I have not used my Vero 4k for some time and trying to use it again.
I just have the vero 4k box, Power Supply and Remote.
I cannot get the remote to work. Does it need some kind of dongle (USB or RF) to work? My box is from August 2019.
Thanks!
Thanks!
Yes - a dongle is supplied with the remote.
Bummer - I cannot find mine. Can I order another from you folks or Amazon?
Many thanks! I just found it. Happy holidays and all the best for 2022!!
Glad to hear it. If you haven’t used the remote for a while, you might need to pair it to the dongle. You can do this by holding Home and OK for a few seconds.
