One of my Vero 4K+ is having some trouble, i can maybe watch something 5 minutes before i get a sad face and it restarts. And i can watch 5 more minutes and the same happens over and over again.
I have a second Vero 4K+ and no issues on that.
reboot the OSMC device
reproduce the issue
upload the log set either using the
Can you swap the two devices over?
Hello, I also get the warm up to a point where it stays frozen and with green dots across the screen, and when you touch the device is burning.
Please refer to the post from @ActionA to provide debug enabled logs if you want the problem to be identified.
