after i power off my Vero 4 k which buttons on the remote can i press to power the vero 4k up again
You need to unplug the vero4k and plug back in to power back on. Vero4k is designed to be on 27/4
If you wish do this with remote instead, use the suspend mode.
Thanks Tom.
