Hey everyone- Just got my Vero in the mail. Apologies from the start, I’m a end user noob on all things coding, but have been using XBMC/Kodi for years and love it and have been a [financial] supporter for a long time. I’ve read a bunch of guides but none have provided enough info to help me figure this out.
The setup:
Windows 7 HTPC storing all files connected to the network (HPTC/D/Movies and HTPC/D/TV)
Vero connected to the network
Problem:
I can’t figure out how to access my files through the Vero/OSMC options. I’ve typed the name of the path above when prompted but get an error suggesting the network is to blame. Under Add Videos -> Browse, when I hit NFS it says “busy” for a minute and then drops back to the menu without anything happening.
When I go through the Windows SMB route, I click through the folder network to D and get prompted for a username and password but from every setting in Windows I can find, there are no password requirements turned on. If that doesn’t matter, which username/password does it want me to use (have no idea what any of them are since they are not required).
Or if I’m going about this the wrong way, please point me in the right direction.
Thanks for the help!
-JC
