@sam_nazarko
So I previously tried alsorts so wifi would stay on, Ping from server every minute, didnt work
When debugging was enabled, it would be fine for weeks, so turned it off, after 3 days wifi dropped
I have added this line
AllowWiFiPowerSave=false
to
/etc/connman.conf
So far systems been on for a month, without dropping connection
So will that line actually work with the hardware? or is this just coincidense
Power saving is disabled in the driver, so I’m not sure how this could make a difference
maybe just coincidence then lol
I dont get why having debugging on full, keeps the wifi connection alive either, thats why I thought Id solved it, but when debug is turned off, few days, 2 weeks tops, its off line
you can go to the TV and scroll through things, but no network connection is shown, and it wont reconnect without reboot
I`ll leave it longer
