Hi all,
I had been getting all the functionality I needed from Kodi 17 so held off updated, and I think my box rebooted and update was applied.
Now upon boot the UI is displayed at 720x480p and 1080p movies and all but one 4K movie will play.(so far haven’t tested enough as have family over and was trying to setup a movie for the kids.
I have a JVC DLA-X570 and Denon 4k receiver. No issues prior to update to latest but did skip updates in between so can’t say which update caused the issue per se.
Have Lock HDMI HPD set and tested with Force 422 colour subsampling
Log here http://paste.osmc.tv/ahihobowiw should show boot right into 480p and then manually attempted to set to 1080p and reverting back to 480p
Going to try and force 1080 and play around with different movies to try and provide more info
That could not have happened unless you agreed to the update, or did it manually.
We’ve seen odd problems with Denon’s in the past. The first thing I’d suggest trying is to connect the Vero directly to the TV and see if the problem continues. It that works, then we can try and work around what the Denon may be doing.
Turned out had an extra cable with easy access. Just connected direct now and same issue, another thing thats odd is that i cannot find the whitelist option noted in many of the other threads talking about resolution issues.
Yeah just found that right before you replied. Tried adding it just for a test but you are right made no difference so removed the test ones I added
New log http://paste.osmc.tv/taqazuboku direct to JVC. Boot goes into 480p, manually try to change to 1080p goes to a screen that looks higher resolution but hard to be sure and flashes off and comes back on 480p. This is the same as what is was doing before going through the Denon
Could you try this experiment. Try resetting Kodi to default setting and see if the problem still happens. (Don’t worry, your library and settings wont be lost, it just a test to see if it’s an odd setting).
Might be the easiest as something seems to be odd in between.
Do a fresh install, set gui to 1080p and enable Adjust Refresh Rate Start/Stop and you should be good to go
Glad we were able to help. I haven’t had a chance yet, but out of curiosity I will look closer at you logs to see if I can spot what happened to cause this.
The switch to a low res is a known issue with the change in guisettings from 17 to 18. Should just have been necessary to re-set the resolution to 1080p.
Sorry for the slow reply, had some usb/sd card media issues. After rebooting Vero 4K+ was stuck back in 1080i again. Did a clean load after sorting out media hardware issues. Loaded the June build and then did an OTA update to the latest.
All is working perfectly again. resolution switching is working perfect. Thanks again for the help your responsiveness is much appreciated!
