Hi all
Just received my Vero 4k+ a little while ago. I look forward to getting to know the unit better. It was purchased exclusively to play 3d blu-ray isos, a feature that my Nvidia Shield Pro is sorely missing.
I use the Vero 4k+ with my Optoma UHD42 projector to view 3d content. The Vero 4k+ works just fine with 3d rips in SBS and TB, but that is not a feature that I will use much due to the lower resolution.
What I want is to play isos of 3d blu-rays. When I try this, the Vero 4k+ does not play the file properly (either shows up in 2d or a just as a mess) and I cannot activate frame packing on my projector, so it is just not picking up any frame packing/sequential signal from the Vero 4k+.
As mentioned, I just received and set up my Vero 4k+. I have updated using the menu updater, so should be on latest software.
My question is as follows: why is my unit not handling 3d isos propely ? Is a special software version/build necessary? If so, where to I get that software and how do I install it on my unit?
Thanks a million.
I have no knowledge of this system, as I just got it. Is there a guide that I can read on this in order do gain knowledge on the system quick, in particular on the 3d aspects? i.e. on where the 3d build is available and how do I install it ? I have reasonably ok background knowledge on xbox media center/kodi from original xbox back in the day and kodi on pc (allthough not used for 3d there). Thanks again.
