I’ve received my Vero V last Saturday. Made an Update right after unboxing. Did some testing and most of the functionms are working fine.
But 3D iso files are absolutely not workin for me neither for NAS nor from disk no matter what settings I use. Those iso’s work absolutely fine with my Dune 4k Solo.
I get hard crashes sometimes with console screen sometimes with a reboot.
many thanks for your response, here you are: https://paste.osmc.tv/ arayofilux
I’ve tried the Avatar.iso from USB disk and ended in a hard crash with auto reboot .
Morning everybody,
I can confirm that 3d iso are running fine with Kodiv21 IF “play main movie” is selected in settings otherwise the player will crash.
For other findings I will generate new forum posts.
All the best
Michael
The problem with BD-J menu support and 3d isos is, that the implementation in the libbluray 3rd party library that Kodi’s using is completely missing. That’s just not supported. Either you get the warning that the player doesn’t support 3d playback or you get hangs or crashes.
