Hello everyone.
On wednesday (29/01), my OSMC entered on a boot reloop… I didn’t make any changes to the system (no new apps, different network, nothing).
Thanks for the reply fzinken.
I was able to follow your instructions and moved the directory.
With the clean install everything went ok, the Vero booted and stayed stable (default screen, no files or addons).
When I restored, the boot loop returned…
That would mean that most likely one of the addons you installed causes the problem.
If you don’t want to start from scratch (recommended) then I suggest to do the move command and then just copy back the files from the userdata folder. Also maybe remove the repositories you added to your sources.xml
Actually in your situation you don’t need to start that far from scratch.
Just removing the Kodi directory as you did and start with a clean Kodi is good enough.
