So i have started to shut down or power off Vero 4k at the end of the day, but simply put it will not start up again unless i physically disconnect the power plug and reconnect.
I don’t have issue in doing a reboot, and at first i never bothered shutting down, it is just a recently have had problems with one WD external drive attached to the hub and decided i best eject all 4 drives and shut down at the end of the day.
After shut down the red light is on. but no matter which button i press on the remote the box does not respond and i read that it should just restart by touching any button?
any ideas?
thanks
