Vero 4K+ grinding to a halt during playback
I’ve had a problem a few times now, where my Vero 4K+ has spontaneously stopped during playback. The video seems to slow right down to just a few frames per second and then finally stop altogether, and the box becomes unresponsive. Sometimes it recovers, sometimes I have to reboot.
I’ve attempted to capture some logs, although that wasn’t easy, as the issue happens unpredictably:
https://paste.osmc.tv/lonoxigoxo
Any suggestions?
You seem to be on the staging repository or have used it very recently.
This is not currently stable.
Yeah, I was trying out the Java blu ray menus thing. I deactivated staging after installing that (a few weeks ago, I think) - would it be a good idea to turn staging back on?
You’ll need to wait for it to become stable again or reinstall.
Okay, I reinstalled, and I’m still getting what looks like the same problem. I didn’t have debug logging enabled this time, but here are some logs anyway:
https://paste.osmc.tv/jewapeyici
(Note that the previous logs posted higher up the thread were debug-enabled, so they may be more useful).
So, any thoughts, @sam_nazarko ?
Did you try a fresh install without restoring from backup?
Did you check playback from local storage?
Yes. It was still crashing.
No. I’ll give that a try, but I’m not sure how informative that will be, given that the crashes happen unpredictably - sometimes things play through without any problems. So if something plays correctly from local storage that might just be a coincidence.
