I detected yesterday, that my Vero 4k+ with a 10-15% CPU usage, it’s processor temperature was 81ºC (21ºC in the room), is that a correct temperature ?
I’m using Eminence skin, but the temperature is the same with OSMC skin. And all works fine.
Not really strange as playing the Video only need GPU and CPU is relaxed.
When you are in the skin especially when you have scrolling text that uses big time CPU.
Vero 4K. When any menu screen with a list of movies is on, for example, and nothing is playing, the processor starts to get very hot. As soon as I switch to the main menu screen, the temperature immediately begins to decrease
One possible explanation is when you see scrolling text in the GUI of the used skin. This increases the CPU consumption … but the temperatures shown are not critical.
