Vero V Bluetooth problem
I’d like to report a bluetooth problem with my new Vero V, hope you can help
I recently bought a SofaBaton X1S to use with the vero v, because CEC was acting flaky, controlling Kodi over IR through LIRC causes a noticeable delay between button presses, so i tried to connect sofabaton hub with vero v via bluetooth (present as a keyboard) to see if it can make a difference
When i go to myosmc > bluetooth > enable, and try to pair, no devices are shown at all
ssh into the vero v:
- `hciconfig -a` returns no output
- `/sys/class/bluetooth/` contains no `hci0`
- Wi-Fi discovery works normally
- rebooting vero v does not help
I did `grab-logs -A` and they are on https://paste.osmc.tv/ogoyuruday
logs show repeated Bluetooth initialization failures such as `OP_H5_SYNC Transmission timeout` / `Retransmission exhausts`, followed by `sdio-bt-firmware.service` failing to start
I also installed the latest OSMC update today, during reboot I briefly saw a message saying that vero v bluetooth failed to start, and the boot logs still show repeated H5 sync timeouts and failed to start Vero5 Bluetooth support
Regards, Neven
Hi, I compared your Bluetooth related system log entries with one of my VeroV systems. Looks to be a HW-related issue with the Bluetooth chip set.
I suggest:
  1. Cold boot (disconnect from power supply and reconnect) the VeroV and try again.
  2. On no success contact support@osmc.tv along with your order number, an one-line description of the issue and a link to this topic.
will do, ty for the suggestion
I have purchased Vero V and SofaBaton X1S recently and had no problem pairing them over BT.
Hey Jim, just wanted to follow up on this
The cold boot fixed it. After fully disconnecting the Vero V from power and reconnecting it, Bluetooth came back and hci0 was present again.
hope it stays that way, tnx for the solution
Let’s keep an eye on things
Best
