I recieved my Vero yesterday love the audio and video quality but its overheating after 5 to 10 minutes it’s at 145 degrees average it cuts off and is hot to the touch I’m running a portable harddrive 2tb thru the usb…thanks in advance
145 degrees should not be possible it should auto switch off at 120 degrees
Please provide logs so that we can help you (see below)
reproduce the issue
upload the log set (all configs and logs!) either using the
After it cuts off I have to unplug it …I hope that doesn’t effect the log
Well most of the log will be lost with a reboot. But with this log we already could get an overview. There is nothing in there that gives any indication why the system is over heating.
Is it happen randomly?
Is it related to play certain videos?
It seems random but when I scroll through my movie library is when I can make it occur it has stopped while playing also and I have seen a sad red face and a red light
Your picture show 158F (70D) which is a normal temperature. So you have seen 293F (145C) as your wrote in your first post?
No sir the highest I’ve seen was 180
180F (82c) is a total normal temperature for the Vero4k. I starts to reduce frequency above 90c and will shutdown at 120c.
So your problems must be something other than overheating.
Maybe you want to enable SSH and login from PC to see if you loose connection in the case where you have your “crash”
I’ll try to set that up …I’ve read a few post on here…do u think it could be a harddrive issue with the vero powering my usb
Possible, we always suggest either self powered drives or using a powered hub but it normally not mean a full crash.
SSH access will tell you the status
Yes – that could cause system instability.
I suggest removing the drive and seeing if the situation improves.
Purchased powered usb hub problem solved thanks guys for the help and support
