I have a Vero 4k+ and until Nov2020 all updates were installed via GUI and without any problem. Got a notification and could install it.
Since then, no new update got offered, so I tried through SSH.
In fact updates got downloaded and installed (as far as I can see it as a newbie), but the screen shows still November 2020 status. I couldn’t identify any error in the update process via Terminal.
Things I have done:
- Rebooted couple of times after install
- Used sudo apt-get update and sudo apt-get dist-upgrade
Where can the issue be? I use a Pi Hole, but couldn’t see any block, but have also disabled it during the update process.
System Info gives me: Version: OSMC running kodi 18.9 & Komplet: 2020-11-27
