Vero & Norton Firewall
I have my files in network-shared drives on a Win 11 desktop (& using SMB). However, if I reboot my PC, Vero can’t access the shares unless I toggle Norton Smart firewall off then on.
After that, Vero works fine, obviously until next PC reboot.
I can work around it, but is there anything I can define in the Smart F/Wall settings to avoid the need for toggling of/on?
many thanks!
Is there a setting for SMB server? If not, we could give you custom port settings to configure.
Hi Sam,
I can’t see anything specific form SMB,
thanks
here’s the info I’d need to add a new entry:
I can see this in my F/wall logging:
I tried setting a rule to Allow that IP for TCP(6), but no change.
What are the options in Protocol and/or Profile?
Lots!
And “Profile”?
For SMB you would need to allow
TCP: 445
TCP/UDP: 137-139
thanks - would that be local or remote ports?
Local Port
ok, created this, added it to the F/wall rules, re-booted, & all seems fine :grinning:
Many thanks for your help :+1:
