I enjoyed my Vero 4k since april 2017, and did an upgrade to the Vero 4k+. The new unit got set up and I enjoyed it for a few days when suddenly it wasn’t available when I wanted to use it. Black screen. Did a reboot, it worked again and I used it some more. After a few days it was locked up again, and this has repeated itself many times.
I started digging into this today, after a few minutes I was finally able to login via ssh. Everything runs really slow, the memory is mostly gone. Kswapd0 uses most of the CPU. No processes use any memory, ps aux shows 0,0% mem usage on every process. I can’t kill kswapd0 since it’s run by the kernel.
free -m:
osmc@Osmc:~$ free -m
total used free shared buff/cache available
Mem: 1788 1647 44 88 96 8
Swap: 0 0 0
ps aux:
osmc@Osmc:~$ ps aux | sort -nk +5
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
osmc 576 7.3 0.0 0 0 ? Zl Mar16 540:48 [kodi.bin] <defunct>
root 2 0.0 0.0 0 0 ? S Mar16 0:00 [kthreadd]
root 3 0.0 0.0 0 0 ? S Mar16 0:51 [ksoftirqd/0]
root 7 0.0 0.0 0 0 ? S Mar16 6:18 [rcu_sched]
root 8 0.0 0.0 0 0 ? S Mar16 0:00 [rcu_bh]
root 9 0.0 0.0 0 0 ? S Mar16 0:00 [migration/0]
root 10 0.0 0.0 0 0 ? S Mar16 0:00 [migration/1]
root 11 0.0 0.0 0 0 ? S Mar16 0:31 [ksoftirqd/1]
root 13 0.0 0.0 0 0 ? S< Mar16 0:00 [kworker/1:0H]
root 14 0.0 0.0 0 0 ? S Mar16 0:01 [migration/2]
root 15 0.0 0.0 0 0 ? S Mar16 0:24 [ksoftirqd/2]
root 17 0.0 0.0 0 0 ? S< Mar16 0:00 [kworker/2:0H]
root 18 0.0 0.0 0 0 ? S Mar16 0:00 [migration/3]
root 19 0.0 0.0 0 0 ? S Mar16 0:17 [ksoftirqd/3]
root 21 0.0 0.0 0 0 ? S< Mar16 0:00 [kworker/3:0H]
root 22 0.0 0.0 0 0 ? S< Mar16 0:00 [khelper]
root 23 0.0 0.0 0 0 ? S Mar16 0:00 [kdevtmpfs]
root 24 0.0 0.0 0 0 ? S< Mar16 0:00 [netns]
root 25 0.0 0.0 0 0 ? S< Mar16 0:00 [suspend]
root 26 0.0 0.0 0 0 ? S< Mar16 0:00 [writeback]
root 27 0.0 0.0 0 0 ? S< Mar16 0:00 [bioset]
root 28 0.0 0.0 0 0 ? S< Mar16 0:00 [crypto]
root 29 0.0 0.0 0 0 ? S< Mar16 0:00 [kblockd]
root 30 0.0 0.0 0 0 ? S Mar16 0:00 [khubd]
root 34 0.0 0.0 0 0 ? S< Mar16 0:00 [devfreq_wq]
root 36 0.0 0.0 0 0 ? S Mar16 0:00 [gp_pll]
root 38 0.0 0.0 0 0 ? S< Mar16 0:00 [rpciod]
root 39 33.8 0.0 0 0 ? R Mar16 2505:58 [kswapd0]
root 40 0.0 0.0 0 0 ? S Mar16 0:00 [fsnotify_mark]
root 41 0.0 0.0 0 0 ? S< Mar16 0:00 [nfsiod]
root 42 0.0 0.0 0 0 ? S< Mar16 0:00 [cifsiod]
root 56 0.0 0.0 0 0 ? S< Mar16 0:00 [kthrotld]
root 57 0.0 0.0 0 0 ? S< Mar16 0:00 [iscsi_eh]
root 58 0.0 0.0 0 0 ? S< Mar16 0:00 [eth_moniter_tx_]
root 59 0.0 0.0 0 0 ? S< Mar16 0:00 [stmmac_wq]
root 64 0.0 0.0 0 0 ? S< Mar16 0:00 [dm_bufio_cache]
root 65 0.0 0.0 0 0 ? S< Mar16 0:00 [kmpathd]
root 66 0.0 0.0 0 0 ? S< Mar16 0:00 [kmpath_handlerd]
root 67 0.0 0.0 0 0 ? S Mar16 0:42 [kthread_hdcp]
root 68 1.0 0.0 0 0 ? S Mar16 80:29 [irq/250-sd_emmc]
root 70 0.0 0.0 0 0 ? S Mar16 0:00 [irq/249-sd_emmc]
root 71 0.0 0.0 0 0 ? S Mar16 0:00 [irq/99-sd_in]
root 72 0.0 0.0 0 0 ? S Mar16 0:00 [irq/101-sd_out]
root 73 0.0 0.0 0 0 ? S Mar16 0:00 [irq/248-sd_emmc]
root 79 0.0 0.0 0 0 ? S Mar16 0:00 [vmalloc_ion]
root 80 0.0 0.0 0 0 ? S Mar16 0:00 [codec_mm_ion]
root 81 0.0 0.0 0 0 ? S Mar16 0:00 [carveout_ion]
root 82 2.8 0.0 0 0 ? R Mar16 210:29 [mmcqd/0]
root 84 0.0 0.0 0 0 ? S Mar16 0:00 [mmcqd/0boot0]
root 85 0.0 0.0 0 0 ? S Mar16 0:00 [mmcqd/0boot1]
root 86 0.0 0.0 0 0 ? S Mar16 0:00 [mmcqd/0rpmb]
root 87 0.0 0.0 0 0 ? S Mar16 0:00 [ge2d_monitor]
root 88 0.0 0.0 0 0 ? S< Mar16 0:00 [gpio_pwm_wq]
root 89 0.0 0.0 0 0 ? S Mar16 0:39 [irq/76-vdec-1]
root 90 0.1 0.0 0 0 ? D Mar16 8:14 [vdec-core]
root 91 0.0 0.0 0 0 ? S Mar16 0:00 [irq/35-vsync]
root 92 0.0 0.0 0 0 ? S Mar16 5:14 [kthread_di]
root 93 0.0 0.0 0 0 ? S< Mar16 0:00 [cec_work]
root 95 0.0 0.0 0 0 ? S< Mar16 0:00 [ipv6_addrconf]
root 96 0.0 0.0 0 0 ? S< Mar16 0:00 [deferwq]
root 115 0.0 0.0 0 0 ? S< Mar16 0:00 [kdmflush]
root 116 0.0 0.0 0 0 ? S< Mar16 0:00 [bioset]
root 128 0.0 0.0 0 0 ? S< Mar16 0:00 [kworker/1:1H]
root 131 0.0 0.0 0 0 ? S Mar16 0:02 [jbd2/dm-0-8]
root 132 0.0 0.0 0 0 ? S< Mar16 0:00 [ext4-rsv-conver]
root 184 0.0 0.0 0 0 ? S< Mar16 0:00 [kworker/3:1H]
root 191 0.0 0.0 0 0 ? S Mar16 0:00 [rc0]
root 192 0.0 0.0 0 0 ? S< Mar16 0:00 [kworker/u9:0]
root 261 0.0 0.0 0 0 ? S< Mar16 0:15 [kworker/2:1H]
root 357 0.0 0.0 0 0 ? S< Mar16 0:00 [cfg80211]
root 578 0.0 0.0 0 0 ? S Mar16 0:00 [wl_event_handle]
root 579 0.0 0.0 0 0 ? S Mar16 0:00 [dhd_watchdog_th]
root 580 0.0 0.0 0 0 ? S Mar16 0:00 [dhd_dpc]
root 581 0.0 0.0 0 0 ? S Mar16 0:00 [dhd_rxf]
root 1024 0.0 0.0 0 0 ? S< Mar21 0:00 [kworker/0:1H]
root 1068 0.0 0.0 0 0 ? S Mar17 0:00 [ppmgr]
root 1072 0.0 0.0 0 0 ? ZN Mar17 0:00 [sudo] <defunct>
root 1223 0.0 0.0 0 0 ? S< Mar21 0:00 [kworker/0:0H]
root 1821 0.2 0.0 0 0 ? S 00:57 0:08 [kworker/1:0]
root 1848 0.1 0.0 0 0 ? S 01:00 0:04 [kworker/2:0]
root 1997 0.0 0.0 0 0 ? S 01:13 0:00 [kworker/u8:0]
root 2269 0.1 0.0 0 0 ? S 01:52 0:01 [kworker/0:0]
root 2271 0.0 0.0 0 0 ? S 01:53 0:00 [kworker/3:0]
root 2293 0.0 0.0 0 0 ? S 01:58 0:00 [kworker/3:2]
root 2302 0.0 0.0 0 0 ? S 02:01 0:00 [kworker/1:2]
root 2313 0.0 0.0 0 0 ? S 02:02 0:00 [kworker/2:2]
root 2314 0.0 0.0 0 0 ? S 02:02 0:00 [kworker/0:1]
root 2325 0.0 0.0 0 0 ? S 02:06 0:00 [kworker/1:1]
root 2328 0.2 0.0 0 0 ? S 02:07 0:00 [kworker/0:2]
root 2329 0.0 0.0 0 0 ? S 02:07 0:00 [kworker/2:1]
root 2715 0.0 0.0 0 0 ? S Mar16 0:00 [irq/64-parser]
root 2716 0.0 0.0 0 0 ? S< Mar16 0:00 [threadrw]
root 5460 0.0 0.0 0 0 ? S< Mar16 0:00 [codec_mm_sc]
root 5465 0.0 0.0 0 0 ? S< Mar16 0:00 [kthread_h265]
root 28870 0.0 0.0 0 0 ? S Mar21 0:00 [kworker/u8:2]
root 390 0.0 0.0 1776 116 ? Ss Mar16 0:05 /usr/sbin/lircd --driver=default --device=/dev/lirc0 --uinput --output=/var/run/lirc/lircd-lirc0 --pidfile=/var/run/lirc/lircd-lirc0.pid /etc/lirc/lircd.conf
root 430 0.0 0.0 1820 108 ttyS0 Ss+ Mar16 0:00 /sbin/agetty --keep-baud 115200,38400,9600 ttyS0 vt220
root 382 0.0 0.0 2016 192 ? Ss Mar16 0:00 /usr/sbin/eventlircd --evmap=/etc/eventlircd.d --socket=/var/run/lirc/lircd --repeat-filter --release=_UP -f
root 419 0.0 0.0 2764 268 ? Ss Mar16 0:00 /bin/bash /usr/bin/mediacenter
osmc 2218 0.3 0.0 2884 400 pts/0 Ss 01:42 0:05 -bash
osmc 2326 10.3 0.0 5036 528 pts/0 R+ 02:07 0:03 ps aux
avahi 380 0.0 0.0 5192 288 ? S Mar16 0:00 avahi-daemon: chroot helper
avahi 365 1.3 0.0 5324 408 ? Ss Mar16 102:50 avahi-daemon: running [Osmc.local]
message+ 366 0.9 0.0 5448 540 ? Ss Mar16 71:36 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
root 567 0.0 0.0 5644 332 ? S Mar16 0:00 sudo -u osmc /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /var/run/lirc/lircd
root 203 0.0 0.0 5788 368 ? Ss Mar16 0:12 /sbin/rpcbind -f -w
root 374 0.2 0.0 6056 420 ? Ss Mar16 17:53 /lib/systemd/systemd-logind
ntp 909 0.3 0.0 6984 436 ? Ssl Mar16 27:30 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 105:107
osmc 594 0.0 0.0 7728 488 ? Ss Mar16 0:00 /usr/bin/udisks-glue --foreground
root 547 0.0 0.0 7756 380 ? Ss Mar16 0:00 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
osmc 2327 0.3 0.0 7832 80 pts/0 S+ 02:07 0:00 sort -nk +5
root 480 0.0 0.0 8488 536 ? Ss Mar16 0:00 /usr/sbin/sshd -D
root 375 0.0 0.0 8936 572 ? Ss Mar16 0:00 /usr/sbin/connmand -n --nodnsproxy --config=/etc/connman.conf
root 2169 1.1 0.0 9644 696 ? Ss 01:36 0:21 sshd: osmc [priv]
osmc 2213 0.2 0.0 9776 740 ? S 01:42 0:03 sshd: osmc@pts/0
root 1 2.6 0.0 25336 1036 ? Ds Mar16 193:53 /sbin/init
Note that I killed a few processes trying to get back control and maybe reboot this thing. No go, I can’t even reboot:
shutdown -r now:
Failed to set wall message, ignoring: Connection timed out
Failed to reboot system via logind: Connection timed out
Failed to open /dev/initctl: Permission denied
Failed to talk to init daemon."
sudo shutdown -r now doesn’t do anything:
osmc@Osmc:~$ sudo shutdown -r now
osmc@Osmc:~$
Now what?
