Hello,
We are not in disagreement that i have send back my Vero 4K+ for further investigation knowing it was possible it could not be repaired.
We are not even in disagreement about the specific point of hardware failure, i still believe you when you say the motherboard failed at the barrelconnector.
But we do, however, disagree about what exactly caused that failure. You are saying i used an incorrect powersupply, and i know i have not used any other powersupply then the original powersupply that came with the device.
And we do seem to disagree about wether my OSMC ucb hub is faulty, and a contributing factor in the failure of my Vero 4K+.
As to the first point of disagreement, my Vero 4K+ has for 20 months happily being hanging on it’s wallmount on the inside of the tv-cabinet. And it has not even been touched for 99,9% of that time. Always powered by it’s own original powersupply, and always on. I was watching tv when it died, with no other device showing problems at the same time.
That is also exactly why i investigated every device connected to the Vero 4K+ at that time, because there was no obvious cause. I used no extensioncord and the powersupply has it’s own wallsocket. And i only found the OSMC usb hub being faulty.
That is actually not true. I work at a company manufacturing motherboards/mainboards, and motherboards/mainboards can take up to 3 years to fail because of manufacturing defects or ESD problems. That is also how i know the absolute havoc backfeeding usb hubs can cause, and why i bought the OSMC usb hub that should not do this.
You expect me to believe a lot of things you stated, for example replies you have send but never arrived, canned replies that were not meant for me, and that i have used an incorrect powersupply. I have answered youre every question truthfully, but you still refuse to believe a single thing i said, for example the fact that i never used an incorrect powersupply.
This is still no answer about my OSMC power backfeeding usb hub. Is my OSMC usb hub faulty because it is backfeeding power? A simple yes or no answer will suffice.
And i have seen the “a bit of praise” thread before, and up until 3 months ago i wholeheartedly agreed with that thread. And i absolutely loved my Vero 4K+ while it was working for 20 months.
But as i said before, i just can not seem to get my point across that i have never used an incorrect powersupply. And therefore the reason for the failure of my Vero 4K+ cannot be me screwing up. I have 2 original OSMC powersuplies, the one that came with the unit and the one i ordered as a spare alongside the OSMC usb hub. So why would i ever use another powersupply then the original? There is no logic to that and it makes no sense.
So my last question for you can be answered with another simple yes or no. Do you believe that i am lying when i say i never used an incorrect powersupply?
Olav.
