Lately I’m having a lot of embuary info errors. The errors start a few hours after rebooting and keep coming until de vero crashes and reboots.
I tried to make a log, but could not reproduce the error while the logging was running. After a while the errors started again and altough the logging was not running I still found the error in the kodi.log
I used the log uploader and got URL: https://paste.osmc.tv/ zolufidari. I hope this is correct and the upload has the error in it.
2023-02-16 21:56:32.042 T:4018 ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <class 'AttributeError'>
Error Contents: 'datetime.timedelta' object has no attribute 'timestamp'
File "/home/osmc/.kodi/addons/script.embuary.info/default.py", line 7, in <module>
from resources.lib.helper import *
File "/home/osmc/.kodi/addons/script.embuary.info/resources/lib/helper.py", line 15, in <module>
import arrow
File "/home/osmc/.kodi/addons/script.module.arrow/lib/arrow/__init__.py", line 2, in <module>
from .api import get, now, utcnow
File "/home/osmc/.kodi/addons/script.module.arrow/lib/arrow/api.py", line 12, in <module>
from arrow.arrow import TZ_EXPR, Arrow
File "/home/osmc/.kodi/addons/script.module.arrow/lib/arrow/arrow.py", line 34, in <module>
from arrow import formatter, locales, parser, util
File "/home/osmc/.kodi/addons/script.module.arrow/lib/arrow/parser.py", line 26, in <module>
from arrow.util import next_weekday, normalize_timestamp
File "/home/osmc/.kodi/addons/script.module.arrow/lib/arrow/util.py", line 6, in <module>
from arrow.constants import (
File "/home/osmc/.kodi/addons/script.module.arrow/lib/arrow/constants.py", line 16, in <module>
_MAX_TIMESTAMP = datetime.max.timestamp()
AttributeError: 'datetime.timedelta' object has no attribute 'timestamp'
-->End of Python script error report<--
But I’m not sure what the solution is. Perhaps you could contact the developer of these add-ons / skin and see if they have some advice.
