I just obtained a vero 4k+ and the light on the front, indicating ‘on’ does not work?
what should i do?
what should i do?
It doesn’t stay on by design. Did you hook it up to test it?
The Vero 4K + doesn’t have an on light.
Thank you for the information.
How do you know if the Vero 4k+ is on?
The Vero is intended to always be on (like most modern A/V devices). There is an option to suspend which puts it in a lower power state though.
