Hi guys. I have a Vero 4k+ that has been working like a champ for a few years now but has all of a sudden stopped. Now, if I unplug it and plug it back in, it usually shows the red led for a few seconds and the goes out. On time it actually stayed solid red until I unplugged it again. In either case, HDMI output is null. I have nothing else plugged in except a micro sd which I removed to test.
I have tried it with the original PS and the one that I have for my older Vero 4K (non-plus). This is in two different rooms with different plugs/circuits. I have not allowed an update for at least a year or two so thing should have not really changed, AFAIK.
The device sits in a “media” closet and is plugged into an HDMI matrix switched that distributes throughout the house. It is used every once in a while so it hard to say how long it was in the state exactly. But I can say it was no more then a few weeks.
I specifically disabled auto update for the OS. I didnt want it upgrading to the latest kodi (Leia?) because the family is used to the Aeon skin. Instead, I have been using the older 4K for testing updates which has been unstable for me but have not had time to look into that one more.
