I have been playing around with the Vero 4K and it is giving me quite a headache.
I try to factory reset under Updates/manual control but after I select the reset after reboot and exit and reenter the same setting it has unselected it. Meaning that nothing happens when I do reboot it?!?
It also wont ‘forget’ previous IP adresses for networks that are longer valid. Meaning that when I try to clean the video library it starts to scan for content on an IP adress there is no longer there (so it fails). If I reenter clean library it usually finds the right one.
Another thing is that it doesn’t seem to care about updated IP adresses from my router. Meaning that when I try to add a new video source It finds the previous IP and not the new one that was just assigned to the network (wireless). If I try to edit the IP manually it says that it cant find a network and then finds a connection on the previous IP? How does that work?
Also a question: Is NFS faster than SMB in regards to streaming wireless?
