Over the last couple of weeks, I have been getting a dialog box pop up saying that errors were encountered when trying to update OSMC. I just tried manually checking for updates and received the same error. My OSMC version is currently sitting at June.
What happens if you try to update from command line? We need to see the complete error. Otherwise:
So, in summary:
- activate the logging
- reboot the OSMC device
- reproduce the issue
- upload the log set either using the
Log Uploadermethod within the My OSMC menu in the GUI or thesshmethod invoking commandgrab-logs -A - publish the provided URL from the log set upload, here
Thanks for your quick reply, Brian. I’ll be sure to follow your suggestions.
You could try update via My OSMC again and when you see the error, upload a set of logs.
June is the current version
I tried reproducing the results again according to the aforementioned steps, but ‘Murphy’s Law’ kicked in and instead of giving me an error dialog, it gave me a dialog saying that everything is up-to-date already.
The only thing that had changed since the errors began occurring was that I had set up my internet (wifi and lan) to turn off for several hours at night, then turn back on at 6am in the morning.
Hi Ben
If your connection dropped at the exact time OSMC checked for an update, you would’ve received this message.
We call it Sod’s law
Glad everything is working well and give us a shout if you have any other issues
