Hello,
This has happened a few times in the last week. I’m wondering if someone could look at the error log URL I’ve got? Where should I send that?
I’d appreciate it!
Hello,
I’d appreciate it!
Also - this is happening on a fresh install.
Normally you would just post it in this thread you started. If there is anything you would prefer to keep confidential you can edit your logs before uploading. If this issue is only happening with a particular add-on then it depends on what add-on it is. If this is not legal content then we cannot offer any help. If it is a legal add-on then likely the best source would be from the developer. Most legit add-ons have threads dedicated to them on the Kodi forum.
