Hi all,
I’ve just ordered the TV dongle to use my Vero 4k as a PVR and I have some doubts.
- I think that the TV dongle will need one USB port correct?
- I would like to connect an USB drive to the Vero 4K for the recordings: it is allowed ?
2.1 A standard portable USB drive without separate power it will be ok ?
2.2 The disk will need some particular formatting ? if yes wich one? - If yes to the questions 1. and 2. , can I remove the RF dongle for the remote since I have “view” between the VERO 4K and the remote ?
Many thanks in advance
