Got in my device mid February 2018 and it was running fine till yesterday. The Vero show it is powered on but the front light is red it is not putting out any signal over HDMI.
Tried the TV it was normally connected toa nd my computer monitors. Also noted that it was no longer showing up on my network any more. So no SSH possible.
I tried a reinstall with an USB stick to no avail. After that i followed the Trouleshooting tips and renamend the kernel.img to recovery.img and also used a non-conductive pin to push the Button on the side of the HDMI port over 30 sec.
Still no reaction from my Vero. No HDMI output and the Front light is still red.
And i forgot to mention that i didnt installed anything in the last few month beside the regular OSMC updates.
Any Advice? Or can i put it after 2.5 years in the bin?
Thanks in advance for any help.
Sounds like you may just need a new power supply.
You are 100% percent right, ActionA.
I tested the vero with the power supply from my bed room installation and it booted right away. I should have tested it before. Thank you very much!
