Source file mediainfo:
Video
Format : AVC
Format profile : Baseline@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 42 min 23 s
Bit rate : 1 950 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.071
Stream size : 583 MiB (94%)
Writing library : x264 core 118
My AVR (Onkyo NR-676) says it is receiving a direct 1080/59hz stream. Of less concern is that my source has 2.0 aac audio but the receiver is reporting 2.0 pcm.
Vero4k is connected directly to AVR, so what’s going on here?
