Hello again,
Since i do not get any response anymore on my support ticket for 3 weeks now, despite several messages asking for a response, i decided to get back to my original thread to get some help.
In short: after some time going back and forth on the support ticket, checking several causes, the last option was to send my Vero 4K+ back to OSMC, so i did that. The verdict was that the device failed due to using the wrong powersupply, and there was nothing left to do. End of story after 20 months of life for the OSMC flagship device.
Now, that was very confusing, since my Vero 4K+ has only been powered by it’s official OSMC powersupply that came with the unit. And i have made that clear several times in the support ticket.
Because i know i have never used any other powersupply than the original OSMC powersupply i was at a loss. Also because if i were to buy a new device then that device would be powered the same way, and run the risc of failing also after 20 months.
So i decided to test every device connected to my Vero 4K+ at the time of failure.
Selfpowered HDD: no problem.
OSMC DVB-T2 dongle: no problem.
OSMC powersupply: 5.3 volt (oke i think)
OSMC spare powersupply: 5.03 volt (oke i think)
OSMC USB 3.0 powered Hub: 5.1 volt !!!
And that last one surprised me, since i specifically bought the official OSMC powered usb hub (and a spare OSMC spare powersupply) because of several warnings i read in some topics on this forum about “power backfeeding usb hubs” and that they can damage your device. I received the OSMC powered usb hub shortly before my Vero 4K+ failed, and it was actually connected to my Vero 4K+ at the time it failed. And connected to the usb hub was the self powered HDD and the OSMC DVB-T2 dongle.
Now, with all the switches on the usb hub in the off position there is no power backfeeding, but with any of the switches in the on position there is 5.1 volt power backfeeding on the cable connecting the usb hub to any device. And thus, my Vero 4K+ was receiving power from it’s own OSMC powersupply and receiving power from the OSMC usb hub. And if i read several warnings correctly on this forum you should never power the Vero 4K+ (or any other device) by it’s own powersupply and a usb hub at the same time.
This last finding was reported back to OSMC via the support ticket, but i get no response anymore.
So at this point in time i have no Vero 4K+ anymore, that has been shipped back to OSMC, with nothing left to do about that. I do however have a OSMC powered usb hub that is backfeeding power, and that was connected shortly prior to my Vero 4K+ failing due to “using the wrong powersupply”. And i do not get any response anymore on my support ticket.
I can accept that no device has the eternal life (that is why i also ordered a spare OSMC powersupply alongside the OSMC usb hub). But it is getting almost impossible to accept the “using the wrong powersupply” explanation i got from OSMC knowing now that i have an OSMC powered usb hub that is backfeeding power when it is absolutely not meant to do that.
If i screwed up, than i happily spend the money for a new Vero 4K+, since i loved every moment of it when it was working for 20 months. I even asked several times what a replacement unit was going to cost me, before i checked the malfunctioning usb hub, but i never received an answer to that question either in the last 3 months.
But i don’t think i screwed up here, since i only used the official OSMC equipment, and one of those has been found to be faulty.
Sorry if the above comes over as terribly impatient or angry, but i am really disappointed by this whole support experience. I just want to get this sorted out, and in the proces of that just taken seriously.
So if anyone can help me to figure out what to do now, and get this sorted, that help will be very appreciated.
Olav.
