I have installed a Vero 4k in a small commercial cinema. I need to permanently adjust the lip sync on the hdmi output by about 150ms. Can this be done?
This is something you usually configure on the Receiver end, as this is the one causing the delay.
The Vero device can do this (actually, it is the kodi software doing it), but saves that data on a per movie/media base.
Sttings level: Expert
Setting -> System -> Audio -> Audio output latency
i think that is what you need
Alternatively, you can go into the sound properties when a video is running, change the Audio offset, and then select “Set as default for all media”.
