Hello ,
My vero box freezes at indefinite intervals. then no hdmi output and no ping/ssh are possible.
Everything optional except flirc receiver is already removed.
Attached is the log immediately after the restart, can you please check here?
Hello ,
The kodi.old.log is missing which normally would indicate something really bad happened.
When you now reboot can you check if a kodi.old.log is created?
Thanks for the quick response!
The log is empty:
osmc@osmc:~$ ll .kodi/temp/*.log
-rw-r--r-- 1 osmc osmc 101651 Aug 7 12:37 .kodi/temp/kodi.log
-rw-r--r-- 1 osmc osmc 0 Aug 5 12:06 .kodi/temp/kodi.old.log
Maybe because i had to restart twice because the system crashed immediately after the first restart ![]()
But the kodi.log begins two days ago:
osmc@osmc:~$ head -1 .kodi/temp/kodi.log
2023-08-05 12:06:17.836 T:2794 info <general>: -----------------------------------------------------------------------
How can i upload the log?
You could try a fresh install to rule out a software issue
Eluctantly, because I have to make the entire settings again, but if necessary I will do it. ![]()
You can take a backup via MyOSMC and restore. But first suggest doing some test without the restore to ensure the system is stable.
But a system that is not writing proper logs is definitely not healthy.
but the system is writing logs:
osmc@osmc:~$ ll .kodi/temp/kodi.log
-rw-r--r-- 1 osmc osmc 110675 Aug 7 17:04 .kodi/temp/kodi.log
Yesterday the box freezed again, but the subsequent restart was successful. So now I have the old log:
-rw-r--r-- 1 osmc osmc 72843 Aug 5 12:06 kodi.log
-rw-r--r-- 1 osmc osmc 184535 Aug 9 03:13 kodi.old.log
osmc@osmc:~$
Should i upload the log some where or look for something specific in it?
Just upload the logs so that more eyes can help basically you would look at the end of kodi.old.log for crash reasons
Sorry for the late response and thanks for checking!
2023-08-05 12:06:17.836 T:2794 info <general>: Starting Kodi (20.2). Platform: Linux ARM 32-bit (version for Vero)
2023-08-05 12:06:17.837 T:2794 info <general>: Using Release Kodi x32
2023-08-05 12:06:17.837 T:2794 info <general>: Kodi compiled 2023-07-24 by GCC 10.2.1 for Linux ARM 32-bit version 5.10.106 (330346)
2023-08-05 12:06:17.837 T:2794 info <general>: Running on OSMC Vero 4K / Vero 4K + with Open Source Media Center 2023.07-1, kernel: Linux ARM 32-bit version 4.9.269-32-osmc
2023-08-05 12:06:17.852 T:2794 info <general>: FFmpeg version/source: 4.4.1-Kodi
2023-08-05 12:06:17.852 T:2794 info <general>: 4 CPU cores available
2023-08-05 12:06:17.852 T:2794 info <general>: ARM Features: Neon disabled
2023-08-05 12:06:17.852 T:2794 info <general>: special://xbmc/ is mapped to: /usr/share/kodi
2023-08-05 12:06:17.852 T:2794 info <general>: special://xbmcbin/ is mapped to: /usr/lib/kodi
2023-08-05 12:06:17.852 T:2794 info <general>: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
2023-08-05 12:06:17.852 T:2794 info <general>: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
2023-08-05 12:06:17.852 T:2794 info <general>: special://envhome/ is mapped to: /home/osmc
2023-08-05 12:06:17.852 T:2794 info <general>: special://home/ is mapped to: /home/osmc/.kodi
2023-08-05 12:06:17.852 T:2794 info <general>: special://temp/ is mapped to: /home/osmc/.kodi/temp
2023-08-05 12:06:17.853 T:2794 info <general>: special://logpath/ is mapped to: /home/osmc/.kodi/temp
2023-08-05 12:06:17.853 T:2794 info <general>: Webserver extra whitelist paths:
2023-08-05 12:06:17.853 T:2794 info <general>: The executable running is: /usr/lib/kodi/kodi.bin
2023-08-05 12:06:17.853 T:2794 info <general>: Local hostname: osmc
2023-08-05 12:06:17.853 T:2794 info <general>: Log File is located: /home/osmc/.kodi/temp/kodi.log
2023-08-05 12:06:17.866 T:2794 info <general>: -----------------------------------------------------------------------
2023-08-05 12:06:17.867 T:2794 info <general>: loading settings
2023-08-05 12:06:17.869 T:2794 info <general>: special://profile/ is mapped to: special://masterprofile/
2023-08-05 12:06:17.913 T:2794 info <general>: Loaded settings file from special://xbmc/system/advancedsettings.xml
2023-08-05 12:06:17.915 T:2794 info <general>: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<!-- Do not modify! These are OSMC Optimised Settings for your device !-->
<!-- If you wish to override any of these values, then create a file in /home/osmc/.kodi/userdata/advancedsettings.xml !-->
<!-- It will override these settings, and your settings will be preserved across OSMC updates !-->
<advancedsettings version="1.0">
<imageres>540</imageres>
<fanartres>720</fanartres>
<splash>false</splash>
<handlemounting>0</handlemounting>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<cache>
<buffermode>1</buffermode>
<memorysize>524880000</memorysize>
<readfactor>5.0</readfactor>
</cache>
<cputempcommand>/bin/sed -e 's/\([0-9]*\)[0-9]\{3\}.*/\1 C/' /sys/class/thermal/thermal_zone0/temp</cputempcommand>
<gputempcommand>/bin/sed -e 's/\([0-9]*\)[0-9]\{3\}.*/\1 C/' /sys/class/thermal/thermal_zone0/temp</gputempcommand>
<gamesgeneral>
<enable>true</enable>
</gamesgeneral>
<smartredraw>true</smartredraw>
<videoscreen>
<screen>0</screen>
</videoscreen>
<myvideos>
<usetags>false</usetags>
</myvideos>
</advancedsettings>
2023-08-05 12:06:17.917 T:2794 info <general>: No settings file to load (special://masterprofile/advancedsettings.xml)
2023-08-05 12:06:17.917 T:2794 info <general>: Default Video Player: VideoPlayer
2023-08-05 12:06:17.917 T:2794 info <general>: Default Audio Player: paplayer
2023-08-05 12:06:17.918 T:2794 info <general>: Disabled debug logging due to GUI setting. Level 0.
2023-08-05 12:06:17.918 T:2794 info <general>: Log level changed to "info"
2023-08-05 12:06:17.918 T:2794 info <general>: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
2023-08-05 12:06:18.040 T:2794 info <general>: creating subdirectories
2023-08-05 12:06:18.040 T:2794 info <general>: userdata folder: special://masterprofile/
2023-08-05 12:06:18.040 T:2794 info <general>: recording folder:
2023-08-05 12:06:18.040 T:2794 info <general>: screenshots folder:
2023-08-05 12:06:18.050 T:2794 info <general>: Running database version Addons33
2023-08-05 12:06:18.832 T:2882 info <general>: Loading special://xbmc/system/Lircmap.xml
2023-08-05 12:06:18.836 T:2882 info <general>: * Adding remote mapping for device 'mceusb'
2023-08-05 12:06:18.836 T:2882 info <general>: * Adding remote mapping for device 'XboxDVDDongle'
2023-08-05 12:06:18.836 T:2882 info <general>: * Adding remote mapping for device 'Microsoft_Xbox'
2023-08-05 12:06:18.836 T:2882 info <general>: * Adding remote mapping for device 'PinnacleSysPCTVRemote'
2023-08-05 12:06:18.836 T:2882 info <general>: * Adding remote mapping for device 'anysee'
2023-08-05 12:06:18.836 T:2882 info <general>: * Adding remote mapping for device 'iMON-PAD'
2023-08-05 12:06:18.836 T:2882 info <general>: * Adding remote mapping for device 'Antec_Veris_RM200'
2023-08-05 12:06:18.837 T:2882 info <general>: * Adding remote mapping for device 'MCE_via_iMON'
2023-08-05 12:06:18.837 T:2882 info <general>: * Adding remote mapping for device 'TwinHanRemote'
2023-08-05 12:06:18.837 T:2882 info <general>: * Adding remote mapping for device 'linux-input-layer'
2023-08-05 12:06:18.837 T:2882 info <general>: * Linking remote mapping for 'linux-input-layer' to 'cx23885_remote'
2023-08-05 12:06:18.837 T:2882 info <general>: * Adding remote mapping for device 'mediacenter'
2023-08-05 12:06:18.837 T:2882 info <general>: * Adding remote mapping for device 'devinput'
2023-08-05 12:06:18.837 T:2882 info <general>: * Adding remote mapping for device 'devinput-32'
2023-08-05 12:06:18.837 T:2882 info <general>: * Adding remote mapping for device 'devinput-64'
2023-08-05 12:06:18.883 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.2sf v20.2.1 installed
2023-08-05 12:06:18.883 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.asap v20.3.0 installed
2023-08-05 12:06:18.884 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.dumb v20.2.1 installed
2023-08-05 12:06:18.884 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.gme v20.2.1 installed
2023-08-05 12:06:18.884 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.gsf v20.2.1 installed
2023-08-05 12:06:18.885 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.hvl v20.2.1 installed
2023-08-05 12:06:18.885 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.modplug v20.2.0 installed
2023-08-05 12:06:18.885 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.ncsf v20.2.0 installed
2023-08-05 12:06:18.885 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.nosefart v20.2.0 installed
2023-08-05 12:06:18.886 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.openmpt v20.2.0 installed
2023-08-05 12:06:18.886 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.organya v20.2.0 installed
2023-08-05 12:06:18.886 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.qsf v20.2.0 installed
2023-08-05 12:06:18.887 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.sacd v20.3.0 installed
2023-08-05 12:06:18.887 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.sidplay v20.2.0 installed
2023-08-05 12:06:18.887 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.snesapu v20.2.0 installed
2023-08-05 12:06:18.888 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.ssf v20.2.0 installed
2023-08-05 12:06:18.888 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.stsound v20.2.0 installed
2023-08-05 12:06:18.888 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.timidity v20.2.0 installed
2023-08-05 12:06:18.889 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.upse v20.2.0 installed
2023-08-05 12:06:18.889 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.vgmstream v20.2.0 installed
2023-08-05 12:06:18.889 T:2794 info <general>: CAddonMgr::FindAddons: audiodecoder.wsr v20.2.0 installed
2023-08-05 12:06:18.889 T:2794 info <general>: CAddonMgr::FindAddons: audioencoder.flac v20.2.0 installed
2023-08-05 12:06:18.890 T:2794 info <general>: CAddonMgr::FindAddons: audioencoder.kodi.builtin.aac v1.0.2 installed
2023-08-05 12:06:18.890 T:2794 info <general>: CAddonMgr::FindAddons: audioencoder.kodi.builtin.wma v1.0.2 installed
2023-08-05 12:06:18.890 T:2794 info <general>: CAddonMgr::FindAddons: audioencoder.lame v20.3.0 installed
2023-08-05 12:06:18.890 T:2794 info <general>: CAddonMgr::FindAddons: audioencoder.vorbis v20.2.0 installed
2023-08-05 12:06:18.891 T:2794 info <general>: CAddonMgr::FindAddons: audioencoder.wav v20.2.0 installed
2023-08-05 12:06:18.891 T:2794 info <general>: CAddonMgr::FindAddons: game.controller.default v1.0.39 installed
2023-08-05 12:06:18.891 T:2794 info <general>: CAddonMgr::FindAddons: game.controller.keyboard v1.1.27 installed
2023-08-05 12:06:18.892 T:2794 info <general>: CAddonMgr::FindAddons: game.controller.mouse v1.0.22 installed
2023-08-05 12:06:18.892 T:2794 info <general>: CAddonMgr::FindAddons: game.controller.snes v1.0.37 installed
2023-08-05 12:06:18.892 T:2794 info <general>: CAddonMgr::FindAddons: game.libretro v20.2.4 installed
2023-08-05 12:06:18.892 T:2794 info <general>: CAddonMgr::FindAddons: game.libretro.2048 v1.0.0.137 installed
2023-08-05 12:06:18.893 T:2794 info <general>: CAddonMgr::FindAddons: imagedecoder.heif v20.1.0 installed
2023-08-05 12:06:18.893 T:2794 info <general>: CAddonMgr::FindAddons: imagedecoder.mpo v20.1.0 installed
2023-08-05 12:06:18.893 T:2794 info <general>: CAddonMgr::FindAddons: imagedecoder.raw v20.1.0 installed
2023-08-05 12:06:18.893 T:2794 info <general>: CAddonMgr::FindAddons: inputstream.adaptive v20.3.11 installed
2023-08-05 12:06:18.894 T:2794 info <general>: CAddonMgr::FindAddons: inputstream.ffmpegdirect v20.5.0 installed
2023-08-05 12:06:18.894 T:2794 info <general>: CAddonMgr::FindAddons: inputstream.rtmp v20.3.0 installed
2023-08-05 12:06:18.894 T:2794 info <general>: CAddonMgr::FindAddons: kodi.binary.global.audioengine v1.1.1 installed
2023-08-05 12:06:18.895 T:2794 info <general>: CAddonMgr::FindAddons: kodi.binary.global.filesystem v1.1.8 installed
2023-08-05 12:06:18.895 T:2794 info <general>: CAddonMgr::FindAddons: kodi.binary.global.general v1.0.5 installed
2023-08-05 12:06:18.895 T:2794 info <general>: CAddonMgr::FindAddons: kodi.binary.global.gui v5.15.0 installed
2023-08-05 12:06:18.895 T:2794 info <general>: CAddonMgr::FindAddons: kodi.binary.global.main v2.0.2 installed
2023-08-05 12:06:18.896 T:2794 info <general>: CAddonMgr::FindAddons: kodi.binary.global.network v1.0.4 installed
2023-08-05 12:06:18.896 T:2794 info <general>: CAddonMgr::FindAddons: kodi.binary.global.tools v1.0.4 installed
2023-08-05 12:06:18.896 T:2794 info <general>: CAddonMgr::FindAddons: kodi.binary.instance.audiodecoder v4.0.0 installed
2023-08-05 12:06:18.897 T:2794 info <general>: CAddonMgr::FindAddons: kodi.binary.instance.audioencoder v3.0.0 installed
2023-08-05 12:06:18.897 T:2794 info <general>: CAddonMgr::FindAddons: kodi.binary.instance.game v3.0.0 installed
2023-08-05 12:06:18.897 T:2794 info <general>: CAddonMgr::FindAddons: kodi.binary.instance.imagedecoder v3.0.1 installed
2023-08-05 12:06:18.898 T:2794 info <general>: CAddonMgr::FindAddons: kodi.binary.instance.inputstream v3.2.0 installed
2023-08-05 12:06:18.898 T:2794 info <general>: CAddonMgr::FindAddons: kodi.binary.instance.peripheral v2.0.0 installed
2023-08-05 12:06:18.898 T:2794 info <general>: CAddonMgr::FindAddons: kodi.binary.instance.pvr v8.2.0 installed
2023-08-05 12:06:18.899 T:2794 info <general>: CAddonMgr::FindAddons: kodi.binary.instance.screensaver v2.2.0 installed
2023-08-05 12:06:18.899 T:2794 info <general>: CAddonMgr::FindAddons: kodi.binary.instance.vfs v3.0.1 installed
2023-08-05 12:06:18.899 T:2794 info <general>: CAddonMgr::FindAddons: kodi.binary.instance.videocodec v2.0.3 installed
2023-08-05 12:06:18.899 T:2794 info <general>: CAddonMgr::FindAddons: kodi.binary.instance.visualization v4.0.0 installed
2023-08-05 12:06:18.900 T:2794 info <general>: CAddonMgr::FindAddons: kodi.resource v1.0.0 installed
2023-08-05 12:06:18.900 T:2794 info <general>: CAddonMgr::FindAddons: metadata.album.universal v3.1.9 installed
2023-08-05 12:06:18.900 T:2794 info <general>: CAddonMgr::FindAddons: metadata.artists.universal v4.3.11 installed
2023-08-05 12:06:18.901 T:2794 info <general>: CAddonMgr::FindAddons: metadata.common.allmusic.com v3.2.2 installed
2023-08-05 12:06:18.901 T:2794 info <general>: CAddonMgr::FindAddons: metadata.common.fanart.tv v3.6.4 installed
2023-08-05 12:06:18.901 T:2794 info <general>: CAddonMgr::FindAddons: metadata.common.imdb.com v3.2.8 installed
2023-08-05 12:06:18.901 T:2794 info <general>: CAddonMgr::FindAddons: metadata.common.musicbrainz.org v2.2.4 installed
2023-08-05 12:06:18.902 T:2794 info <general>: CAddonMgr::FindAddons: metadata.common.theaudiodb.com v2.0.3 installed
2023-08-05 12:06:18.902 T:2794 info <general>: CAddonMgr::FindAddons: metadata.common.themoviedb.org v3.2.19 installed
2023-08-05 12:06:18.902 T:2794 info <general>: CAddonMgr::FindAddons: metadata.generic.albums v1.0.14 installed
2023-08-05 12:06:18.903 T:2794 info <general>: CAddonMgr::FindAddons: metadata.generic.artists v1.0.14 installed
2023-08-05 12:06:18.903 T:2794 info <general>: CAddonMgr::FindAddons: metadata.local v1.0.1 installed
2023-08-05 12:06:18.903 T:2794 info <general>: CAddonMgr::FindAddons: metadata.themoviedb.org v5.3.0 installed
2023-08-05 12:06:18.903 T:2794 info <general>: CAddonMgr::FindAddons: metadata.themoviedb.org.python v2.1.0 installed
2023-08-05 12:06:18.904 T:2794 info <general>: CAddonMgr::FindAddons: metadata.tvshows.themoviedb.org v3.6.0 installed
2023-08-05 12:06:18.904 T:2794 info <general>: CAddonMgr::FindAddons: metadata.tvshows.themoviedb.org.python v1.6.5 installed
2023-08-05 12:06:18.904 T:2794 info <general>: CAddonMgr::FindAddons: peripheral.joystick v20.1.10 installed
2023-08-05 12:06:18.904 T:2794 info <general>: CAddonMgr::FindAddons: peripheral.xarcade v20.1.3 installed
2023-08-05 12:06:18.905 T:2794 info <general>: CAddonMgr::FindAddons: plugin.video.youtube v7.0.1 installed
2023-08-05 12:06:18.905 T:2794 info <general>: CAddonMgr::FindAddons: pvr.argustv v20.5.0 installed
2023-08-05 12:06:18.905 T:2794 info <general>: CAddonMgr::FindAddons: pvr.dvblink v20.3.0 installed
2023-08-05 12:06:18.906 T:2794 info <general>: CAddonMgr::FindAddons: pvr.dvbviewer v20.4.0 installed
2023-08-05 12:06:18.906 T:2794 info <general>: CAddonMgr::FindAddons: pvr.filmon v20.3.0 installed
2023-08-05 12:06:18.906 T:2794 info <general>: CAddonMgr::FindAddons: pvr.freebox v20.3.2 installed
2023-08-05 12:06:18.907 T:2794 info <general>: CAddonMgr::FindAddons: pvr.hdhomerun v20.4.0 installed
2023-08-05 12:06:18.907 T:2794 info <general>: CAddonMgr::FindAddons: pvr.hts v20.6.2 installed
2023-08-05 12:06:18.907 T:2794 info <general>: CAddonMgr::FindAddons: pvr.iptvsimple v20.10.1 installed
2023-08-05 12:06:18.908 T:2794 info <general>: CAddonMgr::FindAddons: pvr.mediaportal.tvserver v20.3.0 installed
2023-08-05 12:06:18.908 T:2794 info <general>: CAddonMgr::FindAddons: pvr.mythtv v20.3.2 installed
2023-08-05 12:06:18.908 T:2794 info <general>: CAddonMgr::FindAddons: pvr.nextpvr v20.4.2 installed
2023-08-05 12:06:18.908 T:2794 info <general>: CAddonMgr::FindAddons: pvr.njoy v20.3.0 installed
2023-08-05 12:06:18.909 T:2794 info <general>: CAddonMgr::FindAddons: pvr.octonet v20.3.0 installed
2023-08-05 12:06:18.909 T:2794 info <general>: CAddonMgr::FindAddons: pvr.pctv v20.4.0 installed
2023-08-05 12:06:18.909 T:2794 info <general>: CAddonMgr::FindAddons: pvr.sledovanitv.cz v20.6.0 installed
2023-08-05 12:06:18.909 T:2794 info <general>: CAddonMgr::FindAddons: pvr.stalker v20.3.1 installed
2023-08-05 12:06:18.910 T:2794 info <general>: CAddonMgr::FindAddons: pvr.teleboy v20.3.4 installed
2023-08-05 12:06:18.910 T:2794 info <general>: CAddonMgr::FindAddons: pvr.vbox v20.4.2 installed
2023-08-05 12:06:18.910 T:2794 info <general>: CAddonMgr::FindAddons: pvr.vdr.vnsi v20.4.1 installed
2023-08-05 12:06:18.911 T:2794 info <general>: CAddonMgr::FindAddons: pvr.vuplus v20.5.1 installed
2023-08-05 12:06:18.911 T:2794 info <general>: CAddonMgr::FindAddons: pvr.waipu v20.9.0 installed
2023-08-05 12:06:18.911 T:2794 info <general>: CAddonMgr::FindAddons: pvr.wmc v20.3.0 installed
2023-08-05 12:06:18.911 T:2794 info <general>: CAddonMgr::FindAddons: pvr.zattoo v20.3.13 installed
2023-08-05 12:06:18.912 T:2794 info <general>: CAddonMgr::FindAddons: repository.xbmc.org v9.9.12 installed
2023-08-05 12:06:18.912 T:2794 info <general>: CAddonMgr::FindAddons: resource.images.weathericons.default v1.1.9 installed
2023-08-05 12:06:18.912 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.af_za v999.999.999 installed
2023-08-05 12:06:18.912 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.am_et v999.999.999 installed
2023-08-05 12:06:18.913 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.ar_sa v999.999.999 installed
2023-08-05 12:06:18.913 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.ast_es v999.999.999 installed
2023-08-05 12:06:18.913 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.az_az v999.999.999 installed
2023-08-05 12:06:18.914 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.be_by v999.999.999 installed
2023-08-05 12:06:18.914 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.bg_bg v999.999.999 installed
2023-08-05 12:06:18.914 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.bs_ba v999.999.999 installed
2023-08-05 12:06:18.914 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.ca_es v999.999.999 installed
2023-08-05 12:06:18.915 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.cs_cz v999.999.999 installed
2023-08-05 12:06:18.915 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.cy_gb v999.999.999 installed
2023-08-05 12:06:18.915 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.da_dk v999.999.999 installed
2023-08-05 12:06:18.916 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.de_de v999.999.999 installed
2023-08-05 12:06:18.916 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.el_gr v999.999.999 installed
2023-08-05 12:06:18.916 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.en_au v999.999.999 installed
2023-08-05 12:06:18.917 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.en_gb v999.999.999 installed
2023-08-05 12:06:18.917 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.en_nz v999.999.999 installed
2023-08-05 12:06:18.917 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.en_us v999.999.999 installed
2023-08-05 12:06:18.918 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.eo v999.999.999 installed
2023-08-05 12:06:18.918 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.es_ar v999.999.999 installed
2023-08-05 12:06:18.918 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.es_es v999.999.999 installed
2023-08-05 12:06:18.919 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.es_mx v999.999.999 installed
2023-08-05 12:06:18.919 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.et_ee v999.999.999 installed
2023-08-05 12:06:18.919 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.eu_es v999.999.999 installed
2023-08-05 12:06:18.919 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.fa_af v999.999.999 installed
2023-08-05 12:06:18.920 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.fa_ir v999.999.999 installed
2023-08-05 12:06:18.920 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.fi_fi v999.999.999 installed
2023-08-05 12:06:18.920 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.fil v999.999.999 installed
2023-08-05 12:06:18.920 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.fo_fo v999.999.999 installed
2023-08-05 12:06:18.921 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.fr_ca v999.999.999 installed
2023-08-05 12:06:18.921 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.fr_fr v999.999.999 installed
2023-08-05 12:06:18.921 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.gl_es v999.999.999 installed
2023-08-05 12:06:18.922 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.he_il v999.999.999 installed
2023-08-05 12:06:18.922 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.hi_in v999.999.999 installed
2023-08-05 12:06:18.922 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.hr_hr v999.999.999 installed
2023-08-05 12:06:18.922 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.hu_hu v999.999.999 installed
2023-08-05 12:06:18.923 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.hy_am v999.999.999 installed
2023-08-05 12:06:18.923 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.id_id v999.999.999 installed
2023-08-05 12:06:18.923 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.is_is v999.999.999 installed
2023-08-05 12:06:18.924 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.it_it v999.999.999 installed
2023-08-05 12:06:18.924 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.ja_jp v999.999.999 installed
2023-08-05 12:06:18.924 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.kn_in v999.999.999 installed
2023-08-05 12:06:18.924 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.ko_kr v999.999.999 installed
2023-08-05 12:06:18.925 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.lt_lt v999.999.999 installed
2023-08-05 12:06:18.925 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.lv_lv v999.999.999 installed
2023-08-05 12:06:18.925 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.mi v999.999.999 installed
2023-08-05 12:06:18.926 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.mk_mk v999.999.999 installed
2023-08-05 12:06:18.926 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.ml_in v999.999.999 installed
2023-08-05 12:06:18.926 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.mn_mn v999.999.999 installed
2023-08-05 12:06:18.927 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.ms_my v999.999.999 installed
2023-08-05 12:06:18.927 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.mt_mt v999.999.999 installed
2023-08-05 12:06:18.927 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.my_mm v999.999.999 installed
2023-08-05 12:06:18.928 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.nb_no v999.999.999 installed
2023-08-05 12:06:18.928 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.nl_nl v999.999.999 installed
2023-08-05 12:06:18.928 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.os_os v999.999.999 installed
2023-08-05 12:06:18.928 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.pl_pl v999.999.999 installed
2023-08-05 12:06:18.929 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.pt_br v999.999.999 installed
2023-08-05 12:06:18.929 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.pt_pt v999.999.999 installed
2023-08-05 12:06:18.929 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.ro_ro v999.999.999 installed
2023-08-05 12:06:18.930 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.ru_ru v999.999.999 installed
2023-08-05 12:06:18.930 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.si_lk v999.999.999 installed
2023-08-05 12:06:18.930 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.sk_sk v999.999.999 installed
2023-08-05 12:06:18.930 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.sl_si v999.999.999 installed
2023-08-05 12:06:18.931 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.sq_al v999.999.999 installed
2023-08-05 12:06:18.931 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.sr_rs v999.999.999 installed
2023-08-05 12:06:18.931 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.sr_rs@latin v999.999.999 installed
2023-08-05 12:06:18.932 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.sv_se v999.999.999 installed
2023-08-05 12:06:18.932 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.szl v999.999.999 installed
2023-08-05 12:06:18.932 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.ta_in v999.999.999 installed
2023-08-05 12:06:18.932 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.te_in v999.999.999 installed
2023-08-05 12:06:18.933 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.tg_tj v999.999.999 installed
2023-08-05 12:06:18.933 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.th_th v999.999.999 installed
2023-08-05 12:06:18.933 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.uk_ua v999.999.999 installed
2023-08-05 12:06:18.934 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.uz_uz v999.999.999 installed
2023-08-05 12:06:18.934 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.vi_vn v999.999.999 installed
2023-08-05 12:06:18.934 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.zh_cn v999.999.999 installed
2023-08-05 12:06:18.934 T:2794 info <general>: CAddonMgr::FindAddons: resource.language.zh_tw v999.999.999 installed
2023-08-05 12:06:18.935 T:2794 info <general>: CAddonMgr::FindAddons: resource.uisounds.kodi v1.0.1 installed
2023-08-05 12:06:18.935 T:2794 info <general>: CAddonMgr::FindAddons: screensaver.asteroids v20.2.0 installed
2023-08-05 12:06:18.935 T:2794 info <general>: CAddonMgr::FindAddons: screensaver.asterwave v20.2.0 installed
2023-08-05 12:06:18.936 T:2794 info <general>: CAddonMgr::FindAddons: screensaver.biogenesis v20.1.0 installed
2023-08-05 12:06:18.936 T:2794 info <general>: CAddonMgr::FindAddons: screensaver.cpblobs v20.1.0 installed
2023-08-05 12:06:18.936 T:2794 info <general>: CAddonMgr::FindAddons: screensaver.greynetic v20.2.0 installed
2023-08-05 12:06:18.937 T:2794 info <general>: CAddonMgr::FindAddons: screensaver.matrixtrails v20.1.0 installed
2023-08-05 12:06:18.937 T:2794 info <general>: CAddonMgr::FindAddons: screensaver.pingpong v20.2.0 installed
2023-08-05 12:06:18.937 T:2794 info <general>: CAddonMgr::FindAddons: screensaver.pyro v20.1.0 installed
2023-08-05 12:06:18.938 T:2794 info <general>: CAddonMgr::FindAddons: screensaver.shadertoy v20.2.0 installed
2023-08-05 12:06:18.938 T:2794 info <general>: CAddonMgr::FindAddons: screensaver.xbmc.builtin.black v1.0.34 installed
2023-08-05 12:06:18.938 T:2794 info <general>: CAddonMgr::FindAddons: screensaver.xbmc.builtin.dim v1.0.66 installed
2023-08-05 12:06:18.938 T:2794 info <general>: CAddonMgr::FindAddons: script.audio.profiles v2.1.2 installed
2023-08-05 12:06:18.939 T:2794 info <general>: CAddonMgr::FindAddons: script.common.plugin.cache v3.0.0 installed
2023-08-05 12:06:18.939 T:2794 info <general>: CAddonMgr::FindAddons: script.keymap v1.1.5 installed
2023-08-05 12:06:18.939 T:2794 info <general>: CAddonMgr::FindAddons: script.module.arrow v1.0.3.1 installed
2023-08-05 12:06:18.940 T:2794 info <general>: CAddonMgr::FindAddons: script.module.backports.functools_lru_cache v1.6.1 installed
2023-08-05 12:06:18.940 T:2794 info <general>: CAddonMgr::FindAddons: script.module.beautifulsoup v3.2.1 installed
2023-08-05 12:06:18.940 T:2794 info <general>: CAddonMgr::FindAddons: script.module.certifi v2023.5.7 installed
2023-08-05 12:06:18.940 T:2794 info <general>: CAddonMgr::FindAddons: script.module.chardet v5.1.0 installed
2023-08-05 12:06:18.941 T:2794 info <general>: CAddonMgr::FindAddons: script.module.dateutil v2.8.2 installed
2023-08-05 12:06:18.941 T:2794 info <general>: CAddonMgr::FindAddons: script.module.defusedxml v0.6.0+matrix.1 installed
2023-08-05 12:06:18.941 T:2794 info <general>: CAddonMgr::FindAddons: script.module.idna v3.4.0 installed
2023-08-05 12:06:18.942 T:2794 info <general>: CAddonMgr::FindAddons: script.module.infotagger v0.0.7 installed
2023-08-05 12:06:18.942 T:2794 info <general>: CAddonMgr::FindAddons: script.module.inputstreamhelper v0.6.1+matrix.1 installed
2023-08-05 12:06:18.942 T:2794 info <general>: CAddonMgr::FindAddons: script.module.kodi-six v0.1.3.1 installed
2023-08-05 12:06:18.942 T:2794 info <general>: CAddonMgr::FindAddons: script.module.metadatautils v1.0.0 installed
2023-08-05 12:06:18.943 T:2794 info <general>: CAddonMgr::FindAddons: script.module.musicbrainz v0.6.0 installed
2023-08-05 12:06:18.943 T:2794 info <general>: CAddonMgr::FindAddons: script.module.osmccommon v0.1.0 installed
2023-08-05 12:06:18.943 T:2794 info <general>: CAddonMgr::FindAddons: script.module.osmcsetting.apfstore v0.1.0 installed
2023-08-05 12:06:18.943 T:2794 info <general>: CAddonMgr::FindAddons: script.module.osmcsetting.logging v0.1.0 installed
2023-08-05 12:06:18.944 T:2794 info <general>: CAddonMgr::FindAddons: script.module.osmcsetting.networking v0.1.0 installed
2023-08-05 12:06:18.944 T:2794 info <general>: CAddonMgr::FindAddons: script.module.osmcsetting.remotes v0.1.0 installed
2023-08-05 12:06:18.944 T:2794 info <general>: CAddonMgr::FindAddons: script.module.osmcsetting.services v0.1.0 installed
2023-08-05 12:06:18.944 T:2794 info <general>: CAddonMgr::FindAddons: script.module.osmcsetting.updates v0.1.0 installed
2023-08-05 12:06:18.945 T:2794 info <general>: CAddonMgr::FindAddons: script.module.pil v5.1.0 installed
2023-08-05 12:06:18.945 T:2794 info <general>: CAddonMgr::FindAddons: script.module.pycryptodome v3.4.3 installed
2023-08-05 12:06:18.945 T:2794 info <general>: CAddonMgr::FindAddons: script.module.requests v2.31.0 installed
2023-08-05 12:06:18.946 T:2794 info <general>: CAddonMgr::FindAddons: script.module.routing v0.2.3+matrix.1 installed
2023-08-05 12:06:18.946 T:2794 info <general>: CAddonMgr::FindAddons: script.module.simplecache v2.0.2 installed
2023-08-05 12:06:18.946 T:2794 info <general>: CAddonMgr::FindAddons: script.module.simpleeval v0.9.10 installed
2023-08-05 12:06:18.947 T:2794 info <general>: CAddonMgr::FindAddons: script.module.simplejson v3.17.0+matrix.2 installed
2023-08-05 12:06:18.947 T:2794 info <general>: CAddonMgr::FindAddons: script.module.six v1.15.0+matrix.1 installed
2023-08-05 12:06:18.947 T:2794 info <general>: CAddonMgr::FindAddons: script.module.thetvdb v1.0.12 installed
2023-08-05 12:06:18.948 T:2794 info <general>: CAddonMgr::FindAddons: script.module.typing_extensions v3.7.4.3 installed
2023-08-05 12:06:18.948 T:2794 info <general>: CAddonMgr::FindAddons: script.module.unidecode v1.1.1+matrix.2 installed
2023-08-05 12:06:18.948 T:2794 info <general>: CAddonMgr::FindAddons: script.module.urllib3 v1.26.16+matrix.1 installed
2023-08-05 12:06:18.948 T:2794 info <general>: CAddonMgr::FindAddons: script.module.xmltodict v0.12.0+matrix.2 installed
2023-08-05 12:06:18.949 T:2794 info <general>: CAddonMgr::FindAddons: script.skin.helper.service v1.1.3 installed
2023-08-05 12:06:18.949 T:2794 info <general>: CAddonMgr::FindAddons: script.skinshortcuts v2.0.3 installed
2023-08-05 12:06:18.949 T:2794 info <general>: CAddonMgr::FindAddons: service.osmc.settings v0.1.0 installed
2023-08-05 12:06:18.950 T:2794 info <general>: CAddonMgr::FindAddons: skin.estouchy v3.0.8 installed
2023-08-05 12:06:18.950 T:2794 info <general>: CAddonMgr::FindAddons: skin.estuary v3.0.10 installed
2023-08-05 12:06:18.950 T:2794 info <general>: CAddonMgr::FindAddons: skin.osmc v20.0.0 installed
2023-08-05 12:06:18.950 T:2794 info <general>: CAddonMgr::FindAddons: skin.osmc.scope v20.0.0 installed
2023-08-05 12:06:18.951 T:2794 info <general>: CAddonMgr::FindAddons: vfs.libarchive v20.3.0 installed
2023-08-05 12:06:18.951 T:2794 info <general>: CAddonMgr::FindAddons: vfs.rar v20.1.0 installed
2023-08-05 12:06:18.951 T:2794 info <general>: CAddonMgr::FindAddons: vfs.sftp v20.2.0 installed
2023-08-05 12:06:18.951 T:2794 info <general>: CAddonMgr::FindAddons: visualization.fishbmc v20.2.0 installed
2023-08-05 12:06:18.952 T:2794 info <general>: CAddonMgr::FindAddons: visualization.goom v20.1.1 installed
2023-08-05 12:06:18.952 T:2794 info <general>: CAddonMgr::FindAddons: visualization.matrix v20.2.0 installed
2023-08-05 12:06:18.952 T:2794 info <general>: CAddonMgr::FindAddons: visualization.pictureit v20.2.0 installed
2023-08-05 12:06:18.953 T:2794 info <general>: CAddonMgr::FindAddons: visualization.shadertoy v20.3.0 installed
2023-08-05 12:06:18.953 T:2794 info <general>: CAddonMgr::FindAddons: visualization.spectrum v20.2.0 installed
2023-08-05 12:06:18.953 T:2794 info <general>: CAddonMgr::FindAddons: visualization.starburst v20.2.0 installed
2023-08-05 12:06:18.953 T:2794 info <general>: CAddonMgr::FindAddons: visualization.waveform v20.2.1 installed
2023-08-05 12:06:18.954 T:2794 info <general>: CAddonMgr::FindAddons: webinterface.default v19.x-2.4.8 installed
2023-08-05 12:06:18.954 T:2794 info <general>: CAddonMgr::FindAddons: xbmc.addon v20.2.0 installed
2023-08-05 12:06:18.954 T:2794 info <general>: CAddonMgr::FindAddons: xbmc.core v0.1.0 installed
2023-08-05 12:06:18.954 T:2794 info <general>: CAddonMgr::FindAddons: xbmc.gui v5.16.0 installed
2023-08-05 12:06:18.955 T:2794 info <general>: CAddonMgr::FindAddons: xbmc.json v13.0.0 installed
2023-08-05 12:06:18.955 T:2794 info <general>: CAddonMgr::FindAddons: xbmc.metadata v2.1.0 installed
2023-08-05 12:06:18.955 T:2794 info <general>: CAddonMgr::FindAddons: xbmc.python v3.0.1 installed
2023-08-05 12:06:18.956 T:2794 info <general>: CAddonMgr::FindAddons: xbmc.webinterface v1.0.0 installed
2023-08-05 12:06:18.966 T:2794 info <general>: Selected Logind/UPower as PowerSyscall
2023-08-05 12:06:18.967 T:2794 error <general>: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2023-08-05 12:06:18.967 T:2794 info <general>: LogindUPowerSyscall - UPower not found, battery information will not be available
2023-08-05 12:06:19.203 T:2794 info <general>: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
2023-08-05 12:06:19.364 T:2794 error <general>: AML: no rw on /sys/module/amlvideodri/parameters/freerun_mode
2023-08-05 12:06:19.365 T:2794 error <general>: AML: no rw on /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
2023-08-05 12:06:19.365 T:2794 error <general>: AML: no rw on /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
2023-08-05 12:06:19.365 T:2794 error <general>: AML: no rw on /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
2023-08-05 12:06:19.365 T:2794 error <general>: AML: no rw on /sys/module/di/parameters/bypass_prog
2023-08-05 12:06:19.460 T:2794 info <general>: RetroPlayer[RENDER]: Registering renderer factory for OpenGLES
2023-08-05 12:06:19.475 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap to read
2023-08-05 12:06:19.476 T:2794 info <general>: No /home/osmc/.kodi/userdata/vesa_cap to read
2023-08-05 12:06:19.477 T:2794 info <general>: Current display setting is 0192001080060.00000pstd
2023-08-05 12:06:19.477 T:2794 info <general>: Current output resolution is 0192001080059.94006pstd
2023-08-05 12:06:19.477 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2023-08-05 12:06:19.477 T:2794 info <general>: Fallback resolution at 16 + 0 00480060.00000pstd
2023-08-05 12:06:19.477 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2023-08-05 12:06:19.477 T:2794 info <general>: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2023-08-05 12:06:19.477 T:2794 info <general>: Fallback resolution at 16 + 2 00576050.00000pstd
2023-08-05 12:06:19.477 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2023-08-05 12:06:19.477 T:2794 info <general>: Fallback resolution at 16 + 3 00720050.00000pstd
2023-08-05 12:06:19.477 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2023-08-05 12:06:19.477 T:2794 info <general>: Fallback resolution at 16 + 4 00720060.00000pstd
2023-08-05 12:06:19.477 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2023-08-05 12:06:19.477 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 Hz
2023-08-05 12:06:19.477 T:2794 info <general>: Fallback resolution at 16 + 6 01080024.00000pstd
2023-08-05 12:06:19.477 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 Hz
2023-08-05 12:06:19.477 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 25.000000 Hz
2023-08-05 12:06:19.477 T:2794 info <general>: Fallback resolution at 16 + 8 01080025.00000pstd
2023-08-05 12:06:19.477 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 30.000000 Hz
2023-08-05 12:06:19.477 T:2794 info <general>: Fallback resolution at 16 + 9 01080030.00000pstd
2023-08-05 12:06:19.477 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 29.970030 Hz
2023-08-05 12:06:19.477 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2023-08-05 12:06:19.477 T:2794 info <general>: Fallback resolution at 16 + 11 01080050.00000pstd
2023-08-05 12:06:19.477 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2023-08-05 12:06:19.477 T:2794 info <general>: Current resolution setting found at 16 + 12
2023-08-05 12:06:19.478 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 Hz
2023-08-05 12:06:19.478 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 120.000000 Hz
2023-08-05 12:06:19.478 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 24.000000 Hz
2023-08-05 12:06:19.478 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 23.976025 Hz
2023-08-05 12:06:19.478 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 25.000000 Hz
2023-08-05 12:06:19.478 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 30.000000 Hz
2023-08-05 12:06:19.478 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 29.970030 Hz
2023-08-05 12:06:19.478 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 24.000000 Hz
2023-08-05 12:06:19.478 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 23.976025 Hz
2023-08-05 12:06:19.478 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2023-08-05 12:06:19.478 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2023-08-05 12:06:19.478 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2023-08-05 12:06:19.478 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2023-08-05 12:06:19.478 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2023-08-05 12:06:19.478 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
2023-08-05 12:06:19.478 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2023-08-05 12:06:19.478 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940060 Hz
2023-08-05 12:06:19.478 T:2794 info <general>: Found 0192001080060.00000pstd at 28, setting to RES_DESKTOP at 16
2023-08-05 12:06:19.478 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap_3d to read
2023-08-05 12:06:19.479 T:2794 warning <general>: Update3dResolutions: No valid 3D resolutions found.
2023-08-05 12:06:19.498 T:2794 info <general>: EGL_VERSION = 1.4 Linux-r7p0-00rel0-db6da91a
2023-08-05 12:06:19.498 T:2794 info <general>: EGL_VENDOR = ARM
2023-08-05 12:06:19.499 T:2794 info <general>: EGL_EXTENSIONS = EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_reusable_sync EGL_KHR_fence_sync EGL_KHR_lock_surface EGL_KHR_lock_surface2 EGL_EXT_create_context_robustness EGL_ANDROID_blob_cache EGL_KHR_create_context EGL_KHR_partial_update EGL_KHR_create_context_no_error
2023-08-05 12:06:19.499 T:2794 info <general>: EGL_CLIENT_EXTENSIONS = EGL_EXT_client_extensions EGL_EXT_platform_base
2023-08-05 12:06:19.499 T:2794 info <general>: CApplication::CreateGUI - using the aml windowing system
2023-08-05 12:06:19.500 T:2794 info <general>: Checking resolution 16
2023-08-05 12:06:19.799 T:2794 info <general>: GL_VENDOR = ARM
2023-08-05 12:06:19.799 T:2794 info <general>: GL_RENDERER = Mali-450 MP
2023-08-05 12:06:19.799 T:2794 info <general>: GL_VERSION = OpenGL ES 2.0
2023-08-05 12:06:19.799 T:2794 info <general>: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
2023-08-05 12:06:19.799 T:2794 info <general>: GL_EXTENSIONS = GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_OES_mapbuffer GL_KHR_no_error
2023-08-05 12:06:20.165 T:2794 info <general>: GLES: Maximum texture width: 4096
2023-08-05 12:06:20.166 T:2794 info <general>: load keymapping
2023-08-05 12:06:20.170 T:2794 info <general>: Loading special://xbmc/system/keymaps/appcommand.xml
2023-08-05 12:06:20.171 T:2794 info <general>: Loading special://xbmc/system/keymaps/customcontroller.AppleRemote.xml
2023-08-05 12:06:20.174 T:2794 info <general>: Loading special://xbmc/system/keymaps/customcontroller.Harmony.xml
2023-08-05 12:06:20.178 T:2794 info <general>: Loading special://xbmc/system/keymaps/customcontroller.SiriRemote.xml
2023-08-05 12:06:20.180 T:2794 info <general>: Loading special://xbmc/system/keymaps/gamepad.xml
2023-08-05 12:06:20.183 T:2794 info <general>: Loading special://xbmc/system/keymaps/hama_mce.xml
2023-08-05 12:06:20.184 T:2794 info <general>: Loading special://xbmc/system/keymaps/joystick.xml
2023-08-05 12:06:20.188 T:2794 info <general>: Loading special://xbmc/system/keymaps/keyboard.xml
2023-08-05 12:06:20.196 T:2794 info <general>: Loading special://xbmc/system/keymaps/mouse.xml
2023-08-05 12:06:20.198 T:2794 info <general>: Loading special://xbmc/system/keymaps/osmc_classic.xml
2023-08-05 12:06:20.199 T:2794 info <general>: Loading special://xbmc/system/keymaps/remote.xml
2023-08-05 12:06:20.205 T:2794 info <general>: Loading special://xbmc/system/keymaps/touchscreen.xml
2023-08-05 12:06:20.212 T:2794 info <general>: Loading special://masterprofile/keymaps/audio_sub.xml
2023-08-05 12:06:20.213 T:2794 info <general>: Loading special://masterprofile/keymaps/audioprofiles.xml
2023-08-05 12:06:20.214 T:2794 info <general>: Loading special://masterprofile/keymaps/codecinfo.xml
2023-08-05 12:06:20.215 T:2794 info <general>: Loading special://masterprofile/keymaps/sms.xml
2023-08-05 12:06:20.216 T:2794 error <general>: Keymapping error: no such action 'jumpsms1' defined
2023-08-05 12:06:20.218 T:2794 info <general>: Loading special://profile/keymaps/audio_sub.xml
2023-08-05 12:06:20.218 T:2794 info <general>: Loading special://profile/keymaps/audioprofiles.xml
2023-08-05 12:06:20.218 T:2794 info <general>: Loading special://profile/keymaps/codecinfo.xml
2023-08-05 12:06:20.219 T:2794 info <general>: Loading special://profile/keymaps/sms.xml
2023-08-05 12:06:20.219 T:2794 error <general>: Keymapping error: no such action 'jumpsms1' defined
2023-08-05 12:06:20.219 T:2794 info <general>: GUI format 1920x1080, Display 1920x1080 @ 60.00 - Full Screen
2023-08-05 12:06:20.238 T:2898 info <general>: CAESinkALSA::EnumerateDevice - device default description
2023-08-05 12:06:20.247 T:2898 info <general>: CAESinkALSA - ALSA: confmisc.c:767:(parse_card) cannot find card '$CARD'
2023-08-05 12:06:20.247 T:2898 info <general>: CAESinkALSA - ALSA: conf.c:4745:(_snd_config_evaluate) function snd_func_card_driver returned error: No such device
2023-08-05 12:06:20.248 T:2898 info <general>: CAESinkALSA - ALSA: confmisc.c:392:(snd_func_concat) error evaluating strings
2023-08-05 12:06:20.248 T:2898 info <general>: CAESinkALSA - ALSA: conf.c:4745:(_snd_config_evaluate) function snd_func_concat returned error: No such device
2023-08-05 12:06:20.248 T:2898 info <general>: CAESinkALSA - ALSA: confmisc.c:1246:(snd_func_refer) error evaluating name
2023-08-05 12:06:20.248 T:2898 info <general>: CAESinkALSA - ALSA: conf.c:4745:(_snd_config_evaluate) function snd_func_refer returned error: No such device
2023-08-05 12:06:20.248 T:2898 info <general>: CAESinkALSA - ALSA: conf.c:5233:(snd_config_expand) Evaluate error: No such device
2023-08-05 12:06:20.252 T:2898 info <general>: CAESinkALSA - ALSA: conf.c:5084:(parse_args) Unknown parameter CARD
2023-08-05 12:06:20.252 T:2898 info <general>: CAESinkALSA - ALSA: conf.c:5217:(snd_config_expand) Parse arguments error: No such file or directory
2023-08-05 12:06:20.253 T:2898 info <general>: CAESinkALSA - ALSA: conf.c:5084:(parse_args) Unknown parameter CARD
2023-08-05 12:06:20.253 T:2898 info <general>: CAESinkALSA - ALSA: conf.c:5217:(snd_config_expand) Parse arguments error: No such file or directory
2023-08-05 12:06:20.253 T:2898 info <general>: CAESinkALSA - ALSA: conf.c:5200:(snd_config_expand) Unknown parameters CARD=AMLMESONAUDIO,DEV=0
2023-08-05 12:06:20.253 T:2898 info <general>: CAESinkALSA - ALSA: conf.c:5084:(parse_args) Unknown parameter DEV
2023-08-05 12:06:20.254 T:2898 info <general>: CAESinkALSA - ALSA: conf.c:5200:(snd_config_expand) Unknown parameters CARD=AMLMESONAUDIO,DEV=0
2023-08-05 12:06:20.255 T:2898 info <general>: CAESinkALSA - ALSA: conf.c:5200:(snd_config_expand) Unknown parameters CARD=AMLMESONAUDIO
2023-08-05 12:06:20.255 T:2898 info <general>: CAESinkALSA - ALSA: conf.c:5200:(snd_config_expand) Unknown parameters CARD=AMLMESONAUDIO,DEV=0
2023-08-05 12:06:20.256 T:2898 info <general>: CAESinkALSA - ALSA: confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.AML-MESONAUDIO.pcm.hdmi.1:CARD=AMLMESONAUDIO,AES0=4,AES1=130,AES2=0,AES3=2'
2023-08-05 12:06:20.256 T:2898 info <general>: CAESinkALSA - ALSA: conf.c:4745:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
2023-08-05 12:06:20.256 T:2898 info <general>: CAESinkALSA - ALSA: conf.c:5233:(snd_config_expand) Evaluate error: No such file or directory
2023-08-05 12:06:20.261 T:2898 info <general>: CAESinkALSA - ALSA: conf.c:5200:(snd_config_expand) Unknown parameters CARD=AMLMESONAUDIO,DEV=0
2023-08-05 12:06:20.261 T:2898 info <general>: CAESinkALSA - ALSA: conf.c:5084:(parse_args) Unknown parameter CARD
2023-08-05 12:06:20.261 T:2898 info <general>: CAESinkALSA - ALSA: conf.c:5217:(snd_config_expand) Parse arguments error: No such file or directory
2023-08-05 12:06:20.271 T:2898 info <general>: CAESinkALSA - ALSA: bluealsa-pcm.c:1057:(_snd_pcm_bluealsa_open) Couldn't get BlueALSA PCM: PCM not found
2023-08-05 12:06:20.271 T:2898 info <general>: CAESinkALSA - Unable to open device "bluealsa" for playback
2023-08-05 12:06:20.276 T:2898 info <general>: CAESinkALSA - ALSA: bluealsa-pcm.c:1057:(_snd_pcm_bluealsa_open) Couldn't get BlueALSA PCM: PCM not found
2023-08-05 12:06:20.276 T:2898 info <general>: CAESinkALSA - Unable to open device "btaudio" for playback
2023-08-05 12:06:20.278 T:2898 info <general>: CAESinkALSA::EnumerateDevice - device hdmi:CARD=AMLMESONAUDIO,DEV=0 description AML-MESONAUDIO,
HDMI Audio Output
2023-08-05 12:06:20.278 T:2898 info <general>: CAESinkALSA - ALSA: pcm_hw.c:1220:(snd_pcm_query_chmaps_from_hw) Cannot read Channel Map TLV
2023-08-05 12:06:20.279 T:2898 info <general>: Found 1 Lists of Devices
2023-08-05 12:06:20.279 T:2898 info <general>: Enumerated ALSA devices:
2023-08-05 12:06:20.279 T:2898 info <general>: Device 1
2023-08-05 12:06:20.279 T:2898 info <general>: m_deviceName : default
2023-08-05 12:06:20.279 T:2898 info <general>: m_displayName : Default (AML-MESONAUDIO: HDMI, S/PDIF & analogue)
2023-08-05 12:06:20.279 T:2898 info <general>: m_displayNameExtra:
2023-08-05 12:06:20.280 T:2898 info <general>: m_deviceType : AE_DEVTYPE_PCM
2023-08-05 12:06:20.280 T:2898 info <general>: m_channels : FL, FR, UNKNOWN1, LFE, FC, BC, BL, BR, BLOC, BROC
2023-08-05 12:06:20.280 T:2898 info <general>: m_sampleRates : 32000,44100,48000,64000,88200,96000,176400,192000
2023-08-05 12:06:20.280 T:2898 info <general>: m_dataFormats : AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
2023-08-05 12:06:20.280 T:2898 info <general>: m_streamTypes : No passthrough capabilities
2023-08-05 12:06:20.280 T:2898 info <general>: Device 2
2023-08-05 12:06:20.280 T:2898 info <general>: m_deviceName : hdmi:CARD=AMLMESONAUDIO,DEV=0
2023-08-05 12:06:20.280 T:2898 info <general>: m_displayName : AML-MESONAUDIO
2023-08-05 12:06:20.280 T:2898 info <general>: m_displayNameExtra: HDMI
2023-08-05 12:06:20.280 T:2898 info <general>: m_deviceType : AE_DEVTYPE_HDMI
2023-08-05 12:06:20.280 T:2898 info <general>: m_channels : FL, FR, BL, BR, FC, LFE, SL, SR
2023-08-05 12:06:20.280 T:2898 info <general>: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
2023-08-05 12:06:20.280 T:2898 info <general>: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
2023-08-05 12:06:20.280 T:2898 info <general>: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_MA,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
2023-08-05 12:06:20.280 T:2899 info <general>: CActiveAESink::OpenSink - initialize sink
2023-08-05 12:06:20.280 T:2899 info <general>: CAESinkALSA::Initialize - Requested layout FL, FR
2023-08-05 12:06:20.280 T:2899 info <general>: CAESinkALSA::Initialize - set digital codec 0
2023-08-05 12:06:20.281 T:2899 info <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2023-08-05 12:06:20.285 T:2899 info <general>: CAESinkALSA::Initialize - Opened device "default"
2023-08-05 12:06:20.286 T:2899 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-08-05 12:06:20.286 T:2899 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-08-05 12:06:20.289 T:2899 info <general>: CAESinkALSA::Initialize - speaker layout 0
2023-08-05 12:06:20.289 T:2899 info <general>: CAESinkALSA - ALSA: pcm_hw.c:1359:(snd_pcm_hw_get_chmap) Cannot read Channel Map ctl
: Invalid argument
2023-08-05 12:06:20.307 T:2898 warning <general>: CActiveAE::StateMachine - signal: 0 from port: OutputControlPort not handled for state: 7
2023-08-05 12:06:20.307 T:2794 info <general>: CLangInfo: loading resource.language.de_de language information...
2023-08-05 12:06:20.329 T:2794 info <general>: global locale set to C
2023-08-05 12:06:20.329 T:2794 info <general>: CLangInfo: loading resource.language.de_de language strings...
2023-08-05 12:06:20.848 T:2794 info <general>: WaitForNet: Waiting for a network interface to come up (Timeout: 1 s)
2023-08-05 12:06:20.848 T:2794 info <general>: WaitForNet: A network interface is up after waiting 0 ms
2023-08-05 12:06:20.851 T:2904 info <general>: Running database version Addons33
2023-08-05 12:06:20.853 T:2904 info <general>: Running database version ViewModes6
2023-08-05 12:06:20.855 T:2904 info <general>: Running database version Textures13
2023-08-05 12:06:20.863 T:2904 info <general>: Running database version MyMusic82
2023-08-05 12:06:20.874 T:2904 info <general>: Running database version MyVideos121
2023-08-05 12:06:20.878 T:2904 info <general>: Running database version TV40
2023-08-05 12:06:20.880 T:2904 info <general>: Running database version Epg16
2023-08-05 12:06:20.924 T:2794 info <general>: Unloaded skin
2023-08-05 12:06:20.929 T:2794 info <general>: load skin from: /usr/share/kodi/addons/skin.osmc/ (version: 20.0.0)
2023-08-05 12:06:20.929 T:2794 info <general>: load fonts for skin...
2023-08-05 12:06:20.933 T:2794 info <general>: Loading skin includes from /usr/share/kodi/addons/skin.osmc/xml/Includes.xml
2023-08-05 12:06:21.126 T:2794 info <general>: Error loading include file /usr/share/kodi/addons/skin.osmc/xml/Coordinates_Includes_Home.xml: Failed to open file (row: 0, col: 0)
2023-08-07 11:10:42.447 T:2794 info <general>: LoadFonts: Loading fonts from '/usr/share/kodi/addons/skin.osmc/xml/Font.xml'
2023-08-07 11:10:42.526 T:2794 info <general>: LoadTimers: Trying to load skin timers from /usr/share/kodi/addons/skin.osmc/xml/Timers.xml
2023-08-07 11:10:42.526 T:2794 warning <general>: LoadTimers: Could not load timers file /usr/share/kodi/addons/skin.osmc/xml/Timers.xml: Failed to open file (row: 0, col: 0)
2023-08-07 11:10:42.526 T:2794 info <general>: load new skin...
2023-08-07 11:10:42.526 T:2794 info <general>: Loading custom window XMLs from skin path /usr/share/kodi/addons/skin.osmc/xml
2023-08-07 11:10:42.552 T:2794 info <general>: initialize new skin...
2023-08-07 11:10:42.552 T:2794 info <general>: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
2023-08-07 11:10:42.557 T:2794 info <general>: Loading skin file: DialogNotification.xml, load type: LOAD_ON_GUI_INIT
2023-08-07 11:10:42.563 T:2794 info <general>: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
2023-08-07 11:10:42.576 T:2794 info <general>: Loading skin file: DialogExtendedProgressBar.xml, load type: LOAD_ON_GUI_INIT
2023-08-07 11:10:42.581 T:2794 info <general>: Loading skin file: Pointer.xml, load type: LOAD_ON_GUI_INIT
2023-08-07 11:10:42.583 T:2794 info <general>: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
2023-08-07 11:10:42.586 T:2794 info <general>: Loading skin file: DialogVolumeBar.xml, load type: LOAD_ON_GUI_INIT
2023-08-07 11:10:42.591 T:2794 info <general>: Loading skin file: Custom_AutoMusicVis.xml, load type: LOAD_ON_GUI_INIT
2023-08-07 11:10:42.592 T:2794 info <general>: Loading skin file: Custom_Overlay_Debug.xml, load type: LOAD_ON_GUI_INIT
2023-08-07 11:10:42.632 T:2794 info <general>: Loading skin file: Custom_Cache_Progress.xml, load type: LOAD_ON_GUI_INIT
2023-08-07 11:10:42.637 T:2794 info <general>: Loading resource://resource.uisounds.kodi/sounds.xml
2023-08-07 11:10:42.735 T:2794 info <general>: skin loaded...
2023-08-07 11:10:42.735 T:2794 info <general>: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
2023-08-07 11:10:42.756 T:2794 info <general>: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
2023-08-07 11:10:42.823 T:2794 warning <general>: Skin has invalid include: skinshortcuts-group-
2023-08-07 11:10:43.626 T:2794 warning <general>: JSONRPC: Could not parse type "Setting.Details.SettingList"
2023-08-07 11:10:43.626 T:2794 info <general>: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
2023-08-07 11:10:43.627 T:2794 info <general>: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
2023-08-07 11:10:43.722 T:2794 info <general>: JSONRPC v13.0.0: Successfully initialized
2023-08-07 11:10:43.722 T:2794 info <general>: [Media Detection] starting service for optical media detection
2023-08-07 11:10:43.854 T:2922 error <general>: GetDirectory - Error getting include
2023-08-07 11:10:43.909 T:2794 info <general>: AddOnLog: peripheral.joystick: Enabling joystick interface "linux"
2023-08-07 11:10:43.944 T:2794 info <general>: Register - new keyboard device registered on application->keyboard: Tastatur (0000:0000)
2023-08-07 11:10:43.946 T:2794 info <general>: Register - new mouse device registered on application->mouse: Maus (0000:0000)
2023-08-07 11:10:43.948 T:2794 info <general>: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2023-08-07 11:10:43.957 T:2794 info <general>: Loaded playercorefactory configuration
2023-08-07 11:10:43.957 T:2794 info <general>: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2023-08-07 11:10:43.957 T:2794 info <general>: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2023-08-07 11:10:43.957 T:2794 info <general>: removing tempfiles
2023-08-07 11:10:43.969 T:2794 info <general>: initialize done
2023-08-07 11:10:43.969 T:2794 info <general>: Running the application...
2023-08-07 11:10:43.994 T:2794 info <general>: starting zeroconf publishing
2023-08-07 11:10:43.998 T:2938 info <general>: ES: Starting UDP Event server on port 9777
2023-08-07 11:10:43.998 T:2938 info <general>: UDP: Listening on port 9777 (ipv6 : false)
2023-08-07 11:10:44.001 T:2794 info <general>: JSONRPC Server: Successfully initialized
2023-08-07 11:10:44.013 T:2794 info <CWebserver[80]>: Started
2023-08-07 11:10:44.015 T:2794 info <general>: AIRTUNES: Initialized server socket(s)
2023-08-07 11:10:44.024 T:2794 info <general>: CWSDiscoveryListenerUDP::Start - Started
2023-08-07 11:10:44.121 T:2794 info <general>: GLES: Enabling VSYNC
2023-08-07 11:10:44.229 T:2929 info <general>: Register - new cec device registered on cec->AOCEC: CEC Adapter (0000:0000)
2023-08-07 11:10:44.785 T:2944 error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/addon_data/pvr.iptvsimple/
2023-08-07 11:10:44.786 T:2944 error <general>: GetDirectory - Error getting special://profile/addon_data/pvr.iptvsimple/
2023-08-07 11:10:44.792 T:2944 error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/addon_data/pvr.nextpvr/
2023-08-07 11:10:44.792 T:2944 error <general>: GetDirectory - Error getting special://profile/addon_data/pvr.nextpvr/
2023-08-07 11:10:44.793 T:2944 error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/addon_data/pvr.sledovanitv.cz/
2023-08-07 11:10:44.793 T:2944 error <general>: GetDirectory - Error getting special://profile/addon_data/pvr.sledovanitv.cz/
2023-08-07 11:10:44.793 T:2944 error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/addon_data/pvr.vbox/
2023-08-07 11:10:44.793 T:2944 error <general>: GetDirectory - Error getting special://profile/addon_data/pvr.vbox/
2023-08-07 11:10:44.794 T:2944 error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/addon_data/pvr.vuplus/
2023-08-07 11:10:44.794 T:2944 error <general>: GetDirectory - Error getting special://profile/addon_data/pvr.vuplus/
2023-08-07 11:10:47.219 T:2794 info <general>: Loading skin file: Settings.xml, load type: KEEP_IN_MEMORY
2023-08-07 11:10:50.809 T:2933 info <general>: [Audio Profiles Service] background monitor version 2.1.2 started
2023-08-07 11:10:50.809 T:2933 info <general>: [Audio Profiles Service] debug logging set to False
2023-08-07 11:10:52.074 T:2794 info <general>: Loading skin file: SettingsSystemInfo.xml, load type: KEEP_IN_MEMORY
2023-08-07 11:11:02.118 T:2794 info <general>: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
2023-08-07 11:11:06.634 T:2794 info <general>: Loading skin file: /usr/share/kodi/addons/service.osmc.settings/resources/skins/Default/1080i/settings_gui_720.xml, load type: LOAD_ON_GUI_INIT
2023-08-07 11:11:06.803 T:2936 error <general>: EXCEPTION: Non-Existent Control 300
2023-08-07 11:11:12.903 T:2794 info <general>: Loading skin file: DialogAddonSettings.xml, load type: KEEP_IN_MEMORY
2023-08-07 11:11:27.198 T:3032 warning <general>: CPythonInvoker(8): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
2023-08-07 11:12:16.422 T:2794 warning <general>: CGUIWindowManager - HandleAction - ignoring action 92, because topmost modal dialog closing animation is running
2023-08-07 11:12:26.803 T:2794 info <general>: Skipped 1 duplicate messages..
2023-08-07 11:12:26.803 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap to read
2023-08-07 11:12:26.804 T:2794 info <general>: No /home/osmc/.kodi/userdata/vesa_cap to read
2023-08-07 11:12:26.804 T:2794 info <general>: Current display setting is 0192001080060.00000pstd
2023-08-07 11:12:26.804 T:2794 info <general>: Current output resolution is 0192001080060.00000pstd
2023-08-07 11:12:26.804 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2023-08-07 11:12:26.805 T:2794 info <general>: Fallback resolution at 16 + 0 00480060.00000pstd
2023-08-07 11:12:26.805 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2023-08-07 11:12:26.805 T:2794 info <general>: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2023-08-07 11:12:26.805 T:2794 info <general>: Fallback resolution at 16 + 2 00576050.00000pstd
2023-08-07 11:12:26.805 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2023-08-07 11:12:26.805 T:2794 info <general>: Fallback resolution at 16 + 3 00720050.00000pstd
2023-08-07 11:12:26.805 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2023-08-07 11:12:26.805 T:2794 info <general>: Fallback resolution at 16 + 4 00720060.00000pstd
2023-08-07 11:12:26.805 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2023-08-07 11:12:26.805 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 Hz
2023-08-07 11:12:26.805 T:2794 info <general>: Fallback resolution at 16 + 6 01080024.00000pstd
2023-08-07 11:12:26.805 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 Hz
2023-08-07 11:12:26.805 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 25.000000 Hz
2023-08-07 11:12:26.805 T:2794 info <general>: Fallback resolution at 16 + 8 01080025.00000pstd
2023-08-07 11:12:26.805 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 30.000000 Hz
2023-08-07 11:12:26.805 T:2794 info <general>: Fallback resolution at 16 + 9 01080030.00000pstd
2023-08-07 11:12:26.805 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 29.970030 Hz
2023-08-07 11:12:26.805 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2023-08-07 11:12:26.805 T:2794 info <general>: Fallback resolution at 16 + 11 01080050.00000pstd
2023-08-07 11:12:26.805 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2023-08-07 11:12:26.805 T:2794 info <general>: Current resolution setting found at 16 + 12
2023-08-07 11:12:26.805 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 Hz
2023-08-07 11:12:26.805 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 120.000000 Hz
2023-08-07 11:12:26.805 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 24.000000 Hz
2023-08-07 11:12:26.806 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 23.976025 Hz
2023-08-07 11:12:26.806 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 25.000000 Hz
2023-08-07 11:12:26.806 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 30.000000 Hz
2023-08-07 11:12:26.806 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 29.970030 Hz
2023-08-07 11:12:26.806 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 24.000000 Hz
2023-08-07 11:12:26.806 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 23.976025 Hz
2023-08-07 11:12:26.806 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2023-08-07 11:12:26.806 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2023-08-07 11:12:26.806 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2023-08-07 11:12:26.806 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2023-08-07 11:12:26.806 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2023-08-07 11:12:26.806 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
2023-08-07 11:12:26.806 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2023-08-07 11:12:26.806 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940060 Hz
2023-08-07 11:12:26.806 T:2794 info <general>: Found 0192001080060.00000pstd at 28, setting to RES_DESKTOP at 16
2023-08-07 11:12:26.806 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap_3d to read
2023-08-07 11:12:26.807 T:2794 warning <general>: Update3dResolutions: No valid 3D resolutions found.
2023-08-07 11:12:27.338 T:2899 info <general>: CActiveAESink::OpenSink - initialize sink
2023-08-07 11:12:27.338 T:2899 info <general>: CAESinkALSA::Initialize - Requested layout FL, FR
2023-08-07 11:12:27.338 T:2899 info <general>: CAESinkALSA::Initialize - set digital codec 0
2023-08-07 11:12:27.338 T:2899 info <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2023-08-07 11:12:27.344 T:2899 info <general>: CAESinkALSA::Initialize - Opened device "default"
2023-08-07 11:12:27.344 T:2899 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-08-07 11:12:27.344 T:2899 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-08-07 11:12:27.346 T:2899 info <general>: CAESinkALSA::Initialize - speaker layout 0
2023-08-07 11:12:27.346 T:2899 info <general>: CAESinkALSA - ALSA: pcm_hw.c:1359:(snd_pcm_hw_get_chmap) Cannot read Channel Map ctl
: Invalid argument
2023-08-07 11:12:27.351 T:2794 info <general>: GLES: Maximum texture width: 4096
2023-08-07 11:12:27.353 T:2794 info <general>: Updated resolutions and set desktop
2023-08-07 12:37:30.165 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap to read
2023-08-07 12:37:30.166 T:2794 info <general>: No /home/osmc/.kodi/userdata/vesa_cap to read
2023-08-07 12:37:30.166 T:2794 info <general>: Current display setting is 0192001080060.00000pstd
2023-08-07 12:37:30.167 T:2794 info <general>: Current output resolution is 0192001080060.00000pstd
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Fallback resolution at 16 + 0 00480060.00000pstd
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Fallback resolution at 16 + 2 00576050.00000pstd
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Fallback resolution at 16 + 3 00720050.00000pstd
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Fallback resolution at 16 + 4 00720060.00000pstd
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Fallback resolution at 16 + 6 01080024.00000pstd
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 25.000000 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Fallback resolution at 16 + 8 01080025.00000pstd
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 30.000000 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Fallback resolution at 16 + 9 01080030.00000pstd
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 29.970030 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Fallback resolution at 16 + 11 01080050.00000pstd
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Current resolution setting found at 16 + 12
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 120.000000 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 24.000000 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 23.976025 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 25.000000 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 30.000000 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 29.970030 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 24.000000 Hz
2023-08-07 12:37:30.167 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 23.976025 Hz
2023-08-07 12:37:30.168 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2023-08-07 12:37:30.168 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2023-08-07 12:37:30.168 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2023-08-07 12:37:30.168 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2023-08-07 12:37:30.168 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2023-08-07 12:37:30.168 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
2023-08-07 12:37:30.168 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2023-08-07 12:37:30.168 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940060 Hz
2023-08-07 12:37:30.168 T:2794 info <general>: Found 0192001080060.00000pstd at 28, setting to RES_DESKTOP at 16
2023-08-07 12:37:30.168 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap_3d to read
2023-08-07 12:37:30.168 T:2794 warning <general>: Update3dResolutions: No valid 3D resolutions found.
2023-08-07 12:37:30.367 T:2794 info <general>: GLES: Maximum texture width: 4096
2023-08-07 12:37:30.368 T:2899 info <general>: CActiveAESink::OpenSink - initialize sink
2023-08-07 12:37:30.368 T:2899 info <general>: CAESinkALSA::Initialize - Requested layout FL, FR
2023-08-07 12:37:30.368 T:2899 info <general>: CAESinkALSA::Initialize - set digital codec 0
2023-08-07 12:37:30.368 T:2899 info <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2023-08-07 12:37:30.369 T:2794 info <general>: Updated resolutions and set desktop
2023-08-07 12:37:30.375 T:2899 info <general>: CAESinkALSA::Initialize - Opened device "default"
2023-08-07 12:37:30.375 T:2899 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-08-07 12:37:30.375 T:2899 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-08-07 12:37:30.377 T:2899 info <general>: CAESinkALSA::Initialize - speaker layout 0
2023-08-07 12:37:30.377 T:2899 info <general>: CAESinkALSA - ALSA: pcm_hw.c:1359:(snd_pcm_hw_get_chmap) Cannot read Channel Map ctl
: Invalid argument
2023-08-07 12:37:38.880 T:3201 info <general>: [Audio Profiles] script version 2.1.2 started
2023-08-07 12:37:38.881 T:3201 info <general>: [Audio Profiles] debug logging set to False
2023-08-07 12:37:38.883 T:3201 info <general>: [Audio Profiles] RESTORING SETTING: 2.0 (TV)
2023-08-07 12:37:38.890 T:3201 info <general>: [Audio Profiles] script version 2.1.2 stopped
2023-08-07 12:37:39.076 T:2898 warning <general>: CActiveAE::StateMachine - signal: 1 from port: OutputControlPort not handled for state: 4
2023-08-07 12:37:49.422 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap to read
2023-08-07 12:37:49.423 T:2794 info <general>: No /home/osmc/.kodi/userdata/vesa_cap to read
2023-08-07 12:37:49.423 T:2794 info <general>: Current display setting is 0192001080060.00000pstd
2023-08-07 12:37:49.423 T:2794 info <general>: Current output resolution is 0192001080060.00000pstd
2023-08-07 12:37:49.423 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2023-08-07 12:37:49.423 T:2794 info <general>: Fallback resolution at 16 + 0 00480060.00000pstd
2023-08-07 12:37:49.423 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2023-08-07 12:37:49.423 T:2794 info <general>: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2023-08-07 12:37:49.423 T:2794 info <general>: Fallback resolution at 16 + 2 00576050.00000pstd
2023-08-07 12:37:49.423 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2023-08-07 12:37:49.423 T:2794 info <general>: Fallback resolution at 16 + 3 00720050.00000pstd
2023-08-07 12:37:49.423 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2023-08-07 12:37:49.423 T:2794 info <general>: Fallback resolution at 16 + 4 00720060.00000pstd
2023-08-07 12:37:49.423 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2023-08-07 12:37:49.423 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 Hz
2023-08-07 12:37:49.423 T:2794 info <general>: Fallback resolution at 16 + 6 01080024.00000pstd
2023-08-07 12:37:49.423 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 25.000000 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Fallback resolution at 16 + 8 01080025.00000pstd
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 30.000000 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Fallback resolution at 16 + 9 01080030.00000pstd
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 29.970030 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Fallback resolution at 16 + 11 01080050.00000pstd
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Current resolution setting found at 16 + 12
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 120.000000 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 24.000000 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 23.976025 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 25.000000 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 30.000000 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 29.970030 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 24.000000 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 23.976025 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2023-08-07 12:37:49.424 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940060 Hz
2023-08-07 12:37:49.425 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2023-08-07 12:37:49.425 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940060 Hz
2023-08-07 12:37:49.425 T:2794 info <general>: Found 0192001080060.00000pstd at 28, setting to RES_DESKTOP at 16
2023-08-07 12:37:49.425 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap_3d to read
2023-08-07 12:37:49.425 T:2794 warning <general>: Update3dResolutions: No valid 3D resolutions found.
2023-08-07 12:37:49.827 T:2794 info <general>: GLES: Maximum texture width: 4096
2023-08-07 12:37:49.828 T:2899 info <general>: CActiveAESink::OpenSink - initialize sink
2023-08-07 12:37:49.828 T:2899 info <general>: CAESinkALSA::Initialize - Requested layout FL, FR
2023-08-07 12:37:49.828 T:2899 info <general>: CAESinkALSA::Initialize - set digital codec 0
2023-08-07 12:37:49.828 T:2899 info <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2023-08-07 12:37:49.829 T:2794 info <general>: Updated resolutions and set desktop
2023-08-07 12:37:49.834 T:2899 info <general>: CAESinkALSA::Initialize - Opened device "default"
2023-08-07 12:37:49.834 T:2899 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-08-07 12:37:49.835 T:2899 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-08-07 12:37:49.836 T:2899 info <general>: CAESinkALSA::Initialize - speaker layout 0
2023-08-07 12:37:49.837 T:2899 info <general>: CAESinkALSA - ALSA: pcm_hw.c:1359:(snd_pcm_hw_get_chmap) Cannot read Channel Map ctl
: Invalid argument
2023-08-07 17:04:35.015 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap to read
2023-08-07 17:04:35.015 T:2794 info <general>: No /home/osmc/.kodi/userdata/vesa_cap to read
2023-08-07 17:04:35.016 T:2794 info <general>: Current display setting is 0192001080060.00000pstd
2023-08-07 17:04:35.016 T:2794 info <general>: Current output resolution is 0192001080060.00000pstd
2023-08-07 17:04:35.016 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2023-08-07 17:04:35.016 T:2794 info <general>: Fallback resolution at 16 + 0 00480060.00000pstd
2023-08-07 17:04:35.016 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2023-08-07 17:04:35.016 T:2794 info <general>: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2023-08-07 17:04:35.016 T:2794 info <general>: Fallback resolution at 16 + 2 00576050.00000pstd
2023-08-07 17:04:35.016 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2023-08-07 17:04:35.016 T:2794 info <general>: Fallback resolution at 16 + 3 00720050.00000pstd
2023-08-07 17:04:35.016 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2023-08-07 17:04:35.016 T:2794 info <general>: Fallback resolution at 16 + 4 00720060.00000pstd
2023-08-07 17:04:35.016 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2023-08-07 17:04:35.016 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 Hz
2023-08-07 17:04:35.016 T:2794 info <general>: Fallback resolution at 16 + 6 01080024.00000pstd
2023-08-07 17:04:35.016 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 Hz
2023-08-07 17:04:35.016 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 25.000000 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Fallback resolution at 16 + 8 01080025.00000pstd
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 30.000000 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Fallback resolution at 16 + 9 01080030.00000pstd
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 29.970030 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Fallback resolution at 16 + 11 01080050.00000pstd
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Current resolution setting found at 16 + 12
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 120.000000 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 24.000000 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 23.976025 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 25.000000 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 30.000000 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 29.970030 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 24.000000 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 23.976025 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940060 Hz
2023-08-07 17:04:35.017 T:2794 info <general>: Found 0192001080060.00000pstd at 28, setting to RES_DESKTOP at 16
2023-08-07 17:04:35.018 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap_3d to read
2023-08-07 17:04:35.018 T:2794 warning <general>: Update3dResolutions: No valid 3D resolutions found.
2023-08-07 17:04:35.217 T:2794 info <general>: GLES: Maximum texture width: 4096
2023-08-07 17:04:35.218 T:2899 info <general>: CActiveAESink::OpenSink - initialize sink
2023-08-07 17:04:35.218 T:2899 info <general>: CAESinkALSA::Initialize - Requested layout FL, FR
2023-08-07 17:04:35.218 T:2899 info <general>: CAESinkALSA::Initialize - set digital codec 0
2023-08-07 17:04:35.218 T:2899 info <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2023-08-07 17:04:35.219 T:2794 info <general>: Updated resolutions and set desktop
2023-08-07 17:04:35.224 T:2899 info <general>: CAESinkALSA::Initialize - Opened device "default"
2023-08-07 17:04:35.224 T:2899 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-08-07 17:04:35.224 T:2899 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-08-07 17:04:35.226 T:2899 info <general>: CAESinkALSA::Initialize - speaker layout 0
2023-08-07 17:04:35.226 T:2899 info <general>: CAESinkALSA - ALSA: pcm_hw.c:1359:(snd_pcm_hw_get_chmap) Cannot read Channel Map ctl
: Invalid argument
2023-08-07 17:23:02.213 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap to read
2023-08-07 17:23:02.214 T:2794 info <general>: No /home/osmc/.kodi/userdata/vesa_cap to read
2023-08-07 17:23:02.215 T:2794 info <general>: Current display setting is 0192001080060.00000pstd
2023-08-07 17:23:02.215 T:2794 info <general>: Current output resolution is 0192001080060.00000pstd
2023-08-07 17:23:02.215 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2023-08-07 17:23:02.215 T:2794 info <general>: Fallback resolution at 16 + 0 00480060.00000pstd
2023-08-07 17:23:02.215 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2023-08-07 17:23:02.215 T:2794 info <general>: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2023-08-07 17:23:02.215 T:2794 info <general>: Fallback resolution at 16 + 2 00576050.00000pstd
2023-08-07 17:23:02.215 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2023-08-07 17:23:02.215 T:2794 info <general>: Fallback resolution at 16 + 3 00720050.00000pstd
2023-08-07 17:23:02.215 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2023-08-07 17:23:02.215 T:2794 info <general>: Fallback resolution at 16 + 4 00720060.00000pstd
2023-08-07 17:23:02.215 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2023-08-07 17:23:02.215 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 Hz
2023-08-07 17:23:02.215 T:2794 info <general>: Fallback resolution at 16 + 6 01080024.00000pstd
2023-08-07 17:23:02.215 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 Hz
2023-08-07 17:23:02.215 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 25.000000 Hz
2023-08-07 17:23:02.215 T:2794 info <general>: Fallback resolution at 16 + 8 01080025.00000pstd
2023-08-07 17:23:02.215 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 30.000000 Hz
2023-08-07 17:23:02.215 T:2794 info <general>: Fallback resolution at 16 + 9 01080030.00000pstd
2023-08-07 17:23:02.215 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 29.970030 Hz
2023-08-07 17:23:02.215 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2023-08-07 17:23:02.215 T:2794 info <general>: Fallback resolution at 16 + 11 01080050.00000pstd
2023-08-07 17:23:02.215 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2023-08-07 17:23:02.215 T:2794 info <general>: Current resolution setting found at 16 + 12
2023-08-07 17:23:02.215 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 Hz
2023-08-07 17:23:02.215 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 120.000000 Hz
2023-08-07 17:23:02.215 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 24.000000 Hz
2023-08-07 17:23:02.215 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 23.976025 Hz
2023-08-07 17:23:02.216 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 25.000000 Hz
2023-08-07 17:23:02.216 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 30.000000 Hz
2023-08-07 17:23:02.216 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 29.970030 Hz
2023-08-07 17:23:02.216 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 24.000000 Hz
2023-08-07 17:23:02.216 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 23.976025 Hz
2023-08-07 17:23:02.216 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2023-08-07 17:23:02.216 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2023-08-07 17:23:02.216 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2023-08-07 17:23:02.216 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2023-08-07 17:23:02.216 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2023-08-07 17:23:02.216 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
2023-08-07 17:23:02.216 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2023-08-07 17:23:02.216 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940060 Hz
2023-08-07 17:23:02.216 T:2794 info <general>: Found 0192001080060.00000pstd at 28, setting to RES_DESKTOP at 16
2023-08-07 17:23:02.216 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap_3d to read
2023-08-07 17:23:02.217 T:2794 warning <general>: Update3dResolutions: No valid 3D resolutions found.
2023-08-07 17:23:02.478 T:2899 info <general>: CActiveAESink::OpenSink - initialize sink
2023-08-07 17:23:02.478 T:2899 info <general>: CAESinkALSA::Initialize - Requested layout FL, FR
2023-08-07 17:23:02.478 T:2899 info <general>: CAESinkALSA::Initialize - set digital codec 0
2023-08-07 17:23:02.478 T:2899 info <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2023-08-07 17:23:02.484 T:2899 info <general>: CAESinkALSA::Initialize - Opened device "default"
2023-08-07 17:23:02.484 T:2899 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-08-07 17:23:02.484 T:2899 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-08-07 17:23:02.485 T:2794 info <general>: GLES: Maximum texture width: 4096
2023-08-07 17:23:02.487 T:2794 info <general>: Updated resolutions and set desktop
2023-08-07 17:23:02.488 T:2899 info <general>: CAESinkALSA::Initialize - speaker layout 0
2023-08-07 17:23:02.495 T:2899 info <general>: CAESinkALSA - ALSA: pcm_hw.c:1359:(snd_pcm_hw_get_chmap) Cannot read Channel Map ctl
: Invalid argument
2023-08-07 17:41:43.888 T:3404 info <general>: [Audio Profiles] script version 2.1.2 started
2023-08-07 17:41:43.888 T:3404 info <general>: [Audio Profiles] debug logging set to False
2023-08-07 17:41:43.889 T:3404 info <general>: [Audio Profiles] RESTORING SETTING: 2.0 (TV)
2023-08-07 17:41:43.896 T:3404 info <general>: [Audio Profiles] script version 2.1.2 stopped
2023-08-07 17:41:46.701 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap to read
2023-08-07 17:41:46.702 T:2794 info <general>: No /home/osmc/.kodi/userdata/vesa_cap to read
2023-08-07 17:41:46.702 T:2794 info <general>: Current display setting is 0192001080060.00000pstd
2023-08-07 17:41:46.703 T:2794 info <general>: Current output resolution is 0192001080060.00000pstd
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Fallback resolution at 16 + 0 00480060.00000pstd
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Fallback resolution at 16 + 2 00576050.00000pstd
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Fallback resolution at 16 + 3 00720050.00000pstd
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Fallback resolution at 16 + 4 00720060.00000pstd
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Fallback resolution at 16 + 6 01080024.00000pstd
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 25.000000 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Fallback resolution at 16 + 8 01080025.00000pstd
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 30.000000 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Fallback resolution at 16 + 9 01080030.00000pstd
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 29.970030 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Fallback resolution at 16 + 11 01080050.00000pstd
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Current resolution setting found at 16 + 12
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 120.000000 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 24.000000 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 23.976025 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 25.000000 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 30.000000 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 29.970030 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 24.000000 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 23.976025 Hz
2023-08-07 17:41:46.703 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2023-08-07 17:41:46.704 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2023-08-07 17:41:46.704 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2023-08-07 17:41:46.704 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2023-08-07 17:41:46.704 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2023-08-07 17:41:46.704 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
2023-08-07 17:41:46.704 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2023-08-07 17:41:46.704 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940060 Hz
2023-08-07 17:41:46.704 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2023-08-07 17:41:46.704 T:2794 info <general>: Found 0192001080060.00000pstd at 28, setting to RES_DESKTOP at 16
2023-08-07 17:41:46.704 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap_3d to read
2023-08-07 17:41:46.704 T:2794 warning <general>: Update3dResolutions: No valid 3D resolutions found.
2023-08-07 17:41:46.968 T:2899 info <general>: CActiveAESink::OpenSink - initialize sink
2023-08-07 17:41:46.968 T:2899 info <general>: CAESinkALSA::Initialize - Requested layout FL, FR
2023-08-07 17:41:46.968 T:2899 info <general>: CAESinkALSA::Initialize - set digital codec 0
2023-08-07 17:41:46.968 T:2899 info <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2023-08-07 17:41:46.973 T:2899 info <general>: CAESinkALSA::Initialize - Opened device "default"
2023-08-07 17:41:46.974 T:2899 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-08-07 17:41:46.974 T:2899 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-08-07 17:41:46.975 T:2794 info <general>: GLES: Maximum texture width: 4096
2023-08-07 17:41:46.976 T:2899 info <general>: CAESinkALSA::Initialize - speaker layout 0
2023-08-07 17:41:46.976 T:2899 info <general>: CAESinkALSA - ALSA: pcm_hw.c:1359:(snd_pcm_hw_get_chmap) Cannot read Channel Map ctl
: Invalid argument
2023-08-07 17:41:46.981 T:2794 info <general>: Updated resolutions and set desktop
2023-08-07 17:42:06.965 T:2794 info <general>: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
2023-08-07 17:42:07.335 T:3414 error <general>: GetDirectory - Error getting -
2023-08-07 17:42:11.925 T:2794 info <general>: Loading skin file: DialogVideoInfo.xml, load type: KEEP_IN_MEMORY
2023-08-07 17:42:37.602 T:2794 warning <general>: Skipped 1 duplicate messages..
2023-08-07 17:42:37.602 T:2794 warning <general>: CGUIWindowManager - HandleAction - ignoring action 92, because topmost modal dialog closing animation is running
2023-08-07 17:42:48.494 T:2794 info <general>: NFS is idle. Closing the remaining connections.
2023-08-07 21:30:11.440 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap to read
2023-08-07 21:30:11.440 T:2794 info <general>: No /home/osmc/.kodi/userdata/vesa_cap to read
2023-08-07 21:30:11.441 T:2794 info <general>: Current display setting is 0192001080060.00000pstd
2023-08-07 21:30:11.441 T:2794 info <general>: Current output resolution is 0192001080060.00000pstd
2023-08-07 21:30:11.441 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2023-08-07 21:30:11.441 T:2794 info <general>: Fallback resolution at 16 + 0 00480060.00000pstd
2023-08-07 21:30:11.441 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2023-08-07 21:30:11.441 T:2794 info <general>: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2023-08-07 21:30:11.441 T:2794 info <general>: Fallback resolution at 16 + 2 00576050.00000pstd
2023-08-07 21:30:11.441 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2023-08-07 21:30:11.441 T:2794 info <general>: Fallback resolution at 16 + 3 00720050.00000pstd
2023-08-07 21:30:11.441 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2023-08-07 21:30:11.441 T:2794 info <general>: Fallback resolution at 16 + 4 00720060.00000pstd
2023-08-07 21:30:11.441 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2023-08-07 21:30:11.441 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 Hz
2023-08-07 21:30:11.441 T:2794 info <general>: Fallback resolution at 16 + 6 01080024.00000pstd
2023-08-07 21:30:11.441 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 Hz
2023-08-07 21:30:11.441 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 25.000000 Hz
2023-08-07 21:30:11.441 T:2794 info <general>: Fallback resolution at 16 + 8 01080025.00000pstd
2023-08-07 21:30:11.441 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 30.000000 Hz
2023-08-07 21:30:11.441 T:2794 info <general>: Fallback resolution at 16 + 9 01080030.00000pstd
2023-08-07 21:30:11.441 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 29.970030 Hz
2023-08-07 21:30:11.441 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2023-08-07 21:30:11.441 T:2794 info <general>: Fallback resolution at 16 + 11 01080050.00000pstd
2023-08-07 21:30:11.441 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2023-08-07 21:30:11.441 T:2794 info <general>: Current resolution setting found at 16 + 12
2023-08-07 21:30:11.441 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 Hz
2023-08-07 21:30:11.441 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 120.000000 Hz
2023-08-07 21:30:11.441 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 24.000000 Hz
2023-08-07 21:30:11.442 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 23.976025 Hz
2023-08-07 21:30:11.442 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 25.000000 Hz
2023-08-07 21:30:11.442 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 30.000000 Hz
2023-08-07 21:30:11.442 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 29.970030 Hz
2023-08-07 21:30:11.442 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 24.000000 Hz
2023-08-07 21:30:11.442 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 23.976025 Hz
2023-08-07 21:30:11.442 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2023-08-07 21:30:11.442 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2023-08-07 21:30:11.442 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2023-08-07 21:30:11.442 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2023-08-07 21:30:11.442 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2023-08-07 21:30:11.442 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
2023-08-07 21:30:11.442 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2023-08-07 21:30:11.442 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940060 Hz
2023-08-07 21:30:11.442 T:2794 info <general>: Found 0192001080060.00000pstd at 28, setting to RES_DESKTOP at 16
2023-08-07 21:30:11.442 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap_3d to read
2023-08-07 21:30:11.443 T:2794 warning <general>: Update3dResolutions: No valid 3D resolutions found.
2023-08-07 21:30:11.638 T:2899 info <general>: CActiveAESink::OpenSink - initialize sink
2023-08-07 21:30:11.638 T:2899 info <general>: CAESinkALSA::Initialize - Requested layout FL, FR
2023-08-07 21:30:11.638 T:2899 info <general>: CAESinkALSA::Initialize - set digital codec 0
2023-08-07 21:30:11.638 T:2899 info <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2023-08-07 21:30:11.643 T:2899 info <general>: CAESinkALSA::Initialize - Opened device "default"
2023-08-07 21:30:11.644 T:2899 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-08-07 21:30:11.644 T:2899 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-08-07 21:30:11.638 T:2794 info <general>: GLES: Maximum texture width: 4096
2023-08-07 21:30:11.646 T:2899 info <general>: CAESinkALSA::Initialize - speaker layout 0
2023-08-07 21:30:11.646 T:2899 info <general>: CAESinkALSA - ALSA: pcm_hw.c:1359:(snd_pcm_hw_get_chmap) Cannot read Channel Map ctl
: Invalid argument
2023-08-07 21:30:11.648 T:2794 info <general>: Updated resolutions and set desktop
2023-08-07 21:30:16.911 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap to read
2023-08-07 21:30:16.912 T:2794 info <general>: No /home/osmc/.kodi/userdata/vesa_cap to read
2023-08-07 21:30:16.912 T:2794 info <general>: Current display setting is 0192001080060.00000pstd
2023-08-07 21:30:16.912 T:2794 info <general>: Current output resolution is 0192001080060.00000pstd
2023-08-07 21:30:16.912 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Fallback resolution at 16 + 0 00480060.00000pstd
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Fallback resolution at 16 + 2 00576050.00000pstd
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Fallback resolution at 16 + 3 00720050.00000pstd
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Fallback resolution at 16 + 4 00720060.00000pstd
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Fallback resolution at 16 + 6 01080024.00000pstd
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 25.000000 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Fallback resolution at 16 + 8 01080025.00000pstd
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 30.000000 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Fallback resolution at 16 + 9 01080030.00000pstd
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 29.970030 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Fallback resolution at 16 + 11 01080050.00000pstd
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Current resolution setting found at 16 + 12
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 120.000000 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 24.000000 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 23.976025 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 25.000000 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 30.000000 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 29.970030 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 24.000000 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 23.976025 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2023-08-07 21:30:16.913 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
2023-08-07 21:30:16.914 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2023-08-07 21:30:16.914 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940060 Hz
2023-08-07 21:30:16.914 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2023-08-07 21:30:16.914 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2023-08-07 21:30:16.914 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2023-08-07 21:30:16.914 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2023-08-07 21:30:16.914 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2023-08-07 21:30:16.914 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
2023-08-07 21:30:16.914 T:2794 info <general>: Found 0192001080060.00000pstd at 28, setting to RES_DESKTOP at 16
2023-08-07 21:30:16.914 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap_3d to read
2023-08-07 21:30:16.914 T:2794 warning <general>: Update3dResolutions: No valid 3D resolutions found.
2023-08-07 21:30:17.357 T:2794 info <general>: GLES: Maximum texture width: 4096
2023-08-07 21:30:17.358 T:2899 info <general>: CActiveAESink::OpenSink - initialize sink
2023-08-07 21:30:17.358 T:2899 info <general>: CAESinkALSA::Initialize - Requested layout FL, FR
2023-08-07 21:30:17.358 T:2899 info <general>: CAESinkALSA::Initialize - set digital codec 0
2023-08-07 21:30:17.358 T:2899 info <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2023-08-07 21:30:17.360 T:2794 info <general>: Updated resolutions and set desktop
2023-08-07 21:30:17.364 T:2899 info <general>: CAESinkALSA::Initialize - Opened device "default"
2023-08-07 21:30:17.364 T:2899 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-08-07 21:30:17.364 T:2899 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-08-07 21:30:17.366 T:2899 info <general>: CAESinkALSA::Initialize - speaker layout 0
2023-08-07 21:30:17.366 T:2899 info <general>: CAESinkALSA - ALSA: pcm_hw.c:1359:(snd_pcm_hw_get_chmap) Cannot read Channel Map ctl
: Invalid argument
2023-08-07 21:30:38.684 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap to read
2023-08-07 21:30:38.685 T:2794 info <general>: No /home/osmc/.kodi/userdata/vesa_cap to read
2023-08-07 21:30:38.685 T:2794 info <general>: Current display setting is 0192001080060.00000pstd
2023-08-07 21:30:38.685 T:2794 info <general>: Current output resolution is 0192001080060.00000pstd
2023-08-07 21:30:38.685 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2023-08-07 21:30:38.685 T:2794 info <general>: Fallback resolution at 16 + 0 00480060.00000pstd
2023-08-07 21:30:38.685 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2023-08-07 21:30:38.685 T:2794 info <general>: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2023-08-07 21:30:38.685 T:2794 info <general>: Fallback resolution at 16 + 2 00576050.00000pstd
2023-08-07 21:30:38.685 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Fallback resolution at 16 + 3 00720050.00000pstd
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Fallback resolution at 16 + 4 00720060.00000pstd
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Fallback resolution at 16 + 6 01080024.00000pstd
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 25.000000 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Fallback resolution at 16 + 8 01080025.00000pstd
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 30.000000 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Fallback resolution at 16 + 9 01080030.00000pstd
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 29.970030 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Fallback resolution at 16 + 11 01080050.00000pstd
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Current resolution setting found at 16 + 12
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 120.000000 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 24.000000 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 23.976025 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 25.000000 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 30.000000 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 29.970030 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 24.000000 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 23.976025 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
2023-08-07 21:30:38.686 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2023-08-07 21:30:38.687 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940060 Hz
2023-08-07 21:30:38.687 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2023-08-07 21:30:38.687 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2023-08-07 21:30:38.687 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2023-08-07 21:30:38.687 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2023-08-07 21:30:38.687 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2023-08-07 21:30:38.687 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
2023-08-07 21:30:38.687 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2023-08-07 21:30:38.687 T:2794 info <general>: Found 0192001080060.00000pstd at 28, setting to RES_DESKTOP at 16
2023-08-07 21:30:38.687 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap_3d to read
2023-08-07 21:30:38.687 T:2794 warning <general>: Update3dResolutions: No valid 3D resolutions found.
2023-08-07 21:30:39.137 T:2794 info <general>: GLES: Maximum texture width: 4096
2023-08-07 21:30:39.138 T:2899 info <general>: CActiveAESink::OpenSink - initialize sink
2023-08-07 21:30:39.138 T:2899 info <general>: CAESinkALSA::Initialize - Requested layout FL, FR
2023-08-07 21:30:39.138 T:2899 info <general>: CAESinkALSA::Initialize - set digital codec 0
2023-08-07 21:30:39.138 T:2899 info <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2023-08-07 21:30:39.140 T:2794 info <general>: Updated resolutions and set desktop
2023-08-07 21:30:39.144 T:2899 info <general>: CAESinkALSA::Initialize - Opened device "default"
2023-08-07 21:30:39.144 T:2899 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-08-07 21:30:39.145 T:2899 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-08-07 21:30:39.146 T:2899 info <general>: CAESinkALSA::Initialize - speaker layout 0
2023-08-07 21:30:39.147 T:2899 info <general>: CAESinkALSA - ALSA: pcm_hw.c:1359:(snd_pcm_hw_get_chmap) Cannot read Channel Map ctl
: Invalid argument
2023-08-08 03:13:34.906 T:2935 error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/auto.master.d/
2023-08-08 16:06:51.292 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap to read
2023-08-08 16:06:51.294 T:2794 info <general>: No /home/osmc/.kodi/userdata/vesa_cap to read
2023-08-08 16:06:51.294 T:2794 info <general>: Current display setting is 0192001080060.00000pstd
2023-08-08 16:06:51.294 T:2794 info <general>: Current output resolution is 0192001080060.00000pstd
2023-08-08 16:06:51.294 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2023-08-08 16:06:51.294 T:2794 info <general>: Fallback resolution at 16 + 0 00480060.00000pstd
2023-08-08 16:06:51.294 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2023-08-08 16:06:51.294 T:2794 info <general>: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2023-08-08 16:06:51.294 T:2794 info <general>: Fallback resolution at 16 + 2 00576050.00000pstd
2023-08-08 16:06:51.294 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2023-08-08 16:06:51.294 T:2794 info <general>: Fallback resolution at 16 + 3 00720050.00000pstd
2023-08-08 16:06:51.294 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2023-08-08 16:06:51.294 T:2794 info <general>: Fallback resolution at 16 + 4 00720060.00000pstd
2023-08-08 16:06:51.294 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Fallback resolution at 16 + 6 01080024.00000pstd
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 25.000000 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Fallback resolution at 16 + 8 01080025.00000pstd
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 30.000000 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Fallback resolution at 16 + 9 01080030.00000pstd
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 29.970030 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Fallback resolution at 16 + 11 01080050.00000pstd
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Current resolution setting found at 16 + 12
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 120.000000 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 24.000000 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 23.976025 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 25.000000 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 30.000000 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 29.970030 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 24.000000 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 23.976025 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
2023-08-08 16:06:51.295 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2023-08-08 16:06:51.296 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940060 Hz
2023-08-08 16:06:51.296 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2023-08-08 16:06:51.296 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2023-08-08 16:06:51.296 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2023-08-08 16:06:51.296 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2023-08-08 16:06:51.296 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2023-08-08 16:06:51.296 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
2023-08-08 16:06:51.296 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2023-08-08 16:06:51.296 T:2794 info <general>: Found 0192001080060.00000pstd at 28, setting to RES_DESKTOP at 16
2023-08-08 16:06:51.296 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap_3d to read
2023-08-08 16:06:51.296 T:2794 warning <general>: Update3dResolutions: No valid 3D resolutions found.
2023-08-08 16:06:51.498 T:2794 info <general>: GLES: Maximum texture width: 4096
2023-08-08 16:06:51.498 T:2899 info <general>: CActiveAESink::OpenSink - initialize sink
2023-08-08 16:06:51.498 T:2899 info <general>: CAESinkALSA::Initialize - Requested layout FL, FR
2023-08-08 16:06:51.498 T:2899 info <general>: CAESinkALSA::Initialize - set digital codec 0
2023-08-08 16:06:51.498 T:2899 info <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2023-08-08 16:06:51.501 T:2794 info <general>: Updated resolutions and set desktop
2023-08-08 16:06:51.512 T:2899 info <general>: CAESinkALSA::Initialize - Opened device "default"
2023-08-08 16:06:51.513 T:2899 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-08-08 16:06:51.513 T:2899 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-08-08 16:06:51.515 T:2899 info <general>: CAESinkALSA::Initialize - speaker layout 0
2023-08-08 16:06:51.515 T:2899 info <general>: CAESinkALSA - ALSA: pcm_hw.c:1359:(snd_pcm_hw_get_chmap) Cannot read Channel Map ctl
: Invalid argument
2023-08-08 16:07:00.235 T:4482 info <general>: [Audio Profiles] script version 2.1.2 started
2023-08-08 16:07:00.235 T:4482 info <general>: [Audio Profiles] debug logging set to False
2023-08-08 16:07:00.238 T:4482 info <general>: [Audio Profiles] RESTORING SETTING: 2.0 (TV)
2023-08-08 16:07:00.244 T:4482 info <general>: [Audio Profiles] script version 2.1.2 stopped
2023-08-08 16:07:13.805 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap to read
2023-08-08 16:07:13.805 T:2794 info <general>: No /home/osmc/.kodi/userdata/vesa_cap to read
2023-08-08 16:07:13.806 T:2794 info <general>: Current display setting is 0192001080060.00000pstd
2023-08-08 16:07:13.806 T:2794 info <general>: Current output resolution is 0192001080060.00000pstd
2023-08-08 16:07:13.806 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2023-08-08 16:07:13.806 T:2794 info <general>: Fallback resolution at 16 + 0 00480060.00000pstd
2023-08-08 16:07:13.806 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2023-08-08 16:07:13.806 T:2794 info <general>: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2023-08-08 16:07:13.806 T:2794 info <general>: Fallback resolution at 16 + 2 00576050.00000pstd
2023-08-08 16:07:13.806 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2023-08-08 16:07:13.806 T:2794 info <general>: Fallback resolution at 16 + 3 00720050.00000pstd
2023-08-08 16:07:13.806 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2023-08-08 16:07:13.806 T:2794 info <general>: Fallback resolution at 16 + 4 00720060.00000pstd
2023-08-08 16:07:13.806 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2023-08-08 16:07:13.806 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 Hz
2023-08-08 16:07:13.806 T:2794 info <general>: Fallback resolution at 16 + 6 01080024.00000pstd
2023-08-08 16:07:13.806 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 Hz
2023-08-08 16:07:13.806 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 25.000000 Hz
2023-08-08 16:07:13.806 T:2794 info <general>: Fallback resolution at 16 + 8 01080025.00000pstd
2023-08-08 16:07:13.806 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 30.000000 Hz
2023-08-08 16:07:13.806 T:2794 info <general>: Fallback resolution at 16 + 9 01080030.00000pstd
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 29.970030 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Fallback resolution at 16 + 11 01080050.00000pstd
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Current resolution setting found at 16 + 12
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 120.000000 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 24.000000 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 23.976025 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 25.000000 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 30.000000 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 29.970030 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 24.000000 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 23.976025 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940060 Hz
2023-08-08 16:07:13.807 T:2794 info <general>: Found 0192001080060.00000pstd at 28, setting to RES_DESKTOP at 16
2023-08-08 16:07:13.808 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap_3d to read
2023-08-08 16:07:13.808 T:2794 warning <general>: Update3dResolutions: No valid 3D resolutions found.
2023-08-08 16:07:14.208 T:2899 info <general>: CActiveAESink::OpenSink - initialize sink
2023-08-08 16:07:14.208 T:2899 info <general>: CAESinkALSA::Initialize - Requested layout FL, FR
2023-08-08 16:07:14.208 T:2899 info <general>: CAESinkALSA::Initialize - set digital codec 0
2023-08-08 16:07:14.208 T:2899 info <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2023-08-08 16:07:14.208 T:2794 info <general>: GLES: Maximum texture width: 4096
2023-08-08 16:07:14.210 T:2794 info <general>: Updated resolutions and set desktop
2023-08-08 16:07:14.214 T:2899 info <general>: CAESinkALSA::Initialize - Opened device "default"
2023-08-08 16:07:14.214 T:2899 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-08-08 16:07:14.214 T:2899 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-08-08 16:07:14.216 T:2899 info <general>: CAESinkALSA::Initialize - speaker layout 0
2023-08-08 16:07:14.217 T:2899 info <general>: CAESinkALSA - ALSA: pcm_hw.c:1359:(snd_pcm_hw_get_chmap) Cannot read Channel Map ctl
: Invalid argument
2023-08-08 16:46:20.165 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap to read
2023-08-08 16:46:20.166 T:2794 info <general>: No /home/osmc/.kodi/userdata/vesa_cap to read
2023-08-08 16:46:20.166 T:2794 info <general>: Current display setting is 0192001080060.00000pstd
2023-08-08 16:46:20.166 T:2794 info <general>: Current output resolution is 0192001080060.00000pstd
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Fallback resolution at 16 + 0 00480060.00000pstd
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Fallback resolution at 16 + 2 00576050.00000pstd
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Fallback resolution at 16 + 3 00720050.00000pstd
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Fallback resolution at 16 + 4 00720060.00000pstd
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Fallback resolution at 16 + 6 01080024.00000pstd
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 25.000000 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Fallback resolution at 16 + 8 01080025.00000pstd
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 30.000000 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Fallback resolution at 16 + 9 01080030.00000pstd
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 29.970030 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Fallback resolution at 16 + 11 01080050.00000pstd
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Current resolution setting found at 16 + 12
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1920 x 1080 with 1920 x 1080 @ 120.000000 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 24.000000 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 23.976025 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 25.000000 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 30.000000 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1920 x 1080 with 3840 x 2160 @ 29.970030 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 24.000000 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 1920 x 1080 with 4096 x 2160 @ 23.976025 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2023-08-08 16:46:20.167 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2023-08-08 16:46:20.168 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2023-08-08 16:46:20.168 T:2794 info <general>: Found resolution 800 x 600 with 800 x 600 @ 59.940060 Hz
2023-08-08 16:46:20.168 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2023-08-08 16:46:20.168 T:2794 info <general>: Found resolution 1024 x 768 with 1024 x 768 @ 59.940060 Hz
2023-08-08 16:46:20.168 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2023-08-08 16:46:20.168 T:2794 info <general>: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940060 Hz
2023-08-08 16:46:20.168 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2023-08-08 16:46:20.168 T:2794 info <general>: Found resolution 640 x 480 with 640 x 480 @ 59.940060 Hz
2023-08-08 16:46:20.168 T:2794 info <general>: Found 0192001080060.00000pstd at 28, setting to RES_DESKTOP at 16
2023-08-08 16:46:20.168 T:2794 info <general>: No /home/osmc/.kodi/userdata/disp_cap_3d to read
2023-08-08 16:46:20.168 T:2794 warning <general>: Update3dResolutions: No valid 3D resolutions found.
2023-08-08 16:46:20.368 T:2899 info <general>: CActiveAESink::OpenSink - initialize sink
2023-08-08 16:46:20.368 T:2794 info <general>: GLES: Maximum texture width: 4096
2023-08-08 16:46:20.368 T:2899 info <general>: CAESinkALSA::Initialize - Requested layout FL, FR
2023-08-08 16:46:20.368 T:2899 info <general>: CAESinkALSA::Initialize - set digital codec 0
2023-08-08 16:46:20.369 T:2899 info <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2023-08-08 16:46:20.370 T:2794 info <general>: Updated resolutions and set desktop
2023-08-08 16:46:20.374 T:2899 info <general>: CAESinkALSA::Initialize - Opened device "default"
2023-08-08 16:46:20.375 T:2899 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-08-08 16:46:20.375 T:2899 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-08-08 16:46:20.377 T:2899 info <general>: CAESinkALSA::Initialize - speaker layout 0
2023-08-08 16:46:20.377 T:2899 info <general>: CAESinkALSA - ALSA: pcm_hw.c:1359:(snd_pcm_hw_get_chmap) Cannot read Channel Map ctl
: Invalid argument
2023-08-09 03:13:51.139 T:2935 error <general>: GetDirectory - Error getting /home/osmc/.kodi/userdata/auto.master.d/
Please upload logs via MyOSMC or grab-logs in these posts it is hard to read and no context
