Vero 4k freeze
How can i upload the kodi.old.log via MyOSMC?
MyOSMC log uploader either choose all or choose Kodi.log that includes the old logs
I couldn’t choose the old log specifically, so i uploaded the whole log again: https://paste.osmc.tv/laqoferota
The uploaded log ends 2023-08-05, but kodi.old.log i pasted above ends 2023-08-08. Maybe you can also take a quick look at the pasted one.
grep error kodi.old.log
2023-08-05 12:06:18.967 T:2794    error <general>: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2023-08-05 12:06:19.364 T:2794    error <general>: AML: no rw on /sys/module/amlvideodri/parameters/freerun_mode
2023-08-05 12:06:19.365 T:2794    error <general>: AML: no rw on /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
2023-08-05 12:06:19.365 T:2794    error <general>: AML: no rw on /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
2023-08-05 12:06:19.365 T:2794    error <general>: AML: no rw on /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
2023-08-05 12:06:19.365 T:2794    error <general>: AML: no rw on /sys/module/di/parameters/bypass_prog
2023-08-05 12:06:19.499 T:2794     info <general>: EGL_EXTENSIONS = EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_reusable_sync EGL_KHR_fence_sync EGL_KHR_lock_surface EGL_KHR_lock_surface2 EGL_EXT_create_context_robustness EGL_ANDROID_blob_cache EGL_KHR_create_context EGL_KHR_partial_update EGL_KHR_create_context_no_error
2023-08-05 12:06:19.799 T:2794     info <general>: GL_EXTENSIONS = GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_OES_mapbuffer GL_KHR_no_error
2023-08-05 12:06:20.216 T:2794    error <general>: Keymapping error: no such action 'jumpsms1' defined
2023-08-05 12:06:20.219 T:2794    error <general>: Keymapping error: no such action 'jumpsms1' defined
2023-08-05 12:06:20.247 T:2898     info <general>: CAESinkALSA - ALSA: conf.c:4745:(_snd_config_evaluate) function snd_func_card_driver returned error: No such device
2023-08-05 12:06:20.248 T:2898     info <general>: CAESinkALSA - ALSA: confmisc.c:392:(snd_func_concat) error evaluating strings
2023-08-05 12:06:20.248 T:2898     info <general>: CAESinkALSA - ALSA: conf.c:4745:(_snd_config_evaluate) function snd_func_concat returned error: No such device
2023-08-05 12:06:20.248 T:2898     info <general>: CAESinkALSA - ALSA: confmisc.c:1246:(snd_func_refer) error evaluating name
2023-08-05 12:06:20.248 T:2898     info <general>: CAESinkALSA - ALSA: conf.c:4745:(_snd_config_evaluate) function snd_func_refer returned error: No such device
2023-08-05 12:06:20.248 T:2898     info <general>: CAESinkALSA - ALSA: conf.c:5233:(snd_config_expand) Evaluate error: No such device
2023-08-05 12:06:20.252 T:2898     info <general>: CAESinkALSA - ALSA: conf.c:5217:(snd_config_expand) Parse arguments error: No such file or directory
2023-08-05 12:06:20.253 T:2898     info <general>: CAESinkALSA - ALSA: conf.c:5217:(snd_config_expand) Parse arguments error: No such file or directory
2023-08-05 12:06:20.256 T:2898     info <general>: CAESinkALSA - ALSA: conf.c:4745:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
2023-08-05 12:06:20.256 T:2898     info <general>: CAESinkALSA - ALSA: conf.c:5233:(snd_config_expand) Evaluate error: No such file or directory
2023-08-05 12:06:20.261 T:2898     info <general>: CAESinkALSA - ALSA: conf.c:5217:(snd_config_expand) Parse arguments error: No such file or directory
2023-08-07 11:10:43.854 T:2922    error <general>: GetDirectory - Error getting include
2023-08-07 11:10:44.785 T:2944    error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/addon_data/pvr.iptvsimple/
2023-08-07 11:10:44.786 T:2944    error <general>: GetDirectory - Error getting special://profile/addon_data/pvr.iptvsimple/
2023-08-07 11:10:44.792 T:2944    error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/addon_data/pvr.nextpvr/
2023-08-07 11:10:44.792 T:2944    error <general>: GetDirectory - Error getting special://profile/addon_data/pvr.nextpvr/
2023-08-07 11:10:44.793 T:2944    error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/addon_data/pvr.sledovanitv.cz/
2023-08-07 11:10:44.793 T:2944    error <general>: GetDirectory - Error getting special://profile/addon_data/pvr.sledovanitv.cz/
2023-08-07 11:10:44.793 T:2944    error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/addon_data/pvr.vbox/
2023-08-07 11:10:44.793 T:2944    error <general>: GetDirectory - Error getting special://profile/addon_data/pvr.vbox/
2023-08-07 11:10:44.794 T:2944    error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/addon_data/pvr.vuplus/
2023-08-07 11:10:44.794 T:2944    error <general>: GetDirectory - Error getting special://profile/addon_data/pvr.vuplus/
2023-08-07 11:11:06.803 T:2936    error <general>: EXCEPTION: Non-Existent Control 300
2023-08-07 17:42:07.335 T:3414    error <general>: GetDirectory - Error getting -
2023-08-08 03:13:34.906 T:2935    error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/auto.master.d/
2023-08-09 03:13:51.139 T:2935    error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/auto.master.d/
For the kodi.old log to be of any use it would need to contain the time from when it crashed. What you uploaded appears to be just rebooting twice and then upload without any crash occurring. When Kodi starts it renames kodi.log to kodi.old.log and starts a new log. So if a crash occurs when Kodi starts back up if you upload logs at that point (without restarting Kodi first) this kodi.old.log might contain information of exactly what it was doing when it crashed. As for the errors you posted above most os those are not really errors so much as just information messages that have no relevance. BTW the keymapping error is because you manually keymapped a jumpsms1 actionid which isn’t something that exists. The number relates to the digit on a phone and “abc” is on number two. There is no letters on 1 thus jumpsms 1-9.
Thanks for the detailed answer. Ok, i wait for the next crash and will upload the kodi.old.log again. But this kodi.old.log i cant upload via the MyOSMC uploader. Therefore i pasted it here last time.
If you have a problem just uploading normally you can try via ssh…
paste-log ~/.kodi/temp/kodi.old.log
Great to know, thank you!
Finally i got a kodi.old.log after crashing:
https://paste.osmc.tv/eruxuyayoz
I would change your HDMI cable and perhaps which input your using on your display and see if the messages reading the display capabilities in the logs over and over stop. If they don’t then you could try enabling settings>system>display>Lock HDMI HPD>.
Thank you!
Do you think this may cause the crashes?
My Vero box is connected to a AV receiver and these AV receiver is connected to a TV and a projector.
Do you recommend to change the HDMI cable between the Vero box and AV receiver or all three?
I really don’t know.
I would start with the one from the Vero to the AVR.
I did some checks.
I get these blocks of display messages in the logs every time I turn the TV on or off. I don’t get these messages when I connect the Vero directly to the TV and turn the TV on or off.
I swapped both HDMI cables, from the AVR to the Vero and from the AVR to the TV, disconnected the projector from the AVR, used different inputs and outputs on the AVR and a different HDMI input on the TV, and unplugged the AVR for a few seconds from the power supply and checked the AVR video settings (no scaling, no ACR). I still got the messages all the time.
After turning on the Lock HDMI HPD option, I no longer get these messages.
I will check if the box still crashes now.
Unfortunately my box crashed last Friday again. I have a new kodi.old.log
https://paste.osmc.tv/telurogipa
Can you see any reasons for the crash? Otherwise it seems that i really have to reinstall osmc :frowning:
BTW the box always feels a little warmer after the crash.
Not sure – but as an aside, your audio settings look a bit problematic.
You get some strange errors. Ping @grahamh
OP has detailed logging for the audio component turned on. You always get logspam from that.
This means the are no more abnormalities in the logs and i have to reinstall?
I reinstalled OSMC last Wednesday or Thursday and just finished the initial setup (language, location etc).
In this status the box runned stable without crashing until yesterday.
Yesterday i did a few settings, installed the addons Audio Profiles and Keymap Editor, added my media sources from my NAS and started a scan. Aside from that a try to watch a trailer via Youtube failed and i did a restart.
Thats all i did, but at the evening the box crashed again :frowning:
Here is my kodi.old.log: https://paste.osmc.tv/avoqodujer
and here my kodi.log: https://paste.osmc.tv/axoqaripuj
I think I heard the YouTube add-on from the Kodi repository is currently broken so you would want to install the updated one from github.
You have an outdated add-on spamming your logs, but I don’t know which one. It is filling your logs with…
warning <general>: ListItem.setCast() is deprecated and might be removed in future Kodi versions. Please use InfoTagVideo.setCast().
warning <general>: ListItem.setUniqueIDs() is deprecated and might be removed in future Kodi versions. Please use InfoTagVideo.setUniqueIDs().
warning <general>: ListItem.addAvailableArtwork() is deprecated and might be removed in future Kodi versions. Please use InfoTagVideo.addAvailableArtwork().
Figuring out which add-on is a fault for that and disabling it would probably be a good place to start.
Thank you darwindesign!
Im wondering that a addon is outdated, i have installed osmc from the scratch, no backup restored und just installed Audio Profiles (2.1.2) and Keymap Editor (1.1.5).
So i dont know which addon i have to disable…
I had no crash since Tuesday and have just now logged in to remove the youtube addon.
BTW for me it seems the log for the last two days looks better:
2023-09-21 11:42:35.896 T:2798     info <general>: Loading skin file: Settings.xml, load type: KEEP_IN_MEMORY
2023-09-21 11:42:39.299 T:2798     info <general>: Loading skin file: AddonBrowser.xml, load type: KEEP_IN_MEMORY
2023-09-22 09:11:22.054 T:2798     info <general>: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
2023-09-22 09:11:22.335 T:5156    error <general>: GetDirectory - Error getting -
2023-09-22 09:11:23.665 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:11:29.192 T:5156     info <general>: Skipped 4 duplicate messages..
2023-09-22 09:11:29.192 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:11:30.159 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:11:33.060 T:5156     info <general>: Skipped 2 duplicate messages..
2023-09-22 09:11:33.060 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:11:36.079 T:5158     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:11:36.079 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:11:37.661 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:11:38.665 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:11:39.948 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:11:42.382 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:11:43.399 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:11:46.605 T:5199     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:11:46.605 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:11:56.814 T:5199     info <general>: Skipped 2 duplicate messages..
2023-09-22 09:11:56.814 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:11:58.318 T:5158     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:11:58.318 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:12:00.838 T:5199     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:12:00.838 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:12:02.321 T:5158     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:12:02.321 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:12:03.376 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:12:04.702 T:5156     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:12:04.702 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:12:05.326 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:12:07.926 T:5156     info <general>: Skipped 2 duplicate messages..
2023-09-22 09:12:07.926 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:12:08.546 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:12:14.046 T:5158     info <general>: Skipped 4 duplicate messages..
2023-09-22 09:12:14.046 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:12:15.682 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:12:17.183 T:5156     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:12:17.183 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:12:18.046 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:12:21.563 T:5158     info <general>: Skipped 2 duplicate messages..
2023-09-22 09:12:21.563 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:12:23.968 T:5156     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:12:23.968 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:12:25.305 T:5158     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:12:25.305 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:12:27.102 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:12:27.868 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:12:35.771 T:5158     info <general>: Skipped 8 duplicate messages..
2023-09-22 09:12:35.771 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:12:36.358 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:12:38.661 T:5156     info <general>: Skipped 2 duplicate messages..
2023-09-22 09:12:38.661 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:12:39.363 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:12:42.353 T:5199     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:12:42.353 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:12:42.854 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:12:45.608 T:5158     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:12:45.608 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:12:51.741 T:5158     info <general>: Skipped 5 duplicate messages..
2023-09-22 09:12:51.741 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:12:53.001 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:12:58.925 T:5199     info <general>: Skipped 4 duplicate messages..
2023-09-22 09:12:58.925 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:12:59.867 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:13:03.344 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:13:04.457 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:13:05.031 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:13:05.714 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:13:06.608 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:13:08.555 T:5156     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:13:08.555 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:13:09.467 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:13:10.190 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:13:11.152 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:13:12.735 T:5158     info <general>: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 41727
2023-09-22 09:13:13.147 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-2 video
2023-09-22 09:13:13.666 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:13:15.523 T:5156     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:13:15.523 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:13:16.969 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:13:21.258 T:5199     info <general>: Skipped 3 duplicate messages..
2023-09-22 09:13:21.258 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-2 video
2023-09-22 09:13:21.744 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:13:23.043 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:13:24.393 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:13:26.956 T:5158     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:13:26.956 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:13:28.104 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:13:29.669 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:13:30.805 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:13:33.029 T:5158     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:13:33.029 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:13:36.290 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:13:37.179 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:13:41.231 T:5156     info <general>: Skipped 2 duplicate messages..
2023-09-22 09:13:41.231 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:13:43.649 T:5156     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:13:43.649 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:13:45.031 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:13:45.620 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:13:46.248 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:13:48.057 T:5156     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:13:48.057 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:13:52.317 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:13:53.070 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:13:54.194 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:13:55.541 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:13:56.449 T:2798     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:13:56.449 T:2798     info <general>: Loading skin file: DialogAddonInfo.xml, load type: KEEP_IN_MEMORY
2023-09-22 09:13:58.619 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:13:59.024 T:2798     info <general>: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
2023-09-22 09:13:59.202 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:14:04.904 T:2798  warning <general>: Skipped 5 duplicate messages..
2023-09-22 09:14:04.904 T:2798  warning <general>: CGUIMediaWindow::OnMessage - updating in progress
2023-09-22 09:14:05.324 T:5156     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:14:05.324 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:14:05.460 T:2798  warning <general>: CGUIMediaWindow::OnMessage - updating in progress
2023-09-22 09:14:05.504 T:5199     info <general>: Skipped 3 duplicate messages..
2023-09-22 09:14:05.504 T:5199     info <general>: CAddonUnInstallJob[plugin.video.youtube]: removed orphaned dependencies (InfoTagger, requests, Skin Shortcuts, certifi, chardet, idna, Simple Eval, Unidecode, urllib3)
2023-09-22 09:14:05.582 T:2798  warning <general>: CGUIMediaWindow::OnMessage - updating in progress
2023-09-22 09:14:06.565 T:5156     info <general>: Skipped 2 duplicate messages..
2023-09-22 09:14:06.565 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:14:07.186 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:14:09.069 T:5199     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:14:09.069 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:14:09.642 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:14:11.285 T:5158     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:14:11.285 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:14:12.829 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-2 video
2023-09-22 09:14:13.221 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:14:15.402 T:5158     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:14:15.402 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:14:23.484 T:2798     info <general>: Skipped 7 duplicate messages..
2023-09-22 09:14:23.484 T:2798     info <general>: Loading skin file: SettingsCategory.xml, load type: KEEP_IN_MEMORY
2023-09-22 09:14:23.978 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:14:25.165 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-2 video
2023-09-22 09:14:25.702 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:14:26.345 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:14:27.713 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:14:28.335 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:14:31.286 T:5158     info <general>: Skipped 3 duplicate messages..
2023-09-22 09:14:31.286 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:14:32.660 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:14:36.646 T:5158     info <general>: Skipped 3 duplicate messages..
2023-09-22 09:14:36.646 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:14:37.194 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:14:38.127 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:14:39.339 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:14:44.873 T:5156     info <general>: Skipped 4 duplicate messages..
2023-09-22 09:14:44.873 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:14:45.471 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:14:52.414 T:5199     info <general>: Skipped 6 duplicate messages..
2023-09-22 09:14:52.414 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:14:53.299 T:5156     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:14:53.975 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:14:55.235 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
2023-09-22 09:14:55.903 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:14:56.917 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-2 video
2023-09-22 09:14:57.438 T:5158     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
2023-09-22 09:14:59.946 T:5199     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:14:59.946 T:5199     info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2023-09-22 09:15:31.984 T:2798     info <general>: Skipped 1 duplicate messages..
2023-09-22 09:15:31.984 T:2798     info <general>: NFS is idle. Closing the remaining connections.
Just these CDVDVideoCodecFFmpeg logs repeat over and over again since i logged in and i navigate through the menus.
I have now startet a new media scan, due the last one hasn’t finished to scan all media bevor the box crashed.
During the scan of movies i got for every scanned movie the following block, you already mentioned, in the logs:
2023-09-22 09:33:11.957 T:5856  warning <general>: Skipped 1 duplicate messages..
2023-09-22 09:33:11.957 T:5856  warning <general>: Setting most video properties through ListItem.setInfo() is deprecated and might be removed in future Kodi versions. Please use the respective setter in InfoTagVideo.
2023-09-22 09:33:11.957 T:5856  warning <general>: ListItem.setCast() is deprecated and might be removed in future Kodi versions. Please use InfoTagVideo.setCast().
2023-09-22 09:33:11.958 T:5856  warning <general>: ListItem.setUniqueIDs() is deprecated and might be removed in future Kodi versions. Please use InfoTagVideo.setUniqueIDs().
2023-09-22 09:33:11.959 T:5856  warning <general>: ListItem.addAvailableArtwork() is deprecated and might be removed in future Kodi versions. Please use InfoTagVideo.addAvailableArtwork().
2023-09-22 09:33:11.960 T:5856  warning <general>: Skipped 26 duplicate messages..
2023-09-22 09:33:11.960 T:5856  warning <general>: ListItem.setRating() is deprecated and might be removed in future Kodi versions. Please use InfoTagVideo.setRating().
I still have no idea what this deprecated add-on is, but it seems that it is only used when scanning movie titles.
