Hi, I purchased a Vero 4k+ and OSMC TV Tuner. I have set up TVHeadend on my Vero, and can see the EPG data through my browser (ip:9981). I can also use the EPG with no problems on a raspberry pi b+ running OSMC; however, on my Vero, no information is displayed for any of the channels. I have tried disabling and re-enabling, clearing all guide and channel data, enabling asynchronous EPG update all to no avail. The actual signal plays back fine.
Is there something I might have missed? How can I fully reset the TVHeadend client on the Vero (the disable/re-enable and clearing of channel and guide data still retains information like username and password, ip address etc)? Thank you.
Thank you all for your answers. I had this problem for 3 days, which I had thought would be enough time for the guide to populate. I came home from work today to find the guide suddenly working on the vero - as far as I can tell, it was just taking a long time.
