I’m using the Vero 4k with the vero DVB-T2 dongle (with default TVheadend stuff).
The sound quality is noticeably worse (in particular s-sounds have become unpleasantly sharp/distorted) when compared to my previous solution.
I have tested a recorded show on my pc, and the sound is the same leading me to believe the issue is somewhere on the input side.
Is there any way to fix this, or settings i should try somewhere?
Edit, here is a clip: Dropbox - clip.mpeg - Simplify your life
