Ok, it could use some cleanup, but it does work:
Thank you. Would you mind explaining how to run it? I still seem to get an error, whether putting the .py file in the folder with a movie, or in the root directory of my folders/files.
Mac-mini:Avengers Infinity War (2018) UHD htmac$ python ./mediareport.py
Color BitDepth Range Format Filename Mast. Luminance MaxCLL Mast. Color MaxFALL
File "./mediareport.py", line 123, in <module>
(exit_code, xml_data) = subprocess.getstatusoutput(command)
AttributeError: 'module' object has no attribute 'getstatusoutput'
You are trying to run it using python2. Try python3 instead.
I donāt know how to on a Mac, but make mediareport.py executable, and you should be able to just
$ ./mediareport.py
I assume you can just do:
$ chmod +x mediareport.py
to make it executable.
Thank you. I installed Python3, made mediareport.py executable, and got thisā¦
Mac-mini:Avengers Infinity War (2018) UHD htmac$ ./mediareport.py
Filename Format BitDepth Range Color Mast. Color Mast. Luminance MaxFALL MaxCLL
Error while getting mediainfo of ./Avengers.Infinity.War.MKV
Do you have mediainfo installed?
Yessir I do. Version 18.08.1.
Can you try to manually run this then:
$ mediainfo --Output=XML Avengers.Infinity.War.MKV
I get a command not found.
-bash: mediainfo: command not found
Well, that tells me that you donāt have mediainfo installed.
lol I definitely do. I use it all the time!
If you run:
$ mediainfo
and get āNot Foundā you donāt have it installed!
Sigh.
I donāt know what to tell you. Maybe itās because Iām on a Mac and you arenāt taking that into account? Iāve used Mediainfo for YEARS.
And just how do you use it, if you canāt type:
$ mediainfo file.mkv
at a command prompt.
I have a GUI? I double click the GUI app and pick the file using the GUI. Maybe this is where weāre at odds.
Iām guessing maybe thereās a command-line versionā¦
@mellon wrote the script that I modified, and he has a Mac and it worked, so I guess you need ot find out from him how to get mediainfo installed to run from a command line.
I got it. I had to install the CLI version, not just have the GUI version. Working like a charm. Thanks ![]()
It runs fine on my machine. Nice improvements @bmillham ! Much more adaptable now. I didnāt bother to invest the time, because I intended to use the script only once.
@mellon, I originally was going to just make a few changes to get it working with XML, but as you noticed I kinda went overboard
Thank you for the original script.
Has there been any progress in implementing max fall / cll data output?
Not just yet.
