ogre
1
Vero 4k connected to an ordinary 1080p tv.
Everything works great, but the menu you access by pressing left on the remote does not align properly, not showing in full.
See screenshots.
The same tv was connected to vero 1st generation without problems.
Looks like TV does wrong aspect ratio.
Do you have set it to 1:1, Just Scan or how the native mode display is called on your TV
ogre
3
Thanks, I got confused with the name of the modes. It was set to 16:9 and if i changed it to Just scan it seems to fix it.
