Playing anything without sound, files, modules like youtube, etc β¦
logs playing a nfs file: https://paste.osmc.tv/ineyirugus
You have A2DP and Pulseaudio installed. Try to remove it as it is deprecated with the latest version.
sudo apt-get remove --purge a2dp-app-osmc bluetooth bluez pulseaudio-module-bluetooth pulseaudio
You are right
Thanks a lot
If you still need bluetooth audio follow this thread
thanks again
