AfaIk, your device has a USB port. Simply connect it as a USB DAC device via an USB 2.0 cable. It should appear in the mediacenter at settings -> system -> audio -> audio output device.
Currently I’m using for tests
DAC Cambridge Audio DacMagic 100 in USB audio class 2 mode
OSMC uses bluez-alsa to support BT audio. We build this with only those codecs that are free to distribute which does not include aptX or LDAC. See here.
If you are comfortable with compiling linux apps then follow the excellent instructions in the bluez-alsa wiki to roll your own. Let us know how you get on because it’s been a long time since we’ve updated our bluez-alsa build.
I just remembered, we do give some guidance on how to add codecs here.
@JimKnopf has pointed out that the LDAC encoder does not need a licence. I’ve built bluez-alsa with LDAC but I can’t test it so can you get the file from here, copy it to vero and
@grahamh
Thank you very much, I will try it out!
Is it possible to see somewhere in osmc/Kodi which codec is currently being used to transmit audio via Bluetooth?
If that works, that would be a great and easy feature for an upcoming OSMC release, wouldn’t it?
Edit: The download link to the deb file doesn’t seem to work.
