Vero 4k Titan Skin
Hello I am interested in the Vero 4k. Is it possible to use the Titan Skin with all the features on it?
Other Question: is it possible to run Java on it and Jdownloader headless?
I am running the pi 3 at the moment with OSMC but sometimes it’s a bit slow with the skin… and also it doesn’t support the new sound format and codecs.
Thanks for the answers and time.
Greetings from Germany
Daniel
If the Titan skin works with Kodi Krypton, then it will work fine.
Yes.
In short: anything that works on your Pi will work on the Vero 4K.
Thank you very much for the quick answer!
