I always leave my 4K on standby. Today I have the red light as usual but the remote won’t turn the unit back on. The remote blue led flashes and I tried a new battery just in case - no luck. Tried disconnecting/reconnecting power and removed dongle and reinserted but still no luck. Is there anything else I can do to try and troubleshoot?
Hi, you can try to supply the vero 4k with power via one of the usb ports (just for tests). Of course, this only has to happen when the power supply is disconnected from the vero.
You need a cable with USB-A male connector on both sides.
If the vero starts as usual, the power supply has reached the end of its life cycle.
Thanks for testing that Jim. I don’t have anything offering power with a USB-C port. I do have an OMSC powered hub though. I couldn’t find an A to A cable so ordered one from Amazon. Should be here by next Tuesday.
I just noticed that the led is now switching between red and blue every minute or so. Is that an indicator that the power supply is faulty? It looks like you don’t sell the power supply separately.
Got the A-A cable today and it successfully powered up the Vero 4K when attached to the OSMC hub. Unfortunately I’m now left without a USB port on the Vero to attach a portable drive. Hopefully the new PSU will arrive soon.
New power supply finally arrived today and the Vero 4K is operating again. Amazing how much better the picture quality is over the Nexbox I was using as a temporary replacement.
Thanks for your help!
