hello support, hello forum,
my setup:
Synology DS1515+ gigaBit Eth 2 Vero 4k (old one)
nfs-permissions: map root to guest
the share is movie, below, i have several folders (movie, docu, concert, …)
in each folder are the files in seperat folders.
I have mount via NFS each folder under the movie share, it works.
the change:
now I bought a vero 4k plus, because some 4k movies dind’t run smothly with Fast-Ethernet.
I also changed the IP-adress in the nfs-permission-settings of the NAS.
I’m now setting up this new device, and I face following problem:
I tried to mount a source via NFS, I see the IP of the NAS, then connect, and I see the share movie. (/volume1/movie)
That’s all, I could not go deeper, I’ dindt see any folder under the share “movie”.
Test:
I tried this also with hte file-manager, it dind’t work too, I could not browse through the directories.
I create at my pc a new folder below the share “movie”, and mount this via NFS with the old vero succesfully.
Nothing with the new vero 4k plus !
Test2:
changing permissions to:
map all users to admin
map all users to guest,
nothing works
what is the problem?
KR
propman
