My Vero is not turning ON.
I have tried to update the OSMC and after that its not turning ON.
On TV there is ‘No Input’ massage, and I also can not notice any red light in the Vero.
I have a very basic Vero setup, power-cable, HDMI cable, Ethernet-Cable, and SPDF cable.
Can you still connect to it using ssh or ping it ? If you left it on the default device name you should be able to connect to osmc.local. If you can connect via SSH then run the following command and paste the result:
It was working just before the recent update (22nd Feb’16).
I was running the June’15 release, since I was facing the dependency failed error.
I tried to update to the recent update to check if it works.
Sam:
In fact I have tried all of those, without any success.
There is no SPDIF light, I even checked it in a dark room just to make sure. But if I keep the plug inserted Vero gets warm, not sure but that probably mean the power supply is working alright.
You appear to be the same person that was quite abusive in the same thread last week towards someone else on the team.
You have signed up with the same first name
You have the same last used IP address, which belongs to UND.
You seem to have changed your reported issue here though. Previously you said it didn’t work post June, but now you say it doesn’t work at all. The method for remedying this issue remains the same
If you get in touch by email we are happy to arrange a return.
