Is there any suggestions for troubleshooting my remote. It stopped working overnight last week.
Blue light comes on ok when buttons pressed but no response on Vero. Yatse Android remote operates the device fine.
Thanks!
Thanks!
Did you try to re-pair the remote?
Thanks I’ll try it tonight!
Genius. Paired successfully, didn’t need the reboot. Thank you!
