Hi folks (ping @sam_nazarko ),
I updated one of my Vero 4K+ deviecs today from the December 2023 release to the latest. A while after, the Ethernet has decided to stop working.
Initially I couldn’t get any connection on Ethernet or WiFi. I tried Enabling and Disabling the adapter in My OSMC, reconnected all cables, did hard power cycles, etc. Nothing helped.
When selecting Automatically configure the network toggle, I get a message about an uncaught exception. Here’s what the kodi.log file mentions:
2024-04-07 22:42:37.409 T:3395 error <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <class 'TypeError'>
Error Contents: 'NoneType' object is not subscriptable
File "/usr/share/kodi/addons/script.module.osmcsetting.networking/resources/lib/osmcnetworking/networking_gui.py", line 531, in onAction
self.update_current_ip_settings(WIRED_IP_VALUES)
File "/usr/share/kodi/addons/script.module.osmcsetting.networking/resources/lib/osmcnetworking/networking_gui.py", line 995, in update_current_ip_settings
self.current_network_config[self.internet_protocol]['Address'] = ip_address
TypeError: 'NoneType' object is not subscriptable
-->End of Python script error report<--
Initially WiFi didnt’ work either, but I did manage to finally get it to connect over WiFi. But Ethernet continues to not work. Everything was working fine before, physical hardware wise, nothing has changed in a long time.
Any idea what the deal might be here?
Could a config file maybe have gotten a bit out of wack with the update, is there any way for me to clear the ethernet config on the CLI perhaps?
And/or is there a way I can re-install the latest updates to make sure they applied properly? the Apt logs appear to note everything completing okay…
p.s.
FWIW, the device appears, for now, to otherwise be working fine over WiFi.
