Hello everyone,
I would appreciate help with missing audio after update.
Device: Vero 4k
I did a (long overdue) update from version 2020-11 to latest “OSMC March 2022 2022-03-1” (Kodi 19.4.). Took so long becaue it stopped offering updates and I had to do it using the hotfix.
After bit of problems (the update patch, some migration of addons), I got it all working.
However, I NO LONGER HAVE SOUND player through HDMI on any videos.
I have been happily using Vero 4k for years using HDMI audio output to TV.
After the latest update there is no audio at all.
What I tried:
- many reboots
- reset audio in System → Audio
- disconnect & reconnect cable
- toggle audio Passthrough
What is weird I can no longer see all the Expert mode options I saw (downmix, etc.).
Audio output device in Kodi Settings → Audio does not show HDMI. I can only see
- Playback/recording through the PulseAudio sound server
- PluseAudio Sound Server
I believe it is something with ALSA, but it is way above my knowledge…
I can see it complaining about unable to work with the HDMI…
I can see these in debug long:
2022-03-26 14:37:56.301 T:2758 INFO <general>: CAESinkALSA::EnumerateDevice - device default description
2022-03-26 14:37:56.346 T:2758 INFO <general>: CAESinkALSA - Unable to open device "btaudio" for playback
2022-03-26 14:37:56.361 T:2758 INFO <general>: CAESinkALSA - Unable to open device "jack" for playback
2022-03-26 14:37:56.363 T:2758 INFO <general>: CAESinkALSA::EnumerateDevice - device pulse description PulseAudio Sound Server
2022-03-26 14:37:56.368 T:2758 INFO <general>: CAESinkALSA::EnumerateDevice - device hdmi:CARD=AMLMESONAUDIO,DEV=0 description AML-MESONAUDIO,
HDMI Audio Output
2022-03-26 14:37:56.369 T:2758 DEBUG <general>: CAESinkALSA - Unable to obtain ELD information for device "hdmi:CARD=AMLMESONAUDIO,DEV=0" (not supported by device, or kernel older than 3.2)
2022-03-26 14:37:56.372 T:2758 INFO <general>: CAESinkALSA - Unable to open device "usbstream:CARD=AMLMESONAUDIO" for playback
2022-03-26 14:37:56.372 T:2758 INFO <general>: Found 1 Lists of Devices
2022-03-26 14:37:56.372 T:2758 INFO <general>: Enumerated ALSA devices:
2022-03-26 14:37:56.372 T:2758 INFO <general>: Device 1
2022-03-26 14:37:56.372 T:2758 INFO <general>: m_deviceName : default
2022-03-26 14:37:56.372 T:2758 INFO <general>: m_displayName : Playback/recording through the PulseAudio sound server
2022-03-26 14:37:56.372 T:2758 INFO <general>: m_displayNameExtra:
2022-03-26 14:37:56.372 T:2758 INFO <general>: m_deviceType : AE_DEVTYPE_PCM
2022-03-26 14:37:56.372 T:2758 INFO <general>: m_channels : FL, FR, BL, BR, FC, LFE, SL, SR, UNKNOWN1, UNKNOWN2, UNKNOWN3, UNKNOWN4, UNKNOWN5, UNKNOWN6, UNKNOWN7, UNKNOWN8
2022-03-26 14:37:56.372 T:2758 INFO <general>: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
2022-03-26 14:37:56.372 T:2758 INFO <general>: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
2022-03-26 14:37:56.372 T:2758 INFO <general>: m_streamTypes : No passthrough capabilities
2022-03-26 14:37:56.372 T:2758 INFO <general>: Device 2
2022-03-26 14:37:56.372 T:2758 INFO <general>: m_deviceName : pulse
2022-03-26 14:37:56.372 T:2758 INFO <general>: m_displayName : PulseAudio Sound Server
2022-03-26 14:37:56.373 T:2758 INFO <general>: Device 3
2022-03-26 14:37:56.373 T:2758 INFO <general>: m_deviceName : hdmi:CARD=AMLMESONAUDIO,DEV=0
2022-03-26 14:37:56.373 T:2758 INFO <general>: m_displayName : AML-MESONAUDIO
2022-03-26 14:37:56.373 T:2758 INFO <general>: m_displayNameExtra: HDMI
2022-03-26 14:37:56.373 T:2758 INFO <general>: m_deviceType : AE_DEVTYPE_HDMI
2022-03-26 14:37:56.373 T:2758 INFO <general>: m_channels : FL, FR, BL, BR, FC, LFE, SL, SR
2022-03-26 14:37:56.373 T:2758 INFO <general>: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
2022-03-26 14:37:56.373 T:2758 INFO <general>: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
2022-03-26 14:37:56.373 T:2758 INFO <general>: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_MA,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
2022-03-26 14:37:56.373 T:2759 INFO <general>: CActiveAESink::OpenSink - initialize sink
2022-03-26 14:37:56.373 T:2759 DEBUG <general>: CActiveAESink::OpenSink - trying to open device ALSA:pulse
2022-03-26 14:37:56.373 T:2759 INFO <general>: CAESinkALSA::Initialize - Requested layout: FL, FR
2022-03-26 14:37:56.373 T:2759 INFO <general>: CAESinkALSA::Initialize - set digital_codec 0
2022-03-26 14:37:56.373 T:2759 DEBUG <general>: CAESinkALSA::Initialize -- unmuting HDMI
2022-03-26 14:37:56.373 T:2759 INFO <general>: CAESinkALSA::Initialize - Attempting to open device "pulse"
2022-03-26 14:37:56.377 T:2759 INFO <general>: CAESinkALSA::Initialize - Opened device "pulse"
2022-03-26 14:37:56.379 T:2759 DEBUG <general>: CAESinkALSA::InitializeHW - Request: periodSize 2048, bufferSize 8192
2022-03-26 14:37:56.420 T:2759 DEBUG <general>: CAESinkALSA::InitializeHW - Got: periodSize 2048, bufferSize 8192
2022-03-26 14:37:56.420 T:2759 DEBUG <general>: CAESinkALSA::InitializeHW - Setting timeout to 186 ms
2022-03-26 14:37:56.420 T:2759 INFO <general>: CAESinkALSA::Initialize - speaker layout 0
2022-03-26 14:37:56.423 T:2759 DEBUG <general>: CAESinkALSA::GetChannelLayout - Input Channel Count: 2 Output Channel Count: 2
2022-03-26 14:37:56.423 T:2759 DEBUG <general>: CAESinkALSA::GetChannelLayout - Requested Layout: FL, FR
2022-03-26 14:37:56.423 T:2759 DEBUG <general>: CAESinkALSA::GetChannelLayout - Got Layout: FL, FR (ALSA: none) (CEA: 0)
2022-03-26 14:37:56.423 T:2759 DEBUG <general>: CActiveAESink::OpenSink - ALSA Initialized:
2022-03-26 14:37:56.423 T:2759 DEBUG <general>: Output Device : PulseAudio Sound Server
2022-03-26 14:37:56.423 T:2759 DEBUG <general>: Sample Rate : 44100
2022-03-26 14:37:56.423 T:2759 DEBUG <general>: Sample Format : AE_FMT_FLOAT
2022-03-26 14:37:56.424 T:2759 DEBUG <general>: Channel Count : 2
2022-03-26 14:37:56.424 T:2759 DEBUG <general>: Channel Layout: FL, FR
2022-03-26 14:37:56.424 T:2759 DEBUG <general>: Frames : 2048
2022-03-26 14:37:56.424 T:2759 DEBUG <general>: Frame Size : 8
and later this when I start playback
2022-03-26 14:37:56.925 T:2758 INFO <general>: CAESinkALSA - Unable to open device "btaudio" for playback
2022-03-26 14:37:56.932 T:2758 INFO <general>: CAESinkALSA - Unable to open device "jack" for playback
2022-03-26 14:37:56.935 T:2758 INFO <general>: CAESinkALSA::EnumerateDevice - device pulse description PulseAudio Sound Server
2022-03-26 14:37:56.940 T:2758 INFO <general>: CAESinkALSA - Unable to open device "hdmi:CARD=AMLMESONAUDIO,DEV=0" for playback
2022-03-26 14:37:56.940 T:2758 INFO <general>: CAESinkALSA - Unable to open device "usbstream:CARD=AMLMESONAUDIO" for playback
2022-03-26 14:37:56.940 T:2758 INFO <general>: Found 1 Lists of Devices
2022-03-26 14:37:56.940 T:2758 INFO <general>: Enumerated ALSA devices:
2022-03-26 14:37:56.940 T:2758 INFO <general>: Device 1
2022-03-26 14:37:56.940 T:2758 INFO <general>: m_deviceName : default
2022-03-26 14:37:56.940 T:2758 INFO <general>: m_displayName : Playback/recording through the PulseAudio sound server
2022-03-26 14:37:56.940 T:2758 INFO <general>: m_displayNameExtra:
2022-03-26 14:37:56.940 T:2758 INFO <general>: m_deviceType : AE_DEVTYPE_PCM
2022-03-26 14:37:56.940 T:2758 INFO <general>: m_channels : FL, FR, BL, BR, FC, LFE, SL, SR, UNKNOWN1, UNKNOWN2, UNKNOWN3, UNKNOWN4, UNKNOWN5, UNKNOWN6, UNKNOWN7, UNKNOWN8
2022-03-26 14:37:56.940 T:2758 INFO <general>: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
2022-03-26 14:37:56.940 T:2758 INFO <general>: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
2022-03-26 14:37:56.940 T:2758 INFO <general>: m_streamTypes : No passthrough capabilities
2022-03-26 14:37:56.940 T:2758 INFO <general>: Device 2
2022-03-26 14:37:56.940 T:2758 INFO <general>: m_deviceName : pulse
2022-03-26 14:37:56.940 T:2758 INFO <general>: m_displayName : PulseAudio Sound Server
