any update on when android will be available for vero…
am I right in assuming that vero will function as a normal media player as well as allowing access to google play store to buy/rent films and also Netflix.
If so, this would be awesome and is what I am looking for…
We will ship an Android image for customers that wish to use Android Apps (APKs) but we still run Kodi through Linux for performance and functionality reasons
At the moment, you will have to maintain the two separate installations. I will streamline them in the future, but there has not been too much demand so far, so we have worked on other things the users are more interested in.
So, when the Vero 2 site says “With Vero, you can switch between Android and OSMC right from your remote.” it sounds pretty official to me?
What will I have to do, to enable this feature on Vero 1? Does it work differently on Vero 2? Or is all that in testing now but scheduled for official release, when Vero 2 ships?
Now I see what you mean. The Vero 2 allows ‘switching’ because we have both internal (NAND) storage and an SD card slot, which makes the dual boot process much easier. On the original Vero, you would need to swap the SD card each time you wanted to swap between OSMC and Android.
Hey Sam!
Thanks for the quick responses and that clears it up, yes. Since I’m eager to get Netflix working on the Vero I guess I’ll give that Android image a try.
Edit: Speaking of which - is it possible to download the image already? I can only find topics where you say that it’s in testing and that people should contact you, if they wanted to check it out. Could you send it to me please?
Along with this thread, I get the impression the Android build has been mothballed. Do you still have builds you’re willing to let people try, or is that asking too much maintenance for little return? Thanks
