Vero 4k+ won't turn on
My 2 yr old Vero 4k+ suddenly won’t turn on. (Red light is on and stays on.) Remote shows blue light when pressed, but I changed the battery just in case. I’ve disconnected the Vero and reconnected, moved the dongle to the other usb port but no luck.
Anything else I could try?
Yep, try changing the PSU. You can take a USB Charger with 2 A power output and connect to the USB-A port.
Thanks for the reply Smurphy. I’ll pick up a new psu and give that a try.
New psu, Vero 4k+ working. Thanks again Smurphy.
