Last week I got my new Vero 4K+ and at the moment I have only one issue: I can’t power it on with the remote control.
I’m using the original power supply and have nothing attached to the USB port (just the needed dongle for the remote control).
I run the first installation, updated everything to the latest version and scanned my movies from my NAS. I already watched 3 TV show episodes from my NAS and everything is fine and I’m really happy with this tiny box. ![]()
Except one thing: When I choose the power off function from Kodi, the device shuts down and the red LED appears. But in this status it’s not possible to power on the device from the remote control anymore.
I need to plug off/plug in the power cable and then it starts automatically. I guess this is not the way it should work. ![]()
Did I miss something? I also tried to use the other options in the power off menu. But these just restart Kodi after a couple of seconds.
The device was never used before I got it, so there should be no wrong configuration on it.
The Vero 4K+ is connected via HDMI to a Pioneer AV-Receiver, which is used as HDMI passthrough switch to my Sony TV. I don’t use HDMI CEC, as I’m controlling the TV and the AV-Receiver with my Harmony RC. (The Vero will be controlled by the Vero RC only)
Would be glad, if I could fix this issue…Thanks
