Vero 4K is crashing randomly during idle
Hi everyone,
I currently have a problem with my V4K. Quite often while the device is idling (usually over night, but also often during the days) it “crashes”. This happens several times a day with varying frequencies and includes:
  • No output on HDMI3 (where it is connected)
  • No SSH to the device possible
  • Kodi showing as “Offline” in Yatse app
  • Soundbar Sound+CEC not working anymore
I can fix this by replugging the device power cable. As soon as the V4K boots back up again the soundbar is recognized by the TV and all the CEC is working again. The problem with the CEC is caused by the V4K crashing, while it’s running, everything is working fine.
There were no such problems before (using the V4K since release) and I did not change anything since the problems occur (no new addons, no updates, etc.)
Log-Output:
osmc@Vero4K:~$ grab-logs -A
Logs successfully uploaded.
Logs available at https://paste.osmc.tv/lujekihebu
When running sudo journalctl, there is some “red” (see bold below) output, mostly stuff like:
Jan 02 23:11:14 Vero4K kernel: aml_audio_hw: IEC958 PCM32
Jan 02 23:11:14 Vero4K kernel: hdmitx: audio: aout notify rate 44100
Jan 02 23:11:14 Vero4K kernel: hdmitx: audio: aout notify size 32
Jan 02 23:11:14 Vero4K kernel: hdmitx: audio: no update
Jan 02 23:11:14 Vero4K kernel: aml_snd_m8_card aml_m8_snd.46: i2s/958 same source
Jan 02 23:11:14 Vero4K kernel: channel count should be 8, we got 2 aborting
Jan 02 23:11:14 Vero4K kernel: aml_snd_m8_card aml_m8_snd.46: I2S playback enable
Jan 02 23:11:14 Vero4K kernel: aml_snd_m8_card aml_m8_snd.46: IEC958 playback enable
Jan 04 14:51:44 Vero4K systemd[1]: Time has been changed
Jan 04 14:51:44 Vero4K http-time[403]: Updated time from Tue Jan 2 22:11:16 UTC 2018 to Thu Jan 4 13:51:44 UTC 2018 using HTTP query to www.google.com
Jan 04 14:51:44 Vero4K systemd[1]: Started Set Time using HTTP query.
Jan 04 14:51:44 Vero4K systemd[1]: Starting LSB: Start NTP daemon…
Jan 04 14:51:44 Vero4K ntpd[819]: ntpd 4.2.6p5@1.2349-o Fri Jul 22 17:59:22 UTC 2016 (1)
Jan 04 14:51:44 Vero4K ntpd[820]: proto: precision = 0.416 usec
Jan 04 14:51:44 Vero4K systemd[1]: Started LSB: Start NTP daemon.
Notice the abrupt ending of the logs after the error. But this should also be visible in the output of grab-logs -A
Do any of you have similar problems, an idea of what is happening or maybe even a fix? If I can provide any more logs, I’d be happy to.
Thanks and best regards.
Looks like the network might be dropping.
This can be enough to freeze Kodi sometimes, but shouldn’t cause the device to become unresponsive via SSH unless the network is completely down.
Is it connected via WiFi?
Hi Sam,
no, the device is connected through gigabit ethernet, through a switch to the router.
If you’re referring to the lost connection via NFS, this is because I usually switch off my NAS when it’s not in use.
Wasn’t a problem in the past though…
Expected.
It may be unrelated, but I’ve just had similar symptoms trying play music from NAS. Total lock-up and loss of ssh. Kodi.old.log full of nulls at the end. I think there may have been a network hiccup while the Music Library was updating. I deleted the database and re-scanned and so far so good now. (Library is on vero, not MySQL).
Indeed, some kind of network problem.
eth0      Link encap:Ethernet  HWaddr c4:4e:ac:0a:ee:fd
          inet addr:192.168.196.60  Bcast:192.168.196.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST DYNAMIC  MTU:1500  Metric:1
          RX packets:2026 errors:0 dropped:195 overruns:0 frame:0
          TX packets:549 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:648697 (633.4 KiB)  TX bytes:61932 (60.4 KiB)
          Interrupt:40
195 RX packets dropped.
Jan 04 14:51:52 Vero4K mediacenter[408]: PING 192.168.196.50 (192.168.196.50): 56 data bytes
Jan 04 14:51:52 Vero4K mediacenter[408]: --- 192.168.196.50 ping statistics ---
Jan 04 14:51:52 Vero4K mediacenter[408]: 1 packets transmitted, 0 packets received, 100% packet loss
Jan 04 14:51:53 Vero4K mediacenter[408]: PING 192.168.196.50 (192.168.196.50): 56 data bytes
Jan 04 14:51:53 Vero4K mediacenter[408]: 64 bytes from 192.168.196.50: seq=0 ttl=64 time=1000.006 ms
Jan 04 14:51:53 Vero4K mediacenter[408]: --- 192.168.196.50 ping statistics ---
Jan 04 14:51:53 Vero4K mediacenter[408]: 1 packets transmitted, 1 packets received, 0% packet loss
Jan 04 14:51:53 Vero4K mediacenter[408]: round-trip min/avg/max = 1000.006/1000.006/1000.006 ms
Jan 04 14:51:53 Vero4K mediacenter[408]: 64 bytes from 192.168.196.50: seq=0 ttl=64 time=739.863 ms
Jan 04 14:51:53 Vero4K mediacenter[408]: round-trip min/avg/max = 739.863/739.863/739.863 ms
Dropped packets and a 1-second ping time on your local network.
I see you’re using Kodi for NFS. I’d recommend you move to /etc/fstab. It performs better and might be more resilient when the network plays up.
Do you think this could cause such crashes? .50 is the IP of my NAS and while those drops are happening, the NAS was probably in sleep/switched off.
How would I set up /etc/fstab? Willing to give it a try.
Am I still able to wake up the NAS (192.168.196.50) through WOL with fstab? Because this is usually how I do it:
  1. NAS on sleep
  2. WOL through Kodi/V4K
  3. Watch
  4. When finished watching send NAS to sleep again.
The V4K is currently crashed yet again, getting a timeout through SSH :frowning:
Network is running though (GF is watching Netflix through App on TV, V4K + TV are hooked up to the same switch).
What is irritating to me is that this setup was running since V4K release without a flaw, before that I had it running on a RasPi and RaspBMC - also without a problem and the exact same config (NFS, WOL, etc.)
Edit:
New logs: https://paste.osmc.tv/revegobici - Crash happened during the opening of this post and right now. NAS was switched off during this period (it is turned on via WOL when booting the V4K, but I usually send it to sleep again directly after)
Another edit:
Is there an option to somehow tail the relevant log? I can let the tail run in the background from my computer until it crashes again. Does it help to enable debug logging beforehand?
The log doesn’t really show any issues unfortunately.
Persistent logging might give some clues.
How would I turn this on?
Also please see above:
FWIW, I also ran a Library cleanup since some of the freezes (also what @grahamh said) seem to be related to the Library (although everything “automatic” [e.g. refresh etc.) using the library is turned off on my side)
watch sudo journalctl might give clues.
I can’t say definitely it will or won’t cause a crash, but it’s a simple thing to change and there’s at least a chance it will help.
How does it explain the ping times of 1000 and 739 ms?
To enable a persistent system journal run:
sudo mkdir /var/log/journal
sudo systemctl restart systemd-journald
Thanks, I ran both commands you sent and am doing the watch in parallel, only problem is that I cannot scroll in the “watch” terminal, neither in Putty nor in Termius.
Regarding the ping times:
You’re right, up to 1s is weird - misread that as 1s until the timeout.
I currently have no explanation for this, since everything directly on the TV (Netflix etc.) and streaming on the Vero is running without a flaw all the time. Maybe it has something to do with the QoS on the switch (Netflix 4K streaming takes up all the bandwidth, no idea…)
Try sudo journalctl -f
Do you have a Smart TV on the network? Try disconnecting it temporarily from the network.
Yes, it’s a Sony Android TV, but I had it longer than the V4K and there also were no recent updates done on it. I will try this later on.
For now I will tail the logs (sudo journalctl -f is working, thx @dillthedog) and let the persistent system journal run as well.
Maybe the library cleanup fixed the problem? So far it’s running stable.
Edit:
AAAAND scratch that. It crashed, my terminal closed and gave me this:
What can I do with the persistent system journal now?
I ran these commands beforehand:
Sorry for doubleposting, I did some more testing.
I ran a ping from my PC to the Vero and at the same time to the TV. I got some timeouts when Netflix was streaming on the TV, but other than that the network is looking fine. So I’d give this to the QoS of my switches:
Results:
PC → Vero:
Pakete: Sent = 2139, Received = 2101, Lost = 38 (1% Loss),
Times:
Min = 0ms, Max = 1ms, Avg = 0ms
PC → TV:
Pakete: Sent = 2216, Received = 2200, Lost = 16 (0% Loss),
Times:
Min = 0ms, Max = 2ms, Avg = 0ms
Network Diagram:
All Ethernet is Gigabit Cat7.
The higher ping (1s+, 700ms+) is directly after the NAS does its WOL; it settles down to <2ms after the NAS is “up” completely.
While I did this, the Vero crashed again (around 19:00), this time I had sudo journalctl -f running in Putty (which doesn’t just close the window):
There was zero congestion on the network this time; TV was off, so no Netflix etc…
Any help? I still have the persistent journal (no idea what to do with it). Is it possible the “Cleanup of Temporary Directories” overloads it somehow? Heat problem? No idea… I always see the “Started” message, but never a message that says it’s finished.
Disable qos for testing?
How are the ports set up between the switch and the nas configured? Lagg?
To access the previous system journal run sudo journalctl -b -1. If you want to go back two journals it’s sudo journalctl -b -2, etc. (For completeness, -b 1 is the first saved journal (in chronological order), -b 2 is the second, etc, and -b is the journal starting from the latest boot.)
Anyone suggested to try a different Ethernet cable?
I seriously doubt this is a network issue… As said, directly after the WOL procedure of the NAS I’m seeing some “higher pings”, but after a very short time (when the NAS is completely booted) the pings are going down to 0.xx ms.
I just ran a ping from V4K to the NAS and I got:
— 192.168.196.50 ping statistics —
69 packets transmitted, 69 packets received, 0% packet loss
round-trip min/avg/max = 0.646/0.687/0.846 ms
The crash is happening whether there is a lot of traffic on the network or not, so even on a full idle network (in the middle of the night) I’m losing the device.
sudo journalctl -b -2 is giving me the info I had in my Putty (crash somewhere between 18:50 and 19:05), nothing else:
Jan 04 18:04:03 Vero4K kernel: aml_spdif_dai: share the same clock
Jan 04 18:04:03 Vero4K kernel: aml_audio_hw: IEC958 PCM32
Jan 04 18:04:03 Vero4K kernel: hdmitx: audio: aout notify rate 44100
Jan 04 18:04:03 Vero4K kernel: hdmitx: audio: aout notify size 32
Jan 04 18:04:03 Vero4K kernel: hdmitx: audio: no update
Jan 04 18:04:03 Vero4K kernel: aml_snd_m8_card aml_m8_snd.46: i2s/958 same source
Jan 04 18:17:58 Vero4K systemd[1]: Starting Cleanup of Temporary Directories…
Jan 04 18:17:58 Vero4K systemd[1]: Started Cleanup of Temporary Directories.
sudo journalctl -b -1 is the most recent start, it gives me logs from 21:20 with “high ping” to the NAS (as said, this is only during the WOL and shortly after the NAS is fully started up).
I cannot find anything else in the logs.
I have now enabled Debug- and Event-Logging and will wait for the next crash… Hopefully we will be able to get some more information.
Never say never…
Remember, 195 RX packets dropped on the eth0 interface. I just checked my V4K:
eth0      Link encap:Ethernet  HWaddr b8:27:eb:00:be:f9
          inet addr:192.168.8.32  Bcast:192.168.8.255  Mask:255.255.255.0
          RX packets:9260137 errors:0 dropped:14 overruns:0 frame:0
          TX packets:2388054 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:11070066885 (10.3 GiB)  TX bytes:1299177497 (1.2 GiB)
          Interrupt:40
14 RX packets dropped.
Here’s another machine:
eth0      Link encap:Ethernet  HWaddr 52:54:00:36:99:0c
          inet addr:192.168.8.12  Bcast:192.168.8.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:27185072 errors:0 dropped:1 overruns:0 frame:0
          TX packets:30329866 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:34631264405 (32.2 GiB)  TX bytes:23748833210 (22.1 GiB)
Uptime in both cases is 14 days (power outage). These are much closer to what I’d expect to see.
I don’t know what Netflix will be using but I’d expect that with gigabit LAN it wouldn’t even break into a sweat. Something else will be causing the dropped packets. As @ActionA says, try a different cable or a different port on the switch. Also beware of broadcast storms.
