I assume “Auto Wide” should be the ride mode. Can you take a full picture of how Kodi looks after you set “Auto Wide”
Also when choosing "Auto Wide’ what option has “Fit to Screen”?
May you can choose it if you first set “fit to screen” to off?
While also the manual says it can not be choosen in all geographic areas (for whatever reason).
The Reason i ask all this is because i cannot choose Passthrough Audio if i set the output configuration to fixed… and i thought maybe its because of this…
