I see that Vero V also has a 120hz option for 1080p GUI. What is the recommendation for GUI in 1080p (60 or 120), and what are the possible negatives of having a GUI in 1080p 120. TV supports 120Hz.
I think leaving it at 1080p60 should be fluid enough.
Can you even perceive the difference between the two modes?
Just tested the differences, I can’t say I can see the differences like I can see on a cell phone when it’s at 120HZ
More frequent mode changes when you start a video unless your videos are in 120hz
That’s why I run my GUI at 24Hz…
